my engine just came back from machine shop!!! rb25 build
otightitzjim
Car: S14 kouki baby
hey wasup guys. im currently building my rb25 series 2. heres a list of things being done to it. i just got my engine back from the machine shop tonight whoohoo. let me know what you guys think about my build. it should be pretty sick i hope when its done. -----engine------rb25det series II fully built-custom engine mounts-garrett gt3082r dual bb-6boost turbo manifold-tial 44mm wastegate-custom dump pipe-custom screamer pipe-3in downpipe-greddy intake manifold-q45 80mm throttle body-300zx fuel filter-nismo fuel pressure regulater-power fc L-jetro with commander-greddy 4 row front mount intercooler-walbro 255lph fuel pump-nismo 740cc sidefeed injectors-greddy timing belt-belt tensioner-koyo 3in radiator-samco radiator hoses-greddy type rs bov-blitz dual solenoid sbc boost controller-z32 mass air flow sensor-dual flex-a-lite electric fans-dif fan controller-tanabe concept g 3in catback exhaust non resonated-carbonetic twin plate clutch-greddy oil cooler-new oem coilpacks-custom turbo hardlines-neo cam angle sensor
-----internals------full big ported head-port and polished-decked head-tomei cams type a 256/256-tomei valve springs type a-supertech racing valves-valve job-upgraded valve guide-decked block-hot tank-bore and hone-blueprint and balanced-micro polished crankshaft-JUN crank collar-cp forged pistons 86.5mm .020 over bore-eagle forged rods-apexi 1.1mm metal head gasket-arp main studs-arp head studs-full gasket rebuild kit-full acl race bearings-oem oil pump-n1 water pump-nismo thermostat
[img]http://i115.photobucket.com/albums/n281/otightitzjim
Modified by otightitzjim at 1:37 PM 4/28/2009
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Motor is coming together nicely, good stuff Jimmy.
On your way into the RBBA :D
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Looks Impressive! Now get 'er on the road!
(If you don't already have it, I have a Nismo T-stat I'll sell you cheap. Nothing wrong with it.)
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Can you please post a closer pic of the end of the crank that attaches to the flywheel? I am looking for the oil seal surface specifically.
240z4u
Car: '95 Nissan 240SX
Your photos make my brain hurt.. lol
You going to have the rotating assembly balanced as well?
Looking good man.
Evan
alexanderig
Car: S2000
looks like a good build
GIJOE69
Car: Going Side Ways!
wow very impressive...did it hurt your wallet for the labor?
WhatsADSM
Car: 1998 240sx
Looks really good, congrats.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
i like how he mentions the 1500 part on his intercooler specs............
huhu, huhuhu, huhuhu
otightitzjim
Car: S14 kouki baby
240z4u wrote:Your photos make my brain hurt.. lol
Looking good man.
Evan
hey sorry if they make your brain hurt. yes i will have the rotating assembly balanced as well. thanks btw.
otightitzjim
Car: S14 kouki baby
GIJOE69 wrote:wow very impressive...did it hurt your wallet for the labor?
yessir it hurt my wallet badly. but its worth it all in the end. thanks.
otightitzjim
Car: S14 kouki baby
thanks everyone for the positive comments. also a personal thanks to ricky from RAW BROKERAGE for his patience with me and his hook up on parts with great service and info, and the guys from G-DIMENSION. i really appreciate it. ill try to keep you guys updated. my engine should be getting blueprint and balanced as i type this. i will try to get engine bay pics soon.
Modified by otightitzjim at 7:28 PM 11/26/2008
otightitzjim
Car: S14 kouki baby
Darius wrote:Can you please post a closer pic of the end of the crank that attaches to the flywheel? I am looking for the oil seal surface specifically.
hey matt. im really sorry i cant get those pics for you. my engine is basically put together and getting balanced right now
RB24D
Car: 1996 rb25det 240
Lookin good Hopefully I will have mine done soon.Still waiting for pistons and rods to arrive .
