lets look at a few scenarios
700cix8000x0.5x.90%/1728=1458cfm base in NA form....
lets boost it to a modest 20psi...
20+14.7/14.7=2.36PR
=3440cfm
it takes approx 1.5cfm to generate 1hp...
so with just some rough calculations...a mild big V8 on a good amount of boost...is at 2293 hp....
i think we could do better with
740cix9000x.5x95%/1728=1830cfm in base NA form....
and lets get a little silly with the boost..lets go to 30psi....
30+14.7/14.7=3.04PR=5563cfm...
thats around 3708hp
the real problem with a machine like this would be traction control, and finding enough areodynamic surface to keep the car on the road....
now....lets not even get into running alcohol..cause the power levels just go up from there
(cause you do know that the 1.6l honda engine runs on a very exotic fuel....right?)
lets take a 2000lb race car....one has 1200bhp at 18000rpm...it has a power to weight of 1.66lbs per hp...
lets take a 2500lb race car ( for fun i added another 500lbs cause you think the engine will weigh alot more)...3708hp at 9000rpm..it has a power to weight of 0.67lbs per hp
now the most crucial thing.....which engine do you think will be more reliable over the long run.....
the boosted 1.6l running 60psi plus at 18,000rpm....
or the boosted V8...running 30psi running at 9000rpm....
which one do you think is going to be faster?
again...why do car makers not do these kind of motors....RULES......
the last real unlimited car series was the CANAM...and i think after that choas....we won't see another one like it..
i still don't see how you can dismiss displacement as a benifit?
