95-j30t wrote:ok guys, she is back, but with 2 problems (one seems very major, but i cant judge yet)
i left the car at the mechanics shop for a couple of days waiting on the drive shaft, so the shop left the car outside in very cold weather.... we got it inside the garage today, and worked on the driveshaft, and finishing up the transmission work..... and once i fired her up, the oil light came on right away and stayed on (added oil, light is still on), that was very disapointing, i opened the oil fill cap, the RPM dropped, and i got to see the oil circulating over the camshafts...., so i thought it would be okay to drive home, so i did. when i got home, i realized that there is a sound coming from the engine, it is a squealing sound, it is not coming from the belts, it gets louder from around the top centre of the engine..... the engine didnt overheat (i drove it for a good 40 minutes), there is no knocking or ticking sounds, just a intermettent squeal that is relative to the engines RPM.... i would appreciate your input on this
the second problem is that the transmission mouting bracket is off, and the transmission is connected by one bolt on each side instead of 2 on each side.....
i'll have to go back to the shop to get the transmission mounted safely....but the oil problem seems to be major issue
Hey, i dont recall messing around with the transmission sensor.
about the oil light, make sure you have the stock j30 vg30de oil sensor, the 300zx has a different sensor (it measures psi) vs j30's oil pressure/no oil pressure sensor (idiot light)
if you have the TT sensor in there, it will show no oil pressure.
btw, i only have 2 bolts holding my transmission in and it worked great for months
hope this helps, good luck man
