Incorrect. RPM increase is a replacement for displacementSpace Monkey wrote:There is no replacement for displacement.
a stock ka will rev to 7K no problem but a FCW crankshaft and the KA will actually build hp past 7K rpmsPoorManQ45 wrote:
Then you have the problem of getting the head to flow enough air to make power past 7k.spooled240 wrote:
So you can prove that increasing rpm makes more power then increasing displacement on these particular engines? Oh, just talking out your @#$...PoorManQ45 wrote:
Peak HP will be higher assuming your head can flow enough air. However, the power curve is increased more efficiently by adding displacement since you gain power throughout the entire rpm range vs just peak.Space Monkey wrote:
The crank can't increase power past 7k just by being counter weighted homie. You need cams and a turbo that will support the volume required at that rpm. The KA just needs cams and valve springs to rev right to 7300. Been done many many times.spooled240 wrote:
I hate youWDRacing wrote:
Ask the SR guys if they'd rather have the 2.2 stroker kit or higher revving stock SR.
Koshin wrote:how about that built TT KA26dett? that thing was nasty, Im looking for pics...
Here you go -- it not TT but it still puts out 802WHP!!! That is more HP than GDemension's all out top shop challenge SR20 w/ 827 crank HP.Koshin wrote:how about that built TT KA26dett? that thing was nasty, Im looking for pics...
true, the stock KA head has tow truck spec cams and small portskouki munster wrote:
DrifterXRPS13 wrote:yea, you'd like some stroke wouldn't ya.
WTF was with that guy's reaction time? He let like 2 whole seconds go before he took off...Space Monkey wrote:1000HP KA24DE
http://www.youtube.com/watch?v=r-LFECM-OH0
Not saying the SR can't put out 1000HP! Just saying the KA can
Well, that's only if all things are equal. If your efficiency is much better, then yeah... you'll make more power.JustinStrife wrote:There's no replacement for displacement.
Lou Gigliotti took his C5 z06 world challenge car to the strip for s***s and giggles...in full road race trim except for the rear wing the thing goes 10.50 @ 140, 535 rwhp...it can be doneWDRacing wrote:Hard to have a circuit and a drag contest and build the car for either one more then the other. Most circuit cars are far slower in the 1320 and most drag cars...well they usually end up in the grass when venturing out onto the circuit...lol. Especially with 275/60's out back.
I drag far more often then I'll even see a road course, but I'd love to have a car designed to do both well. Just requires more money then I have right now.
Check out the first car on this list:Space Monkey wrote:1000HP KA24DE
