You should contact Aries, who is a member here on NICO, from what I've heard it's definetly not a straight drop in, and you will definetly need a couple extra thousand dollars just for extra misc. stuff.midnightclubbaa wrote:well from what i heard it's straight drop in all ya need is GTO oil pan and custom motor mounts
so far we've spent 950 on the chassis and about 4000 on the motorset(i think)
didn't mean to sound like an *** if i did
i thought it sounded fishy2BN_S13 wrote:
OMG please! Stop! Youre killing me!What exactly about wiring, transmission placement, custom driveshaft, custom mounts, etc sounds like a "straight drop in"? You are so funny!
...seriously, its alot of work.
seeing as the rb is something like 100 pounds more i find that most amusingmidnightclubbaa wrote:it's not heavy enough to matter
i think it's like 15 pounds heavier than the SR
are you ****ing kidding, i bet an ls1 longblock weighs at least 150-200lbs more than an srmidnightclubbaa wrote:it's not heavy enough to matter
yeah its aluminum, so is the sr. only the sr is about 1/3 the size. intercooler, maybe 20lbs(depends on size), pipes maybe another 5lbs, and one turbo manifold and a turbo might weigh 5-10lbs more than both the exhaust manifolds on an ls1.frapjap wrote:If only it did. The LS is alluminum, and when you go to really work on that SR and put a fmic, piping, turbo, and other accessories (oilcooler, transmission cooler,etc), you're adding another 150-200 lbs anyway. Plus, can your SR make 300hp N/A? Its a lot of work, I myself would like to take an older 302 and make it work in the 240, but the time and money that it takes to do...well I'll start saving for the 2008 Corvette or soemthing.
s2000s are made for auto xing and road racing...last time i checked its actually fairly hard to make one a good drift car, kind of like the older mr2smidnightclubbaa wrote:well he had a s2000 before so i guess drag and drift
and maybe a little but not alot of autox ing
