****UPDATE****
I started cleaning up my engine. Last year when i did the swap we literally got the engine from the shop and put it in the car that day. This time around I want to pay a little more attention to detail. On to the pics...
Engine Before
After the preliminary cleaning
Today I also got the parts in for my Z32 brake upgrade. The rotors are huge compared to the old ones. The rears are going to have to wait till next year if i do them at all. A little black paint on the calipers and they should look fine.
Got all the subframe bushings out. The front ones are fairly easy but the back ones you are left with leftover rubber. I will have to burn the rest out.
Rear ones
Front ones...see nice and clean since they have the metal sleeve.
The tension rods they have a sleeve to so they turn out nice and clean
Btw a wood stove is a great way to melt the control arm bushings out. About 30 seconds is all it takes.
And finally the car as it sits now. Kinda sad really but this should be well worth it once spring comes.
The wheels and some misc parts are being ordered monday from enjuku so i will have plenty of time to figure out the spacer situation before spring
