Dattebayo wrote:From knowing your posts, that probably means it was half decent to anyone else. You are certainly a creature that demands excellence...
It's really genuinely terrible, not just by my standards.
The picture quality is terrible, for one thing.
It also takes ~30 seconds just to power on. It actually shows "Please wait..." on the screen while booting.
The on-screen display takes ~30 seconds to go away after changing the channel or volume, and it's got a HUGE grey rectangular background that's 5 times the size of the volume bar or channel display it's backing. Which means every time you change the volume, you lose a huge chunk of the screen.
For a long time there were no universal remotes that supported it. I bought one a few months ago that was the first I've ever encountered that works with it.
The stock remote is so poorly designed (underpowered???) that you basically have to point directly at the corner of the TV with the IR receiver for a chance at anything working. And, even then, if you're more than 6 feet away it won't work. This made the lack of supported universal remotes quite frustrating.
There's no "per-pixel" display size setting and it's 1360x768 (not 1366), so NOTHING knows what to do with it. My PS3 thought it was 1080i, my DVD player thought it was 720p but left parts of the edges cut off. Every youtube app for every device known to man gets the outer ~5% of the screen cut off because the TV won't size things correctly. (
Photo of the cutoff, vs a
display that doesn't suck)
The inputs are scattered all over the back of the TV.
The HDMI inputs and power port are located in such a way that any standard VESA mounting kit is obstructed by the cords sticking out from the TV. I had to find HDMI cables with stubby connectors. And worse, I had to manually cut a chunk of rubber off the power cable fitting so it would clear the mounting brackets.
It's a very low-quality LCD so there's no "sweet spot" between brightness/contrast/sharpness. The contrast levels are atrocious and there's TONS of blocky artifacting visible in darker colors.
It has an enormous LED power indicator strip running ~1-6 the length of the screen right under the center. It glows orange when off (a trend I've seen on many TVs--I KNOW it's off--there's nothing on the screen!!!) and blue when on. The blue distracts from the screen very badly. I ended up sticking blue tack along it and coloring it black with a sharpie so I wouldn't have to look at it. But, since the TV takes so long to boot (even to show "Please wait...") the lack of LED means sometimes I can't tell if the remote was successful in turning it on.
It loses its mind when switching inputs and starts hunting for a resolution setting from nothing, which covers the display in more grey rectangles displaying the data of its confusion.
The speakers are ridiculously terrible, and face completely backward behind a hanging bezel, meaning the sound goes everywhere but where you are.
When I got a sound bar to work around the speakers, I lost the ability to change the volume with the TV's remote, and any attempt to do so is greeted with another wonderful grey rectangle blocking a chunk of the screen and reminding you that "Feature not available".
You can't disable unused inputs, and HDMI is at the bottom of the selection list, which means lots of fun scrolling or repeat button pressing.
Occasionally the audio will just stop working. You have to turn the TV off and back on to remedy this (which, as we've covered, is not a quick process). This began happening the first month I bought it.
It's really, genuinely, non-perfectionist terrible.
Dattebayo wrote:I'd hate to be employed by you, lol.
My employees are all the best of the best, so there's no issue there. They share my perfectionist views, which is why they work for me.
