Depends on the array. If you're going for improved speed, raid 0 is what you want. In this case, if either one of the drives fails, you lose everything. This makes it 50% less reliable than an individual drive. Now, if you want more security, you'll go for something like a raid 1 which would be more than double the reliability as the only way you get in trouble is if both drives fail at the SAME time.Dattebayo wrote:My experience has shown them to be more reliable... I thought that was part of the whole point!RobPaulson wrote:naahhh too much crap can go wrong with the RAID arrays
4inch diameter PVC pipe from a hardware storeADDirishboy wrote:
Gerry, any suggestions on how to stretch my lower back out? Did kettlebell swings yesterday and I feel like hell.
thats what the foam is for though, it creates a softer layer between you and the hard PVC, its a lot like a deep tissue message int he fact that it hurts a good amount while in the act, but once you stop you feel like a million bucks. <shrug> to each their own though, it works for memarlin29311 wrote:I still don't agree with this - in essence, you've created a roller, but you also have not given any stress relief to the roller - at the core, it is a hard object. The foam rollers you buy from stores have built in stress relief becuase they are not solid cores...you shouldn't be really using solid core items on your body, as your body is not solid either.
Just my .02...
ADDirishboy wrote: I can't do kipping on that iron gym.
lulzADDirishboy wrote:I can't do kipping
lulz x856375613890756138057165ADDirishboy wrote:on that iron gym.
I try not to take pain meds. They generally don't do anything for me anyways. I became mostly immune to them when I was on them for my knee. It takes a LOT to actually do anything for me.RobPaulson wrote:also, ice ice ice. and anti-inflamatory if your not going to be working out. I dont like being on meds during workouts, if something hurts, i need to be able to feel it. so like... pop an aleve after ur workout, or in the morning on an off day.
Do you remember who you're talking to? I build cabinets all day, every day. I know how to make things sturdy. I'm not gonna half-a** this. It will be concreted into the ground.RobPaulson wrote:
ya no kidding. Make sure you look up some good schematics to build it, you don't wanna get hurt.
ADDirishboy wrote: I try not to take pain meds. They generally don't do anything for me anyways. I became mostly immune to them when I was on them for my knee. It takes a LOT to actually do anything for me.
That's why I meant that the PVC pipe thing is bad.RobPaulson wrote:IMPORTANT:
DO NOT ROLL FLAT ON YOUR SPINE!!!! THAT IS BAD!!!!
ALWAYS lean to one side and target it specifically, never put all your weight on your lower spine. THAT IS BAD. VERY BAD. Lean off to the side, you have to do right/left side separately.
makes sense...marlin29311 wrote: That's why I meant that the PVC pipe thing is bad.
On a normal foam roller, the foam gives and conforms to your back, allowing you to roll normally.
Which piece?marlin29311 wrote:yea, but for $20 i'd rather have piece of mind lol
