goody90q45 wrote:Brian is trying to verify the the ATF is clean. Wipe the dipstick on a white towel and compare the ATF to new ATF. If it looks worst than new it's time for a few drain and fills using $10 gallon Walmart ATF. I had hard shifting in my 94Q and Lucas Transmission treatment and Lubeguard both worked well in cleaning up varnishes the transmission internals and improved the 1-2 gear shift.
Do run the self-diagnostic as suggested. It's simple to do (sitting in the driver seat in your driveway) and may lead you to a bad sensor. Check out the Transmission section of the FSM (AT) for the self-diagnostic procedure. Has the TRANSMISSION MALFUNCTION warning come on in the Odometer display?
Finally, I'd ohm test the external mounted sensors on the transmission. There's 4 of them and they're easy to test. The turbine revolution sensor could be your culprit. You'll find the instructions for ohm testing in the AT section also.
Good luck.
http://www.nicoclub.com/FSM/Q45/1994_Q45/
Please tell me exactly how to do this if is not much trouble I already have the Lucas Transmission treatment but the idea of just send it in without some process seem not quite the solution, supposedly it had a atf not long ago change of a i dont know the word in English Spanish "junta" like the one between 2 cranks
The stain is very light pink
The self-diagnostic was an OK
page??
