Learned'd 4 - More Sequels than Rocky, y0. NSFW
Razi
Car: Moo
DrifterXRPS13 wrote:the best part was messing up tailgaters...if they got on your a**, i would shoot a fireball on their bumper...that always backed them off.
It's like Mario Kart or something.
I wish I could spit fireballs at will, that'd be fun.
PEZi
sadly because of where my exhaust exits... no one would be scared when i shoot fireballs... can't see that s*** :/
DrifterXRPS13
Car: 1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600, 2013 Harley Davidson Iron 883, 2014 BMW S1000RR
haha ant....yea all i had to do was either brake boost it or slowly accelerate in 1st gear until i get up to speed a little bit and then just punch it....it would always pop and fireball into second.
PEZi
yeah mine does it when i go from either high rev or full throttle and just let off
PEZi
where the f*** is everyone?
AppleBonker
fapping?
PEZi
meh... i guess...
maybe i'll do homework
King Ranzo
Car: 15 Ford Focus ST
I are here.
AZ89two4Tsx
Ant, how much would you charge me for 8 quarts of 5w 40?
Razi
Car: Moo
:couch
PEZi
AZ89two4Tsx wrote:Ant, how much would you charge me for 8 quarts of 5w 40?
$9.20 x 15% discount = $7.82 per quart
Razi
Car: Moo
King Ranzo
Sex.
Anyway, I'm out gaiz. Night. :wavey:
PEZi
razi... tech talk time!
Razi
Car: Moo
We doing what now?!
Bye Gir!
PEZi
i'm doing a bypass oil system on the truck.... first thing first... any idea what nissan uses for threads on their filter mounts? i'm assuming they're universal...... can't be 100% sure
after i build this up long enough i'll post the pic of what i'm doing
Razi
Car: Moo
They change up between engines, no idea what their reason for it is.
I know for the KA and S13 SR, it's 3/4"-16 thread.
Are you relocating the oil filter or doing something crazy?
PEZi
well... yeah... the system requires that i get an adapter... said adapter comes in:
• BK195 for 3⁄4" x 16 thread
• BK196 for 13⁄16" x 16 thread
• BK197 for 18 mm x 1.5 mm thread
• BK198 for 20 mm x 1.5 mm thread
AZ89two4Tsx
Dayyyum. Is it liquid gold or something? That be expensrive!
Razi
Car: Moo
The BK198 would fit SRs and stuff.
I have no idea what your dinosaur engine runs though. :P
I think BK195 or BK198 would be your best bet.
I'd be willing to bet the BK195 would be the one though, I guess you could buy a cheap KA filter from Autozone or something to see if it fits?
Yes!
PEZi
Razi wrote:I guess you could buy a cheap KA filter from Autozone or something to see if it fits?
i might do that if i can't find the listing... i know the reason i can't run a KA filter is because the diameter of the housing is too small... i haz jumbo filter
Razi
Car: Moo
Are you trying to put in an oil cooler too?
I've always wondered what autocross cars need to do for cooling, it doesn't seem like it would be that hard on the temps since the runs last a minute or something.
PEZi
i might do a cooling system after the engine swap... no need yet as the oil will already be cooler just by doing this and i don't have heat issues yet with the power i make
ok... reveal time.... got the info i needed... so its time to show off my over the winter mod!
this is the system
AZ89two4Tsx
Ant, please tell me you're doing an "external" oil cooler.
YES
Dattebayo
Hey Razo, fix that signal problem yet?
Razi
Car: Moo
PEZi720 wrote:i might do a cooling system after the engine swap... no need yet as the oil will already be cooler just by doing this and i don't have heat issues yet with the power i make
this is the system
That's pretty awesome!
Dattebayo wrote:Hey Razo, fix that signal problem yet?
Negatory!
Dattebayo
Try checking the signal fuse under the hood, then pulling off your column cover and looking at the light switch stalk. The white clitoris at the end that moves when you move the stalk from up to down is the signal return. lol But check the reed connections to see if they move.
Razi
Car: Moo
Yeah, I checked the fuses, all the harnesses (except behind the gauge cluster), the relay clicks when I use the Hazard lights so the relay seems to be in good shape.
Then I took off the combination switch, cleaned all the reeds so they were nice and shiny, still didn't work.
My clock light doesn't turn on with the rest of the gauges either, I'm thinking maybe I got a loose harness or something in the back.
I'll take a look back there this week.
Dattebayo
Nah, its your combination switch. The turn signal reed is separate from the others, I just found out.
Razi
Car: Moo
Yeah they are little copper strips, the switch touches 2 out of the 3 to signal one of the lights.
Just to make sure, I touched em with a screwdriver, the way the switch would, still didn't click.
wat do? :(