Darius
Thats cool. It just looked like the crank had a good sized oil seal goove in it that could cause it to leak after u get it all put back together. There is a Speedi-Sleeve that u can get to solve the problem for cheap.
otightitzjim
Car: S14 kouki baby
hmm im going to have to look into that. thanks though for the heads up. heres some pics of it.
Modified by otightitzjim at 4:21 PM 11/27/2008
otightitzjim
Car: S14 kouki baby
gahhh the build is being held off until i receive my JUN crank collar. thanks once again to ricky from raw brokerage for providing me with it
otightitzjim
Car: S14 kouki baby
hey guys, my build is almost done. ill update everyone with pics. i just got my JUN crank collar and my crank is at the machine shop. hold tight....
otightitzjim
Car: S14 kouki baby
alright guys heres my update on the build. sorry for the lagg. let me know what you guys think.
also btw, does the clearance on the valve covers and the turbo with the 6boost manifold looks proper or normal? it sits really close. does anyone elses? its a t3 flange with the same gt3082r.
Modified by otightitzjim at 8:40 PM 12/10/2008
Modified by otightitzjim at 8:53 PM 12/10/2008
RB24D
Lookin real good what turbo is that still 30/ 82? What oil pump did you go for don't tell me you skimped on the most important part I have a n1 but now I am thinking of going with jun
otightitzjim
Car: S14 kouki baby
RB24D wrote:Lookin real good what turbo is that still 30/ 82? What oil pump did you go for don't tell me you skimped on the most important part I have a n1 but now I am thinking of going with jun
yeah same gt3082r. i went with an OEM non N1 oil pump. like you said, i wished i wouldve bought a better oil pump, but unfortunately, my funds are really low atm.
240z4u
Looks great man!
Just curious, will that exhaust housing being that close damage your paint (powdercoat) on the valve cover? Would be a real shame.
Keep it up.
Evan
otightitzjim
Car: S14 kouki baby
240z4u wrote:Looks great man!
Keep it up.
Evan
thanks man. well it sucks that i cant really do anything about it the ex housing. i emailed 6 boost to see what he would say, because im not not sure if i seen anyone on here with clearance isseues with the 6boost mani. but o well, funds hold me back and i cant do much now.
240z4u
Did you see the turbo blanket group buy? Should solve your problems and keep underhood temps down.
IMO, I would want that turbo right where it is for extra space for plumbing.
Evan
otightitzjim
Car: S14 kouki baby
240z4u wrote:Did you see the turbo blanket group buy? Should solve your problems and keep underhood temps down.
Evan
yeah i was thinkin about it, but i honestly dont think it would fit in between the valve covers and housing. the gap is probably 1/4-1/2 inch. true about plumbing, but i hope my valve covers dont get burnt
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
redonkulus I love a clean build.
Darius
Your build looks awesome! Thanks for posting the pics of the bolt end of the crank. It looks borderline and it might leak with a new seal on there. At this point you still may be able to get a speedi-sleeve on there. I think they're like $20 tops.
I am concerned with how close the exhaust housing sits to the valve cover. That paint is toast unless you ceramic coat and get the turbo blanket. I strongly recommend both because the ceramic coating will keep the heat from getting into the cast iron in the first place and the blanket is a physical barrier to the heat.
This also puts the source of heat that much closer to the coil packs, but that can be controlled by ceramic coating and putting a blanket on the turbo.
Keep the pics coming. It looks great!
l0nestar
2004 Toyota Altezza
More impressive!
Seriously, look into the turbo blanket. Did you powder-coat the lower timing cover? After seeing your engine pictures, it makes me wonder about the ALT bracket and PS pulley getting powder-coated now
Speaking of which, what 'color' powder did you use? a gloss black with heavy multi-colored flake?
Your build looks clean. Interested in seeing more of the car!
I wish I had spent some time detailing my engine, instead of focusing purely on function. Oh well. I guess that is what winter projects are for!
240z4u
Shiny slow cars are worthless Lonestar.. ask radianation on 240sxforums..
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
Wow, nice work. I gotta get one of those 6boost manifolds.
