LED conversion
Fafdawg
Car: 2001 Infiniti QX4 4x4 (Silver) & 2006 M35X AWD With Tech package. (Blk on Blk)
Yah, I like yours better...
Huy
Car: M45
My leds (Lic. Plate) should be in any day now.
Any pointers for an easy install?
pmtran16
Car: Infiniti M45
Huy wrote:My leds (Lic. Plate) should be in any day now.
Its pretty easy to do. Just take out the plastic pins to remove the trunk lid panel covering the license plate bulb and just a twist and pull off the license light plugs. Keep in mind that LED bulbs, unlike regular bulbs, there is a positive and negative side. If you put the bulb in and the light doesn't work, try rotating it before you return it.
pmtran16
Car: Infiniti M45
Fafdawg wrote:Yah, I like yours better...
Didn't you order the same bulbs that I did...from v-LED.com?
SunLitSandMax00SE
Car: Silver 2006 Infiniti M35
Just got mine put in today and looking god so far, but I'm going to wait till it's dark to take pix. All is left is my driving LEDs that are on the way
SunLitSandMax00SE
Got mine in and fell in love at first sight
pmtran16
Car: Infiniti M45
SunLitSandMax00SE, Your lights look nice, did you get the single white LED or did you get more cause your lights look really bright. Either way looks good
Fafdawg
pmtran16
Here is 5 LED at dark... [IMG][/IMG]
pmtran16
Car: Infiniti M45
Looks good....HMMMM 5 LEDs....tempting
I'm good with my single LED for now
paigoomein
these should work for the backup lights too, right?
http://www.v-leds.com/Shop/Con...32481
pmtran16, with the 6-led for the back-up lights, do you already find those to be brighter than the oem bulbs? my windows are tinted pretty dark so having a brighter backup-light would actually help quite a bit when I am parking.
Modified by paigoomein at 12:36 PM 11/5/2008
SunLitSandMax00SE
pmtran16 wrote:SunLitSandMax00SE, Your lights look nice, did you get the single white LED or did you get more cause your lights look really bright. Either way looks good
I just got the normal bulb that was listed in the links given out
pmtran16
Car: Infiniti M45
paigoomein wrote:these should work for the backup lights too, right?
Yeah those are the ones that I used for the reverse lights. They look really nice but they really dont make a big difference in brightness. You might want to get brighter bulbs for that.
SammyTheBull
Car: 2006 M35 Sport
pmtran16 wrote:Just did a couple of LED light changes to my M45....I know if a previous post someone was asking about the license light changes to look like a Lexus....Here are my pics....Tell me what you think
Here is a picture with one of the License lights replace compared to the stock. In the picture it looks really blue but the light is actually white.
Here is another picture of the License plate light comparison and also my reverse light LED conversion (once again it's really not that blue)
Here is a close up of the License light
Here is my Driving Light conversion to White LEDs....Once again the light seems blue but its more of a HID look
Here is another
Here's the overall look
Here is the comparison....this is the stock driving light
And here is the LED converted driving light....notice it's really not that blue
What do you think?
I guess i am confused. i like the idea of LED, i like the "white" look of it Vs. the more yellow of the HID. but can you see better with the LED or the HID? i dont see that well at night, so i am looking for the better option for that issue.
Thanks for your help.
striz923
Car: 2006 M35x
just insalled my lights and they look SWEET. took about 10 minutes to install (only because I was changing them in the garage w/o a flashlight). On a side note with the parking light LED's are easily removed and incredibly bright so if you need an engine compartment light, just unscrew the parking light and point it where you need the light.
Bull to answer your question the parking light LED's don't give any extra light. I haven't changed my headlights, so unfortunately can't help you there.
Summary- about $35 and about 6 days (including weekend) then 10-15 minute install for a VERY clean look.
pmtran16
Car: Infiniti M45
Between LED and HIDs the HIDs will provide more light and brightness and will help with the night vision. LED provides more of a cosmetic enhancment.
SammyTheBull
Car: 2006 M35 Sport
Very nice. Thanks for clearing that up for me. I do like the look, i think that i will order. i tried to click the links to the V-led site, but kept getting "currently un-available" page.
