My Detailed 2jz-gte/240sx swap
rb25crazy
Car: 1997 miata
omg, this is the secks... i love it! good job man your THEEE man
Steve2jz240
Car: 1989 Nissan 240sx coupe
rb25crazy wrote:omg, this is the secks... i love it! good job man your THEEE man
Thanks aolt man! im not done yet tho i believe i can get the speedo sinal from the ABS sensor on the rear diff, the coolant temp basically is just gonna hook right up.. drive shaft, shifter extension and im on the road im actually eager to see what kinda gas milage ill get.. its funny how simple the wiring was anyone who know how to read a wiring diagram can get it. Power to just one wire in the harness gives power to almost everything on the engine o2 sensor, injectors, map sensor, vac solonoids, ignitor i dont know if i get in some **** for posting a complet diagram of how to do without being hated because these guys are making $$$$$ on this and i just wanna give it away.. ****, its information, education **** it lets share... i remember when i called a perfomrance down there in savannah ga... whats his name DR. Tweek boy did he not wanna give me a clue on how to wire this thing he said "of course i want you to send it to me so i can do it" sorry dr tweek...lol
tu_bryan
Car: None =(
oh dear god im so inspired
RCA
Again Thanks for the fuel sys details..
But I know I would definitly be interested in how you did the harrness!Awesome job!
tu_bryan wrote:oh dear god im so inspired
You have NOOO idea!I have been saving for a JZ swap for about 2.5 years
Steve2jz240
[QUOTE=rcabrita]Again Thanks for the fuel sys details..
i dont know i your being serious or sarcastic.... there really was nothing to it i cut the fuel lines at the fire wall and ran long 5/16 goodyear fuel hose (rubber) from the right side of the car to the left. Stock fuel pump for now oh yeah and i jumped the fuel pump relay so that it comes on with a 12v switch(when i turn the key to the on position the pupm gets a constant 12v i take some more pics
RCA
Definitly not sarcasum.
I only have a slight knowlege of cars, so I wasn't sure if useing rubber lines was a good idea.
I have been told from a few people to flare hardlines and extend them to the other side of the S chassis.
After reading this thread you are like a hero to me.I have been looking into this swap for about 2.5 years and the only thing holding me back is money.So if I could save $500 because of wiring then to you sir!
And keep the pictures/updates comming!
ricanflava
Car: 1992 240SX SE COUPE
do you still have the coupe or did you sell it? Hit me up:[email protected]
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Steve2jz240 wrote: Stock fuel pump for now
Im sure you already know to up grade your fuel pump before running your motor. That pump will NOT flow the 300hp worth of fuel that the 2jz needs. It might work for start up but It's not worth blowing the motor.
Just lookin out!
silvia_ks_69
Car: 1990 Nissota Silpra
2017 Porsche Macan GTS
yeah but u could just pick up a walboro for >100$, lol unfortunately for me i had to up-upgrade to a denso but ya thats wut happens haha.
extension is just a fabbed up shifter with two 90 degree bends. but ya obviously it has to be longer.
RCA
^^ Yea I was gunna say a used JZ costs $2,xxx and a aftermarket fuel pump is $100 something...
So worth upgradeing
silvia_ks_69 wrote:yeah but u could just pick up a walboro for >100$, lol unfortunately for me i had to up-upgrade to a denso but ya thats wut happens haha.
Why? Doesnt the Walbro flow more then the Denso?Denso is stock on chassis' with JZ engines... right?
silvia_ks_69 wrote:extension is just a fabbed up shifter with two 90 degree bends. but ya obviously it has to be longer.
Yea can some one post the specs on the shifter extention?
Steve2jz240
Just lookin out!
cool thanks... It crossed my mind once or twice to keep the stock fuel pump untill i felt like upgrading but your the second person today to say the exact same thing.. so before it hits the pavement ill make the switch.. thank for info.
ricanflava wrote:do you still have the coupe or did you sell it? Hit me up:[email protected]
i actually sold it the same day i posted it sorry.. check out Craigslist.com to many 240's
Steve2jz240
got some pretty good updates today also... i took the driveshaft out of my 88 supra turbo and with that in hand plus the ka shaft i went to a place north of atlanta called driveline and for $200 there going to use the front portion of the supra shaft (just the head part that goes into the transmission).. one peice steel shaft(i think its aluminum) and i was going to use the stock KA rear yolk(the oppisited end of the shaft that bolts up to the Rear Diff, but the guys at driveline said it would probably fail so he recommend using the yolk from a q45.. he said its bigger and tougher and brand new.. Also he rated this particular shaft at or around 600hp.. for you guys that are going to use the mounts i did from the end of the shaft at the back of the transmission, to the very face of the diff is 46 and 1/4 inches exactlly that and the two shafts is all they needed... ill get it back tommorrow and post some pics of how it fits if i have time... im actually letting this project take up to much of my time and i gotta business to run so more that likley ill have to give it a rest for a few days to catch up on my work at the shop and these angry *** clients trippin about why their car's not ready yet.. "cause im workin on my **** Bit*hes just playin without them i'de be riding the damn bus/train/walking/bummin rides
Modified by Steve2jz240 at 8:45 PM 8/9/2008
silvia_ks_69
rcabrita wrote:^^ Yea I was gunna say a used JZ costs $2,xxx and a aftermarket fuel pump is $100 something...
So worth upgradeing
ya i can post a pic after work today. no walboro pumps kinda suck the d!ck when it comes to higher hp. i didnt buy the OEM denso pump its like the second tier and then the top tier is wut HKS uses to make there fuel pumps (i woulda got top but they were outta stock). they basically slap on a sticker and jack the price 200$.
RCA
silvia_ks_69 wrote:ya i can post a pic after work today.
