My Detailed 2jz-gte/240sx swap
RCA
Kalypso123 wrote:post more pics with more step by step details.
+1 for that...
Kalypso123 you are going to email me about how you did your signiture....
Right?[email protected]
nissan789
hey did you sign up on 240atl yet? sorry i wasnt bashing its just that the more members the better on there and makes the 240 community in 240 cooler man. werd. you can get informed in driftevents have at least one a month, meets, get togethers, parts you need, (great deals), get to know people, sell things, etc, etc all locally. btw im carlova78 on there. thers a bunch of cool people who know there stuff.check it. zenki cam on here is also on there
Rellik27
Car: 240sx
very nice bro hopefully ill start mine soon
greddy2die
+1 for more pics
cwtt
Car: 95 Twin Turbo Supra
Good luck with your swap! You do realize that is an Aristo motor, not a Supra motor right?
There are differences (turbos, injectors, cams, oil pan, water pump etc)
RCA
cwtt wrote:Good luck with your swap! You do realize that is an Aristo motor, not a Supra motor right?
The differences you posted has less to do with one is an Aristo engine and one is a Supra engine and more to do with Aristos are only available in the JDM and the Supra 2JZ is available in both USDM and JDM.
Both JDM 2JZs (Supra & Aristo) have smaller turbos, injectors, cams then the USDM 2JZs (Supra & GS300).
But oil pans and water pump is diffrent between the Supra and Aristo/GS300.
Or am I wrong...? I am no expert but have done some research.
Steve2jz240
Car: 1989 Nissan 240sx coupe
Updates on the way guys sorry i took so long....
silvia_ks_69
Car: 1990 Nissota Silpra
2017 Porsche Macan GTS
hey man. good to see another 2J swapper on here. this is a big project ur undertaking as ive found out over the last little while and especially today when i got quotes for hooking everything up in the bay and wiring in the standalone. i dunno wut ur plans are for power wise/application but if u plan on upgrading to make some substantial numbers like mine (500whp) then ur budget might as well be doubled. im not tryin to scare u or anything but ya it sucks when u run outta money and ur car is still on stands. trust me. anywayz welcome and ill be followin ur build so do it up right
Steve2jz240
Here are some shots of the mount brackets on the motor
US spec water pump..
Thanks Driftmotion......
Thanks again DM!...
and i gotta smokin deal on the r154 transmission try $250 with a 90day warranty(car had 108k on the dash and shifted fine).. im sorry for my pretty long absense its just been hetic here at the shop but ill be droppin it in when i get my last two flywheel bolts and my clutch
Steve2jz240
silvia_ks_69 wrote:hey man. good to see another 2J swapper on here. this is a big project ur undertaking as ive found out over the last little while and especially today when i got quotes for hooking everything up in the bay and wiring in the standalone. i dunno wut ur plans are for power wise/application but if u plan on upgrading to make some substantial numbers like mine (500whp) then ur budget might as well be doubled. im not tryin to scare u or anything but ya it sucks when u run outta money and ur car is still on stands. trust me. anywayz welcome and ill be followin ur build so do it up right
Doubled? maybe. Im not buying the $500 "600hp" intercooler, or the hks ssq blow off, or the $400 radiator, or have an expensivie *** performance shop do all the work. all work will be done here at my shop with quality parts for under 6k and that includes the car... heres a quick run down of what i've maped out as far as cost for this project1. car-$5002. motor set-$18003. r154 transmission $2504. 1j bellhousing and flywheel $8005. wiring free6. timing belt water pump misc seals $200(like 212.00 from dealership i already have everything)7. rukus racing mounts $2258. custom driveshaft $3509. j30 rear diff- free (have a j30 in the back of the shop for parts)10. intercooler, piping, blow off valve $300 (give or take $100 probably give)11. clutch line, rad hoses, fuel lines, flywheel bolts $10012. stage 2 clutch $35013. and we'll say $500 for any other misc. things that i left out. keep in mind this is just to get it in the car running with the stock twins which is a total of $5375.00.. thats really not all that bad its only outragously expensive if someone else is doing the work. And when i decide to upgrade and go for higher numbers im looking at about $4000 which almost half of that is going to the turbo itself adding only another 1k if i decide to buid the block.. if you account for everything you'll have no suprises! im pretty prepared trust me thanks for the heads up tho i just wanna have a lil fun, show it off, sell it down the road and move on to something else
Kalypso
its less expensive then people say
when you're done post your total costs, even if it cost 20k
rcabrita wrote:+1 for that...
email you about how I did my signature? which onethis one? this is a 3d model I made in Maya 8.0 and rendered in mental ray
RCA
^ hahaI would check the date on that post, it is definitly stale.
