95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Mon Jan 15, 2007 8:45 pm
ok i couldnt resist, i drove it around in the underground garage parking, the speedometer works, selector beam is installed correctly, steering is good (a little heavy), transmission responds well when the engine is cold, when the engine warms up, the car feels heavy at starting from a stop, and then smoothes out.....
boost controller wiring is all check (made a mistake by hooking up the positive wire of the controller to a ground, but sorted that easily)
checked lighting, all good, i didnt think that my engine remote starter would work, but it worked, engine codes are 35 and 42
42 is a fuel temp sensor, it is located in the fuel rail of the tt engine, all J's of all years dont come with such a sensor, so to solve that issue, i have the J-spec harness that came with the package, i'll take the sensors plug out of the jdm harness, extend it, and install it in the J (from the sensor to the ecu)
code 35 is the EGR temp sensor, i dont have an EGR temp sensor in the engine because it is a JDM engine (they dont come with such a sensor), i have the wire for it though in the J's harness, i have researched, and that sensor doesnt effect performance, emmisions of the engine
by the way, the tt is supposed to idle at about 900-1100 RPM, so i'm going to adjust that next
there is a strange connection between the coolant temperature sensor and the way the car idles, if that sensor's contact is corroded or if the sensor is unfunctional, then the engine would not idle correctly, and would run rich, so i'm going to clean that tomorrow....
well i'm getting closer to completion, i'm hoping to get the car fully functional by the weekend, i'll keep you posted