^ Um you promissed shift linkage pictures! If you dont come through with those pictures "I'm going to take a pillowcase and fill it full of bars of soap and beat the **** out of you!"- Step Brothers
silvia_ks_69
haha i will man gotta be patient, came home from work yesterday and pretty much blacked out lol
Rellik27
Car: 240sx
hey quick question what radiator did you use the KA or something else?
everything looks awsome btw, and a write up on the wiring would kick *** lol
Kalypso
Steve2jz240 wrote:PLEASE SHOW ME HOW TO PUT BIGGER BETTER PICTURES HERE ON THIS FORUM
ok,
- go to photobucket.com- create an account, and login.- in the My albums page, select and upload all your pics at once. - copy and paste the IMG tags here,
try it
Kalypso
the video is looking dope, nice work!
I still dont understand the basics of a wiring diagram. wiring is my only vice
Steve2jz240
Rellik27 wrote:hey quick question what radiator did you use the KA or something else?
believe it or not i used a radiator from my wrecked 91 BMW 525i!!!! it fit almost perfect (with a little modifying the body of the car) it works sooo well that even in 95degree atlanta heat, NO RADIATOR FANS, and Rush hour traffic it stayed well below half... under 190degrees.. (no thermostat).....Oh yeah its running ok BTW i dont have the intercooler hooked up (running a str8 pipe from turbos to intake), transmission shifts perfect and suprisingly no weird vibration at 80mph on the hwy! so far its good.. it idles pretty good and died on me once on my way home but started right up.. also its running extremely rich (pumes of black smoke at WOT) but we'll give it some time and a little more work... you guys want some videos or whatever let me know and the wiring im not completly done with yet.. got the speedo, Tach and a few other bugs to work out before i feel comfortable sharing the wiring just give me some time
nissan789
hey did you join 240atlanta.com yet?
RCA
Steve2jz240 wrote:-believe it or not i used a radiator from my wrecked 91 BMW 525i!!!!
-95degree atlanta heat,
-NO RADIATOR FANS,
-i dont have the intercooler hooked up (running a str8 pipe from turbos to intake)
-died on me once on my way home
You are asking for trouble
Steve2jz240 wrote:also its running extremely rich (pumes of black smoke at WOT) but we'll give it some time and a little more work...
Maybe its oil?
Steve2jz240 wrote:you guys want some videos or whatever let me know and the wiring im not completly done with yet.. got the speedo, Tach and a few other bugs to work out before i feel comfortable sharing the wiring just give me some time
Awesome job with the wiring.
I am a wiring fool so try to make it "retard" proof. Emfasis on TRY!.
And yea the more picture and videos you post the better. You will never get a negative responce on here about the amount of pics or videos.Take pics of the current set-up and take pics of when it changes.
I am definitly following this thread A++ job! Keep it up
Modified by rcabrita at 12:07 PM 8/10/2008
Kalypso
it sounds like it was overheating...
tctomasc
Car: 95 240sx
Man i think once your done you might actually convince me to do this swap instead of an sr or an rb
leroiboy
Car: 1989 Nissan 240SX Coupe
well he had to do something after he blew up his built prelude being spanked by my infamous sr... good ish tho steve, u will get my buisiness when i pick up another 240.
Solow240sx
Car: sr20 powered 91 240sx
Looks like a good build...
ruckus-racing
well steve sounds like its goin good. but you need to get a cooler on that ****. those turbos do get hot and that air is almost as hot. as for the black smoke the other guy said oil. black is rich blue is oil. but someone else said they were leaning to this swap compared to sr or rb. i would lean to the jz series the power band and accel is bad ***. sr feels like a smaller jz. and i personally dont care much for the rb. i think next year i may build a second track car with another jz engine cause we moved to a sr. sorry for the thread jack steve
Kalypso
2jz been the ****, since day one
but please dont let it overheat
Steve2jz240
Kalypso123 wrote:2jz been the ****, since day one
I wont man i promise!!
ruckus-racing wrote:well steve sounds like its goin good. but you need to get a cooler on that ****. those turbos do get hot and that air is almost as hot. as for the black smoke the other guy said oil. black is rich blue is oil. but someone else said they were leaning to this swap compared to sr or rb. i would lean to the jz series the power band and accel is bad ***. sr feels like a smaller jz. and i personally dont care much for the rb. i think next year i may build a second track car with another jz engine cause we moved to a sr. sorry for the thread jack steve
yeah Cody, its REALLY GOOD.. Man does this car move!!!! i mean in stock for at 10psi this thing feels like a rocket and it seems like it wants more.. im really not used to running a car hard and then having it idle like a new lexus! my built honda prelude made 340/275 on 12psi and would not idle with the 880cc injectors so this is completley new to me..
UPDATE: well as you may already know i've got everything together intercooler, rad fan, boost gauge, most of the little kinks worked out and im soooo impressed. its funny because i seem to have little boost in 1st gear maybe like 5psi but once i throw it in second its almost to much to handle!!! i get a **** load of boost creep (i dont think my wastegates are opening) but i do a pretty good job regulating boost with the gas pedal so i usually keep it a or around 10~psi.. also the motor does not move at all the mounts are a work of art and i believe it makes no sense to get them anywhere else but from Cody(Ruckus Racing)!!call him 937-520-0284 The guy is great and customer service is A++ he was actually walking me thru some things on the phone with his babys crying in the background!! Thats devotion Thanks man! Hoods going on when i steal some more time from myself.
Steve2jz240
leroiboy wrote: spanked by my infamous sr...
LOL! come holla at me now!
skott.b
Car: 91 S13 ka-t
looking and sounding good. cant wait to see more pics and vids homie.