You were using a picture of your S13 and it had a cool blurry effect.But it doesn't matter now I don't even use a picture in my sig.
Keep the updates comming!
Steve2jz240
Well, i had some free time today so i went ahead got some things done with the ride
its funny how the clutch and pressure plate work. its so much different than the traditional way of bolting the pressure plate and clutch to the flywheel and then trying to wiggle the transmission on straight.
engine bay almost clean.. i really wanna try to make this swap look clean as possible.. i want to paint the valve cover and timing cover just dont what color will match with the brown..
i scored a pretty big battery from a 08 Mercedes so ill probably throw that in the trunk
BY BY KA!
sorry about the small *** pictures im used to using tinypic and for some reason it wont work with my new apple. overall my day was pretty good... i met a really cool guy down here in atlanta at Kill Switch performance (Decker) great guy. he has a 2j in his 240 and was eager to show it to me and give me his advice on the swap and wiring.... That you really dont find much here in atlanta, most are so arrogent, rich with mom and pops money and dont wanna share ****. What i have learned is that usually if someone works hard for $$ and puts alot of time and sweat in something they wont have any problems sharing their ideas and accomplishments (sorry cant spell tonight) ya know.. happy to help type of people.. i like those.. anyways let me know if there are any specific pic you guys want or whatever..
datsun2401972
Car: 90 Nissan 240SX XE coupe
Steve2jz240 wrote:That you really dont find much here in atlanta, most are so arrogent, rich with mom and pops money and dont wanna share ****.
Probably because they will sound stupid after you realize they don't really know **** about it....cause they didn't do it themselves.
GL with the swap, hope it turns out how you want it to.
RCA
Steve2jz240 wrote:anyways let me know if there are any specific pic you guys want or whatever..
My request is that you cover the fuel system and battery relocation.I am not sure how I will end up doing my fuel lines and also I want to know about the batt. setup.
Thanks allot and to you sir
xpicer
Car: 1990 nissan 240sx
bro im not sure but i think you migth be forgetting a mufler, and lil misc things here and there , coolant , oil ........
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I would like to know more about the clutch system and how it bolts up. Is that fly wheel slotted? The nickel and dime $h!+ is what killed my budget! Looks good, Keep it going!
Steve2jz240
xpicer wrote:bro im not sure but i think you migth be forgetting a mufler, and lil misc things here and there , coolant , oil ........
naw not forgotten at all. Exhuast is not expensive at all i actually own a snap on welding machine just not very good a welding. The shop next to ours does all of our exhuast work, cat convertors, mufflers, and such for a custom straignt 3in from the downpipe back will run me $125 (not stainless steel) minus the muffler so your right i did miss that. and i've got 2 50gallon drums of antifreeze and several 50gallon drums of oil i really think i covered most of everything little nic naks i can pick up at autozone and then we have a commerical account with them so 30percent is our discount
Steve2jz240
rcabrita wrote:My request is that you cover the fuel system and battery relocation.I am not sure how I will end up doing my fuel lines and also I want to know about the batt. setup.
No problem that what i was going to tackle today the fuel system shouldn't be to bad i believe i just have to relocate the filter to the oppisite side of the car and for the battery just run.... i can show u better than i can tell u.. thanks for checking in tho!
RCA
No problem
I am gunna guess that the filter relocation is nessasary, but I haven't ever heard of needing to move it.
