That's not more than a dusting for Buffalo.frapjap wrote:f***, its cold out.
At least we don't have the snow that parts of Buffalo do.
4-6 FEET! Insanity.
frapjap wrote:
Something to ponder for the day- if a gas station had a Black Friday sale on fuel for something like $1.50/gallon, do you think they'd even be busy considering the other sales going on? Do you think most people would fail to do the math, wait in line at the pump, and realize that they're only saving $20 on a fill up vs the $100 they could be saving in line at Best Buy?
Yes, but would you wait in what would likely be a long line when you could be getting the deal on a limited supply of whatever it is that you want at a retail store? This would also assume that gas would be that cheap between the hours of 5am and 9am or something like that. No one is going to lose their profits over an all day fiasco.Bubba1 wrote:frapjap wrote:
You're assuming both sales are mutually exclusive. I'm sure I wouldn't be the only one to do both.
Awesome! I've been watching your progress on Bookface. Are you going to take photos of the body work, too?Kompresshun wrote:It's quite cold here today too. It was 17 yesterday, but it was still 23 on the way to work this morning. Cold enough that I made a fire last night. We're supposed to hit the upper 50's or low 60's on Monday but it's only supposed to be warm for a couple of days then go right back to freezing cold again.
I've already got the Miata torn half apart in the garage and about 75% of the paint sanded, so it probably won't get driven again for quite a while.
I started thinking crazy again yesterday about V8 swapping the Miata. I'm just trying to figure out how to justify the expense to pull it off and figure out a plan to get it done. I'll probably talk myself out of it again, but i'm missing V8 power again right now.
I highly doubt a Black Friday fuel sale would see a lot of traffic increase. On Black Friday most people are more concerned about buying gifts, so they probably wouldn't even care if fuel was much higher.
Yeah i'll probably snap some more photos once I start working with the body filler and fixing dents. I've also decided to go back to the cheap route on the paint for now though.frapjap wrote:Awesome! I've been watching your progress on Bookface. Are you going to take photos of the body work, too?
You could do a V8 fairly cheaply if you grabbed your old favorite 302 from a Mustang. Simplify it with a carb conversion, a little extra cam, and some fresh heads and it'll be the meanest sounding Miata on the block. As long as you don't care about fuel economy anyway.
Also, side pipes are a must if you go that route.
Yeah it would set me back probably close to $10k. See I told you i'd talk myself out of it againfrapjap wrote:You're in the hole for a good chunk of change for an LSx into that car though. There is a whole subframe kit that needs to be bought (or built, at which is a major time investment), the cost of functional a/c, wiring harness, etc. The engine is the cheapest part about the damned build.
If I were to modify a Miata for speed again, I would stick with a turbo and use a quality manifold. That was my major drawback and the only part I was cheap about. The rest of the engine was well sorted between the right injectors, full standalone, efficient cooling, wide band, etc. However, if I decided to be different with a similar investment to the turbo, it'd be a stock rebuilt carb'd & cam'd 350 with a suitable manual transmission.
hey ben, remember when i asked you about that evap leak code my exploder was throwing? you suggested changing out the gas cap. well, it seems to have worked. i still have to replace the cel bulb, but i plugged in the scanner and i'm not getting any codes. i changed the gas cap a good month ago, so it should have gone through all the cycles after clearing the code. cheers.sx moneypit wrote:Good afternoon folks!
this x10000000000000000.Kompresshun wrote:I DESPISE carbs
