I feel as though this needs to be updated as it is long over due.
I did some suspension and brake work on the front end of the car.
NEW OEM NISSAN FRONT LOWER CONTROL ARMS
NISMO POWER BRACE
SPL TITANIUM TENSION RODS
DIF STAINLESS BRAKE LINES
INFINITI Q45 CALIPERS
EBC SENTRA ROTORS
O'REILLYS GOLD PADS (for now)
HAWK HPS
With the MAP ECU 2 long gone it was time to make the car run on the AEM EMS V2, after some tweeking and adjustments the car was ready to go down to Sound Performance for the tune.
The temperature outside was 96 degrees with a humidity in the high 60's when the car was strapped to the dyno, So needless to say i wasn't expecting much. A few hours later after a few pulls and a couple of mishaps and issues. the car got to 400rwhp on 14psi only being able to rev the motor to the 5800-6000rpm are due to a fuel pressure drop. (Wiring to the fuel pump needs to be upgraded) For the temperature, the low boost and the higher stalled automatic that is in the car i am pretty pleased with the setup.
Took the car to a local car show a couple weeks later
Drove the car some that summer (2012) had a few issued with the wiring Tech2 did to the car. Which caused us to redo a few things to get the car back running. Also noticed a small oil leak from the oil return line, guh. always something right?
Here are some pics of the car throughout the summer/fall of 2012.
we ended up selling the Megan street coilovers and picked up some HKS HyperMax RS coilovers
We parked the car shortly after getting the coilovers on the car for the 2012/2013 winter.
Decided it was time to get rid of the noisy water pump, figured get a new timing belt well i was in there as well as a new tensioner.
Got that back together and decided to tackle a little wiring job to clean it up a little bit.
With the radiator removed i massaged the upper core support to gain a little more room. But i didn't want to make a big cut cause i hate how that looks.
Also got one of these!
Figured a new strut bar was in order, Picked up the GT-SPEC bar.
Also thought it was time for a wheel upgrade! Stich Mesh 17x8+35 (f) 17x9+35 (r)
In March of 2013 this happened.
Then we built this.
Out with the old in, In with the new.
While the wheels were painted we had the spark plug cover,and strut bar ends as well as the new velocity stack painted to match.
Got the interior pretty much finished.
Took the car out and did some cruising around.
Car developed a misfire so we redid the coilpack connectors.
and picked up a clean low mile set of uncracked coilpacks, as these were toast.
With the car back up and running i decided to straighten the garage and found this!
Went to a meet and had a friend take some more shots.
did so more cruising around with some friends.
had a friend take some shots of the car before we put it away for the winter.
Mod list:
1989 Nissan 240sx Coupe XE
19,000 Original miles
2JZ-GTE Aristo swap
MKIV Supra (USDM) camshafts
Tech2 Motorsports swap kit
Precision 6266 .68A/r T4 turbo
AEM EMS Version 2 standalone
Fuel Injector Clinic 750CC injectors, -6AN fuel rail
Aeromotive FPR
Red Horse racing fuel lines and fittings
Deatchwerks DW300 fuel pump
Godspeed Intercooler
Custom 2.5” Intercooler piping
Tial 38mm Wastegate
Tial Blow off valve
Treadstone Turbo manifold
CX Racing downpipe
Megan OE Type II “cat back”
Titan 3500 Stall converter
Speedhut custom speedometer and Tachometer
Axis Racing custom gauge cluster
Axis Racing custom center gauge panel.
AEM Digital gauges (Wideband,Oil temp, Trans temp, Oil pressure, Oil Temperature)
GFB E-Force II Boost controller
Silvia S13 front end conversion
SuperMade Instant Gentleman body kit
Origin trunk spoiler
17x8 + 35 235/40/17
17x9 + 35 275/40/17 Mickey Thompson Drag Radials
The car has had a variety of coilovers, from Megan street’s to the HKS Hypermax, Now the car will be riding on ISC Streets.
Megan traction and RUCA
SPL Tension Rods
Tein inner and outter tie rods
Silvia S13 VLSD
Clocks Off Racing 6-Point NHRA roll cage
S14 SE front seats
RJS Pink harness
Cruise Pink shift knob
Yashio Factory E brake button
Big End Pink steering wheel
NRG Short hub and V.2 Quick Release
Factory huds up display
and lots lots lots lots more