I'll keep trying. I just got my M two weeks ago, and haven't done a thing to ot yet, so i am excited to get ANYTHING done on it.
SammyTheBull
Car: 2006 M35 Sport
Just placed the order.......hope shipping is fast...
paigoomein
I guess these would be the only other option to go with for brighter back-up lights. it would definitely be an easier choice if it wasn't so pricey.
pmtran16
Car: Infiniti M45
paigoomein wrote:I guess these would be the only other option to go with for brighter back-up lights. it would definitely be an easier choice if it wasn't so pricey.
I agree 50 bucks is way to much to spend on reverse lights
infinitiandbeyond
Car: 2007 M35x
Regarding LED TURN SIGNALS, i found the following to make them blink normally for $7.00.
http://www.ledlight.com/led-fl....aspx
striz923
Car: 2006 M35x
couldn't get link to work.
Does anyone know if there is a white turnsignal for the bulb on the side of the car?
paigoomein
Went ahead with the 19 LED bulb. Here are some pictures.
OEM bulb...
...replaced with LED bulb
LED bulb
OEM bulb (it's actually more yellow than this as you can see in the next picture)
head-on comparison (the LED definitely produces whiter light, but even the 19 bulb LED isn't any brighter than the OEM filament bulb
close-up
Modified by paigoomein at 9:15 AM 11/7/2008
Modified by paigoomein at 10:29 AM 11/7/2008
Modified by paigoomein at 10:30 AM 11/7/2008
pmtran16
Car: Infiniti M45
paigoomein wrote:Went ahead with the 19 LED bulb. Here are some pictures.
OEM bulb...
OEM bulb
LED bulb
close-up
Paigoomein, Nice pics.....yeah I agree with the fact that it's really not brighter but I definitely like how it looks. It's really suddle but really cleans up the look. I think 19 LED is brighter (obviously) but I might like that better than my 11 LED bulb.
My personal favorite driving with just those lights on....not when it's dark but when its dark enough to notice the lights
Nice post
paigoomein
agreed. I love that it's not a drastic change, but that it's really a clean, subtle effect. also did the license plate lights, and that's an even more subtle difference.
I might swap out the back-up lights back to the OEM filament bulb--the LED bulb is more front-firing and doesn't take advantage of the reflective surfaces. either that or I'll empty my wallet and get the brighter LEDs.
Next up I will probably change out the trunk lights.
striz923
Car: 2006 M35x
paigoomein wrote:Next up I will probably change out the trunk lights.
lol, i was thinking the same thing when I was changing out the other lights at night. Then the stupid practical part of my brain said "how many times have you opened your trunk at night in the past 3 months", to which the fun part of my brain said "a half dozen and the yellowish light was oppressing, you jerk"
infinitiandbeyond
Car: 2007 M35x
Try this link instead for the "load equalizers" to make turn signals blink normally.
Has anyone yet tried the fog light conversion (H11)?
paigoomein
ok, I will most likely swap out the LED lights back to the OEM filament bulbs for the backup lights. cosmetically, it looks nice, but it basically renders is useless as a backup light. bummer.
ArbitrageMan
Car: 2006 M45 Sport
I just did the license plate blub switch. It was super easy, once I figured out how to get the clips off.
However, these bulbs are really bright. Im trying to decide whether theyre too bright or not... I think I was going for the same brightness, just the white color instead of the yellow. I dont want them to scream, "I Changed These Myself."
infinitiandbeyond
Car: 2007 M35x
A-Man....which LED did you use? The two light, five light or other?
I have all of the LED's on this string on the way plus the FOGS, dome lights and the top trunk light.
HEY PMTRAN, great job with all the pics!!!
ArbitrageMan
Car: 2006 M45 Sport
infinitiandbeyond wrote:A-Man....which LED did you use? The two light, five light or other?
I ordered the ones PMTRAN posted the link for:http://www.v-leds.com/Shop/Con...32481
They certainly dont look bad. But they overshadow even the tail lights... just my opinion, to each his own. I've left mine on for now, Im going to try and get used to them. I need to find a lexus around and compare...
