Infiniti q45 hard shift 1994 please help, mechanically impai
Jcesar_lopes
Car: Infiniti Q45t 1994
Infinitiguy19 wrote:The rebuilt ones are just as good as new as nearly every part is replaced. Use the OEM external filter or the easier add, cheaper and possibly better Magnefine one.
So the external filter have to be change
qship96
Car: 1996 Infiniti Q45
[quote="Jcesar_lopes"]I check on Infinitipartsusa they only sale new transmission were I can boy a rebuilt one[/quote
Those are actually factory rebuilt transmissions, expensive with a too short warranty for the huge price they ask.
OwnerCS
Looks like $3,123.32
OwnerCS
Here's a link to a thread from Stvo with a filter cut away.
post5033039.html#p5033039
Jcesar_lopes
OwnerCS wrote:Here's a link to a thread from Stvo with a filter cut away.
explain newbie here
OwnerCS
The transmission fluid filter is in the engine compartment in front of the alternator in the picture below.
The thread shows a picture of the filter after being cut open. The filter needs to be periodically replaced with a new one. Many members use a Magnafine filter instead of the OEM type in the picture. The Magnafine provides a better cost value. Last fall I had to wait about 6 weeks for an OEM filter to arrive after I ordered one from IOS. I believe it had to be shipped to the US via boat from Japan.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
qship96 wrote: Those are actually factory rebuilt transmissions, expensive with a too short warranty for the huge price they ask.
Which begs the question, where else does one buy a factory rebuilt one for less?
Jcesar_lopes
OwnerCS wrote:The transmission fluid filter is in the engine compartment in front of the alternator in the picture below.
Cut open? Really?
qship96
normally just swapped with a brand new one......."cut open" old one is only to look inside to see how much debris it collected if you are interested in knowing.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
This helped me and should help you: http://www.familycar.com/transmission.htm
Jcesar_lopes
Thanx!
