No its not the bolts.Its the tolerances between the inner hub and outer gear.Doesn't matter if you crazy glued them.It will just wear down the aluminum on the inner hub from vibration and then you will have to play the tightening game with it.mello88 wrote:Haven't ran them yet... I put the bolts on there with loctite. They seem tight tolerance, they don't move around turning the motor over by hand but I guess we'll see
