***UPDATE***
A long story short...
Turned into this...
And now it ended up like this...
I basically eliminated all the wiring that involves the A/C system, and some other stuff that i no longer needed. All i have left of the main fuse box is this. Along with the two antitheft relays that arent pictured but will be put in the same location.
I have decided to relocate the engine bay fuse box, or whats left of it to this location under the ECU.
And then i had to deal with all this...
I know it looks overwhelming but let me explain a little about the project. Not a single wire was harmed in the making of this wire tuck. I depined and repinned every wire i did something to. The only wires i have to lengthen are the Alternator power wire, the starter power wire and some misc stuff like the reverse lights since my car was originally an auto. I rocked it for a year with no reverse lights. By not cutting any wires i have made it so i can add stuff if the need ever arose.
The upper string of wires is whats left of what used to go to the enigne bay fuse box minus the lights and radiator fan relay and its wiring. Everything else will be joined back up to the lower loom and run where the orignal loom went. There is enough room i already checked. Here is a pic of the tw looms.
I have decided to weld up this hole and make a smaller one above it. I ordered some smaller grommets that should work on accoutn of there being not as many wires. This is over the driverside wheel well.
On the otherside the engine wiring harness will be run through the old AC condensor condensation hole which is the lower hole in the picture. The other 3 holes in the picture will be welded shut. the starter and alternator wires will be run through their own holes with grommets but the engine will cover them up.
Here are some other misc pics....
Here you can see the two looms a little better.
As soon as the wires i ordered and the grommets come in i will hook up the battery back in and make sure everything still works. Since i didnt mess with any of the engine wiring im not worried about that stuff not working.
