as a person that works on cars for a living i feel for you there... there are alot of different unneccesary things designed into cars for no reasonkouki munster wrote:The ecu plug has to make a tight turn right at the hole in the firewall, and it is a lot easier to get the plug to make that turn with out the abs pump blocking your view and taking up space your hands need to work.
You're just pulling the engine harness, on non-abs cars there is only one thing to make it difficult, there is a little clip( I hope there is a special place in hell for the little Japanese engineer that thought that clip was a good idea) that holds the harness to the firewall behind the air box, I just wedge a flathead against the clip and give it a couple of hits to break it. On abs cars you have that clip but you also have to haggle with the abs pump for space to pull the harness.
oh come on!! ill pay shipping both ways. does your car have an open diff?Lonismos14 wrote:If you come to ga and take all of that off sure. But i am to damn lazy to take all of that off.
Oh, sorry.. Yes i did. But I kept the upper belt connected to the cam pulleys. How you might ask? lol I zip tied the belt to each cam pulley. 2 per cam towards the top so they wouldnt jump teeth.Lonismos14 wrote:So did you?Lonismos14 wrote:Hey when you changed the water pump did you have to take the timing belt off?
Lol. I don't think I've ever seen those words said on this forum... You are my hero!Hoffman5982 wrote:, so I decided to make do with an sr. Im not too happy about it, but I think the sr will be plenty for now.
ThanxHoffman5982 wrote:that engine looks awesome. Make sure you clean the rest of the block up and paint the engine bay to set it off real nice. I was going to go with an rb25, but After thinking about it, Im going off to college in the fall and I need an engine thats easy to source parts and gets great gas mileage, so I decided to make do with an sr. Im not too happy about it, but I think the sr will be plenty for now. Take your time with this swap. What I was going to do with the rb, and still doing with the sr, is getting a master gasket set, oil pump, etc and pretty much do a mild rebuild. better to spend the money before hand than have it mess up afterwards and be stuck without a car again.
Just a suggestion. Good luck bro
Thank you very much sir... That b**** was tucked all the way up there.kouki munster wrote:There is a clip behind the air box a couple inches down from where the harness comes through the firewall, use a flat head screw driver and just break that clip with a little force. Its kind of hard to see, the easiest way to get to it is to slide the seat all the way back and get in the seat upside down and slid your head under the dash.
you'd be surprised... at the nissan dealer we never touched anytihng except graymotoman399 wrote:anything but a nasty color was my point. and i dont think your going to have to worry about the aluminum parts heating and cooling THAT much. maybe on something that is really thin but not on a water pump or intake mani ect.
lol well i have like 4 tubes of the black RTV in my tool box so i've been trying to use them up... the red stuff is good for sealing exhaust leaksmotoman399 wrote:thats weird ive only used ultra black and never had a problem, ever. not saying your wrong, just saying i dont think that is the ONLY one you can use. you know.