Can't wait to see the updates!
silvia_ks_69
well ya thats the thing u can budget pretty well if u keep it basic. but like i went top of the line with alot of parts to try and reach the numbers that im going for and ya somehow the budget is no longer in existence, when u start doing that it becomes very hard to account for everything because misc. things add up very quickly. dude if u kno wut ur doin then more power to u man. i wish i had as much knowledge as most of the guys doing this swap cuz it would save alot of money and it would be a little more satisfaction of knowing i did all or almost all of the work myself....but wut can u do, im learning. newayz keep it real look forward to updates
Steve2jz240
wel im not going to sit here and lie because i do have doubts about keeping my budget i got so many misc. things, hoses, brackets, filters, electrical wires, bolts here around the shop i should be ok for the most part.i see you guys concern tho.. UPDATE: well today and yesterday were pretty damn rough and busy. The engine came out ok as usual but installing that monster engine was a ***** no doubt (i was told it was going to be).. i mean it really took some work but the finished product was quite nice.. it sits as far back as possibe not allowing use of the heater core's bottom hose.. i was also told that it would be hell trying to work on the engine while its in the engine bay but you would be suprised at the amount of room i still have to work.. here are a few pictures of how i relocated the fuel filter and the picture of the cables are battery cables for my bmw525i (that battery is in the trunk and basically i just ripped the cables out and used them)
...and the wiring..... i've got it to turn over, got constant fuel pressure(12v switched to fuel pump relay) i really want to get the fuel pump to work like it should and cut off when the engine stops and not when i turn the key off, i've also got power to all the engine components ignitor, map, o2 sensor, basically everything on the engine.. i've also semi wired up the ecu and got signals from the crank and cam sensors.. the reason i believe i have signal from them is because im getting injector pulse on all six of the injectors while crankin the engine.. all i need now is an ignitor and well just go from there.... im expecting some suprises tho because this has been way to easy so far. I'll aslo get you guys some pictures of how fuc**ing far foward the transmissin gear shifter hole sits thing continue to roll tomorrow.PLEASE SHOW ME HOW TO PUT BIGGER BETTER PICTURES HERE ON THIS FORUM
supreamS14
I use my myspace to post pics and they come out as big as they are. I also crop them with paint when they are too big.
Again could you shine some light on how the clutch bolts up as you said that it dont go on the most common way?
Steve2jz240
supreamS14 wrote:I use my myspace to post pics and they come out as big as they are. I also crop them with paint when they are too big.
well its like this... the flywheel stays on the engine just as normal but you dont bolt anything to it without the transmission being bolted to the engine.. what you do is while the transmission is off you slide the pressure plate onto the output shaft of the transmission like thisthe pressure plate is held onto a tubelar shaft via a snap ring that acts in cojunction with the clutch slave cylinder. its alot easier to understand when its in your face. next you simply slide the clutch disc onto the shaft as far back as it will go. then take and bolt up the transmission to the engine. once thats done there is a big hole in the side of the transmission bellhousing, thru that hold you have to line up the holes on the pressure plate to the flywheel im going to find you a pretty good diagram too
silvia_ks_69
use photobucket that will work better. yeah the transmission was kinda tricky to hook everything up.
RCA
Thanks for the extra fuel documentation...
What did you use to clamp the rubber lines from your fuel line (pressure line) to your fuel filter?
What type of rubber line did you use (techniquial name)?
Shouldn't pressure lines by hard lines instead of rubber?
silvia_ks_69
the only way the shifter setup is gunna change is if u push the engine back as FAR as it will go, cut out the firewall or make an extension on ur shifter which is wut i did.
Steve2jz240
well i didn't really do anything much to the way the fuel is set up.. i just cut both the hard lines (return and flow) and used 5/16 goodyear rubber fuel hose from autozone.. thats what come on most nissan after the filter anyways i'll upgrade later.. as for the hose clamps i just used regular hose clamps the small ones that dont have the tiny gaps inbetween(OEM nissan ones) and in most cars domestic or import there are portions of the fuel line that are rubber so i saw no problem with the use of mine for the time being.
silvia_ks_69 wrote:the only way the shifter setup is gunna change is if u push the engine back as FAR as it will go, cut out the firewall or make an extension on ur shifter which is wut i did.
how did u make your extension?
Steve2jz240
UPDATE:
IT RUNS SOUNDS GREAT AND WAS A PEICE OF CAKE TO WIRE SIMPLY SIMPLE VIDEO UP IN JUST A FEW
Steve2jz240
