i30krabb »
https://forums.nicoclub.com/i30krabb-u36755.html
Sun Feb 19, 2006 11:05 pm
Hi guys,
Actually I've been around for a long time and communicated with Dr. Rex about 4 or 5 years ago. I haven't been around much lately but I'm back!
I live in las vegas and own a 1996 infiniti i30 platinum pearl white with an auto transmission.
My i30t is very heavyly modified and put out 400 fwhp at JWT a few years ago. I'm ready to go back in a few months and shoot for 420 fwhp or better.
I only use mods that improve speed or performance, no fancy lights, body kits, or crazy ICE.The mod list is too long and I'll probably forget some but here goes;-Rebuilt motor (9:1 compression) with new pistons, valve springs, retainers from the vq30det motor, shot peaned connecting rods, JWT cam shafts, 5th gen oil pump, extrude honed upper and lower intake manifolds, 370 injectors, walbro hot wired 255 in tank fuel pump, nismo fpr, ported & polished & gasket matched intake & exhaust manifolds, 300zx mass air sensor, stillen modified super charger and vortech air to water aftercooler with 14 lbs boost, JWT dry n2o kit with 75 shot, Jwt reprogrammed ecu, aquamist water injection, oil catch can with 30 lb PCV valve, engine oil cooler with relocated i qt oil filter, custom exhaust with down pipe and an electric cut out valve that gives a full 3" dump to the passenger side, custom griffin aluminum radiator, battery relocated to trunk with emergency alternator & battery shut off, JIC FLTA2s full coilovers, front brembo big brake kit with SS lines , volk t37 racing wheels, traction bars, stage 2 lower tie bar connectors, front & back strut tower braces, rear sway bar, energy suspension polyurethane bushings including motor mounts, fully modified auto transmission with upgraded valve body, gears, torque convertor and final gear ratio with external oil cooler & filter, mechanical & electric steering rack with adjustable pressure switch, full array of necessary autometer gauges, custom made electrical panel with relays and fuses for all aftermarket addons, 6 point custom roll bar with padding to match interior, schroth 4 point harnesses, fire extinguisher system for engine bay, That is what I can remember. I'm waiting to get some drag radials to go to the track because the last time i went I couldn't hook up!
