KAT vs SR
Mr1der
I expect timeslips to be posted so we can bag on your reaction times
WDRacing
My reaction times are catlike...dead catlike
Mr1der
do you start to go then slam on the brakes like a woman at a 4-way?
WDRacing
Nah, once I start I don't stop until the end. I'm not a big fan of "interuptus"...
spooled240
Car: kouki s14
these guys are pretty old so the r/t's should be around a few seconds? lol
PoorManQ45
WDRacing wrote:
This is exactly true, especially when adding boost into the equation. You can't compare a 2.0 to a 5.0...
WD
Sure you can. All you need is for that 2.0 to rev to 18k RPMs
zerepdivad
Car: '90 240sx . '02 Lexus IS300
What's a ka-t? ka truck?
pauliedrft
Car: 91 240sx
I prefer the sr over the ka24de but both have there pro's and con's I think there should be dyno drag and a circuit test , but hen it still goes to the better driver i cant wait til you guys get this rolling . Its funny dsport is doing this same battle but different chassis . Cant wait to see what happens .
WDRacing
Hard to have a circuit and a drag contest and build the car for either one more then the other. Most circuit cars are far slower in the 1320 and most drag cars...well they usually end up in the grass when venturing out onto the circuit...lol. Especially with 275/60's out back.
I drag far more often then I'll even see a road course, but I'd love to have a car designed to do both well. Just requires more money then I have right now.
I may end up having to switch my setup all around. The turbine wheel on turbo I'm planning on using is trashed. Pits and chips all over the blades. Since I'd be welding the manifold and everything based around that turbo, I have to look for a cheap turbo to use, or explore other options. Kinda puts me behind the power curve as I have to pull my transmission back out and do a bunch of other crap still.
I need to get busy...lol.
WD
Dire91
Car: 1997 Nissan 240sx SE
zerepdivad wrote:What's a ka-t? ka truck?
Hahahaha I don't know why that was so funny KA all the way, why would you not want to represent AMERICA with stock goodness.
Space Monkey
Car: 1990 Nissan 240sx
I'm a KA-T fan myself. Im building my KA to be indestructible!
Built KA-T > Built SR
boriquaS13
Car: 92 240sx
Ka-t indestructable= Not possible sr ftw
spooled240
Car: kouki s14
no way, just rods, head gasket and a good tune and it'll be indestructable
Razi
Car: Moo
boriquaS13 wrote:Ka-t indestructable= Not possible sr ftw
BAHAHAHAHAHHAHAHAHAHAHAHA
raremotive
Car: 04 Infiniti G35
Koshin wrote:refer to above post
Omaha, Nebraska...Early June, first weekend I believe
Man, I hope my summer intentions come true so I can watch you two duke it out.
pauliedrft
Car: 91 240sx
spooled240 wrote:no way, just rods, head gasket and a good tune and it'll be indestructable
nothing is indestructible; i bet you i could throw 500shot 2 stage wet and turn the boost up to 50psi and well KA BOOOM lol
And to the above post about American um Nissan is not American so that was just useless .And as a matter of fact Almost everything these days has a non American part in it some where .
To wd What turbo were you gonna run ??
WDRacing
I don't know at this point man. My TO4 has a bad turbine wheel. So I'll either be buying a used Holset or using a supercharger. We'll see what happens over the next month.
I just had to spend a bunch of cash on my plumbing
No motor is bullet proof, not the SR and not the KA. Either motor can make 500 whp with some internals and a decent tune. It's not even difficult really, add fuel and boost and your only real limit is octane.
WD
Space Monkey
So i exaggerated a little...It should be bullet proof for its application...which is DD at about 300WHP. Just need to find a good tuner in Vancouver...
pauliedrft wrote: the above post about American um Nissan is not American so that was just useless .And as a matter of fact Almost everything these days has a non American part in it some where .
True. Oddly enough, Toyota is the most Canadian auto manufacture...Although Nissan does do a lot of manufacturing in the USA. In one of those "I" states...
WDRacing
The KA is bullet proof with factory internals up to 350 easy, but so is the SR. My whole argument has always been that the SR isn't a better motor. Definitely not enough to warrant swapping out the KA. There are FAR better options when swapping is considered
Space Monkey
I agree. If i am going through the trouble of a swap then im putting in a V6 or I6.
WDRacing
8 is far better then 6
Space Monkey
I disagree. but that is for another thread. Personal preference.
PoorManQ45
WDRacing wrote:8 is far better then 6
10 is far better then 8
WDRacing
If I could find an affordable 10cyl I'd be ALL over it. Twin turbo V10 FTMFW
PapaSmurf2k3
Site Admin
Twin turbo V8 2 stroke FTW.
spooled240
Car: kouki s14
^super over-square with a 10,000 rpm red line
hey WD these cxracing t3/t4's hold up decent, I'm sure they'll last at least a few passes down the track at 15 psi..they are like 150 brand new lol
Modified by spooled240 at 5:48 PM 2/4/2010
WDRacing
V8 2 stroke...can you imagine how obnoxious that would sound? Ear splitting death would probably be a accurate description.
spooled240 wrote:^super over-square with a 10,000 rpm red line
I'd rather make my own methane fuel from recycled pig s*** then use a CXRacing turbo. But you know that
zerepdivad
WDRacing wrote:V8 2 stroke...can you imagine how obnoxious that would sound? Ear splitting death would probably be a accurate description.
The cx turbo's aren't as bad as people make them out to be. Mines lasted me like 6000miles thus far. for 150 bucks that's worth it in my book.
Remember there was a time when people used to say stuff like that about japanese cars haha. Different scenario i know but still.
float_6969
Brian, I've got an M62 supercharger w/a clutch off of a CLK230 I'd let you borrow. I'm sure you could handle building the bracket, but you'd have to figure out a crank pulley. I bought it to use on my wife's Miata, but she's decided she just wants to rebuild the motor and sell it, so unless I get crazy and put a huge turbo on my CA18 and use the supercharger to spool it, IDK that I'll have a use for it anytime soon. I got it for super cheap, so I'm not real worried about it.
seang
Car: Ford Fiesta ST
Someone say v8 2-stroke? Here is a video of a 3.6 liter 2-stroke v8 in a sand-rail making dyno runs:http://www.youtube.com/watch?v=lRKeuHyI0lw
