Jcesar_lopes wrote:
The stain is very light pink
Thanks they say the atf was change recently so for now y just dump the Red Guard and later a full trans checkup? do you think is a good strategymaxnix wrote:Because it is crap! Add nothing but Red Guard Lube to clean M1 ATF.
You need to buckle down for about a week and read the previous posts on here. Start with all by Q45tech. His early posts especially address transmission functioning.
You also may need to change your external ATF filter and check your lines. If all that fails, has the pan been dropped and the filter screen and O ring replaced?
What does "the atf was change recently" mean precisely? You don't know, so you can't answer my questions in the quotation above.Jcesar_lopes wrote:Thanks they say the atf was change recently so for now y just dump the Red Guard and later a full trans checkup? do you think is a good strategymaxnix wrote: You need to buckle down for about a week and read the previous posts on here. Start with all by Q45tech. His early posts especially address transmission functioning.
maxnix wrote:You still are not answering the questions we are asking, so we cannot help you. At 144K miles, you should budget installing a Nissan rebuilt transmission with the appropriate auxiliary cooler and new external ATF filter.
So, what was on the pan? Did they change out the internal filter and O ring? New gasket? Almost impossible for the AT pump to generate too much pressure. I think this guy knows less than you and definitely does not know the transmission.Jcesar_lopes wrote:maxnix wrote:You still are not answering the questions we are asking, so we cannot help you. At 144K miles, you should budget installing a Nissan rebuilt transmission with the appropriate auxiliary cooler and new external ATF filter.
Hey a little patience please I love the car and have to decide if I´m keep in it.
Que answers : Self diagnose said ok, ATF is very light pink, about what was done to it, for now only know they change the oil, dropping the pan,
Very newbie here please some understanding, also I took it to a guy he was pretty much like you since he can´t say what was done to the car but Iam going to print the AT guide so see if he can help. I told him about the outside sensors to see if they can be calibrated but didn´t can they?? He did calibrate i Think the throttle sensor, lowering now the third is not that hard but the second sill kicks, he told me the At had too much pressure??
He also said something about changing the valve cap ? I dont know if he said tha name is where all the sensors are and the solenoids I think I have to study more
Turbine like sound that increases in frequency with increasing speed.Jcesar_lopes wrote:Thanks a lot, define whining??
maxnix wrote:Pulling the turbine speed sensor requires dropping the transmission. At that point, might as well be prepared to install a Nissan rebuilt one along with new external filter and auxiliary ATF cooler.
