LED conversion
DaleHeller
Car: 07 M35, Obsidian Black
Yes, V-leds.com has them in white, blue or purple. They are the H11 (non-HID) and plug right in.
It is a job to replace them, best way is through the wheel well. Took me about an hour to do both sides.
choochmpls
can you detail all of the interior LED light swaps?
LLJes1
Car: '06 Graphite M35X
has everyone used the "white" colored led's or the blue? i was looking for some help before i ordered all the replacement bulbs for my car...
ajgsport7
Car: Infinti M35 Sport
The link for the "front driving light" doesnt seem right....
I need to order these front driving lights Today! could someone please give me the link or model # for v-leds "front driving light" i ordered the 14 led but heard they get too hot. Now im thinking of the 27 led but not sure
Can someone please help me choose which ones i should get and give me a link! thanx
ajgsport7
Odie what was the model # for the "front driving lights" and "license plate" lights you used. They look amazing!
M45Owner
I can't seem to find these on vleds:194_27_SMT_W for front “parking” lights
Anyone know where I can get them or what an alternative would be?
mcp6530
Car: 2006 M35x Navitech
infinitiandbeyond wrote:Carlito and gteclipse,
The heat issue was a combination of the particular location AND that the 14-led was a “high power” 5watt. However, these work perfect for backup lights.
http://www.vleds.com
194_HP2_W for license plate
921_14_HP_W Rear Backup Lights
That license plate part number you gave gives two options. One says 5k the other doesnt' say anything, which one do most of you get??
infinitiandbeyond
Car: 2007 M35x
ATTENTION ALL FRONT PARKING LIGHTS....
I first tried the 14's, skipped the 27's and have now ordered THESE which V-Leds recommends as replacement...
http://www.v-leds.com/Exterior....html
mcp6530
What is a front parking light? I get so confused with all the diff't names!
Front Headlights.Front High Beams.Front Fog Lights.
and we all call them diff't things!
Translation please!
Does anyone have pics of the HID conversion for the fog lights?
rocastro71
Car: 2008 Infiniti M35S
Here are pics of my HID conversion. I will take a better picture on the HID fog at night and post it next time.Here's the kit I used:
Here's the difference: The driver side fog is HID and the passenger side is stock filament bulb. :
mcp6530
Great pics! Now, where do we get those s[QUOTE=rocastro71]Here are pics of my HID conversion. I will take a better picture on the HID fog at night and post it next time.Here's the kit I used:
Here's the difference: The driver side fog is HID and the passenger side is stock filament bulb. :[/QUOTE
Great pics! now where do I get those suckers from??
rsg123
Car: 2006 M45 Sport
rocastro71 wrote:Here are pics of my HID conversion. I will take a better picture on the HID fog at night and post it next time.
How difficult is this to install? Any rewiring needed?
rsg123
Car: 2006 M45 Sport
Has anyone changed their rear turn signals to LED? If so, please share details, like which bulb you used and if a resistor/load equalizer was used.
rocastro71
No rewiring needed, it's pure plug and play. The instillation took me less than an hour on both. Took four revits under the hood on each side and also took out the black plastic housing of the fog light. Then I unscrewed the metal fog light housing then basically installed the bulb and plug all wirings per the instruction manual. Then tricky part was the mounting of the ballast. There are like 3 holes on the driver side that you can use to mount them. On the passenger side, it's a little difficult because the area is very tight. I ended up mounting it on the front bumper area inside the fog light housing.
I got the kit from ebay. I read a lot about HID kits and the only one I can trust of is the Philips kit. I bought a cheaper one but I returned it because I read a lot about chinese made kits and they could burn your bulb housing. I paid about $195 for the kit. They sell around $190+ to $300+. Here's the link: http://cgi.ebay.com/ebaymotors...witem=.
rsg123
Car: 2006 M45 Sport
I am looking into replacing the rear turn signal with LEDs so the turn signal doesn't look so odd with the rest of the LEDs back there.Is there a flasher like the one above in our cars that can be replaced with one for LEDs (higher resistance) so the turn signal flashes at a normal rate?
rsg123
Car: 2006 M45 Sport
Does anyone know if our Ms have the flasher listed under Nissan on this site:http://autolumination.com/equalizers.htmA plug and play solution would be great.
rottweilers999
whats
SunLitSandMax00SE wrote:Got mine in and fell in love at first sight
whats the exact model for the license plate light? on the website they have a 5000k rate which is similar to the lexus ones.. is that the one you got?
WillV
Car: 2006 M35 Moonlight White/Tan Interior
rsg123 wrote:Does anyone know if our Ms have the flasher listed under Nissan on this site:http://autolumination.com/equalizers.htmA plug and play solution would be great.
Sorry for reviving the old thread, but I have my LED turn signal lights shipping! Does anyone know if we do indeed have a compound flasher unit that is removable and replaceable? I have found a FSM looking diagram for the G37 that shows where it is, and I would assume it would be in the same spot/very close? I would rather not do 4 resistors, but go this route. If nobody has looked or done it, maybe I will try. Or does someone know if the signal is controlled by the BCM?
