Damn you Irony. Is nothing safe from your touch?Dookie wrote:think of the possibilities of mispelling!
Hey, factory HP numbers are just averages of test engines. Real ones will actually perform higher or lower, hovering around the factory spec. It COULD happen that you get the one magic motorspanishricer wrote:We were referring to "whp" or horsepower measured at the wheels. The numbers you quoted are manufacturer rated horsepower numbers, not the same thing.
A car rated at 305hp from the factory, should roughly put down around 265-ish whp. But many LS1's put down around 280-290whp stock. The highest I've seen a stock LS1 dyno was the Firebird Formula I mentioned earlier that put down 304whp.
An LS1 without C5 internals that's putting down over 340whp completely stock isn't a factory freak motor....it's a factory Act of God motor
ok well it's domestic guy stock (lid and exhaust) (basically intake and exhaust)spanishricer wrote:
but then you wouldnt be driving a 240sx now would you... plus the cost would be ridiculous times more if you were to do that.flyboy367 wrote: id even go as far to say your probably better off getting a ws6 trans am frame, or a lighter vette frame and working off that. good luck
in that case, a full front clip would be very helpful. BTW, if you want to keep your poer steering you will be needing a GTO oil pan and pil pump pickupj-z wrote:no no no. i was talking about when i get the motor... as in order a complete front clip. that way i would have everything i would need all in one place and not have to search for misc ****. i would never ever think of doing that even though i am a master body technician. you all will be seeing either an ls1 or a lt1 in my car at the end of summer. i want the ls1 if i can get a clip for a good deal. i cant wait
Do it and you will have a definite customer outta me!Aries wrote:DIE THREAD DIE?
LOL.
Seems there is still a lot of interest in this.I could be convinced possibly to start producing the kits again.
Correct, to clear the opwer steeing plugs in the rack, and allow proper submersion of the oil pump, the LS1 has to be set about 5 inches forward. This makes for a very tight squeese between the bell (waterpump) and the radiator. The other option is setting the motor higher up in the engine bay and putting a 2-3" cowl hood on. But then its not a sleeper.Chingon wrote:Aries, one question. I've seen the ls1 in an s14, and to tell you the truth, it seemed really far forward. I don't know if it was a perspective thing or what not, but I thought you'd have better off-hand experience on the placement of the thing. In the rx7 I posted earlier, the ls1 sits really far back, almost in line with the strut towers.
a/c can be kept with some creative plumbing to keep the lines out of the wayj-z wrote:thanks for the tip. any other helpful pointers like that i should know of? is it possible to still keep the a/c? im pretty sure you can. i just want to make sure...
My other car has an LS1 with LS6 intake. Good motor, very powerful, tends to drink oil, has some cold start knocking issues (piston slap). transmission is a T-56, same as Viper but with different synchros. The weak link in the driveline is the 10 bolt Zexel-Torsen rear end, definitely think about a 12 bolt Moser or Ford 9" if you're going to do the swap.j-z wrote:no no no. i was talking about when i get the motor... as in order a complete front clip. that way i would have everything i would need all in one place and not have to search for misc ****. i would never ever think of doing that even though i am a master body technician. you all will be seeing either an ls1 or a lt1 in my car at the end of summer. i want the ls1 if i can get a clip for a good deal. i cant wait
yep.RS210 in mine. 8.93" and when properly assembled, nearly indestructable. The last one I broke broke only the ring gear.Chingon wrote:a z32 tt r230 vlsd, which is probably easier to work with, and is almost 9". Not many gear options though.
