Exhaust IS NOT "trivial" to drop on an old car that has actually been daily driven, all the bolts and fasteners are rusted and very brittle. My tech had transmission out in about 10 minutes without touching the entire exhaust system......all depends on the skill level of the tech you choose to work on your car.maxnix wrote:Care to illustrate how?
In dropping the transmission, the exhaust is trivial to remove and gives much more room to work. No reason not to do it.
Not if the car is not in the salt belt. Ten minutes to remove means you had the optional explosive bolts installed.qship96 wrote:all the bolts and fasteners are rusted and very brittle. My tech had transmission out in about 10 minutes without touching the entire exhaust system.......maxnix wrote:Care to illustrate how?
Oh, this is all about your problem. You just don't realize it. Try at least reading the AT section of the FSM. You don't ask the right questions, you don't make the correct observations, you ignore the relevant data, you don't understand the functional processes. How can we help you when you remain steadfastly ignorant? We cannot. You need to take it to an experienced shop and replace the transmission with a Nissan remanufactured one, or at least get a competent diagnosis. Or walk away from the car because you will not know what to do to restore and maintain it and the next expensive system will break from neglect and/or abuse and you will be stuck again.Jcesar_lopes wrote:now back to my problem, i doubt it, gracias por nada
Very funny.maxnix wrote:You need a Yaris.
Jcesar_lopes wrote:maxnix wrote:I need a Yaris.
The accord is long gone, my prob. is the Q45 he has experience in pathfinder trans and is very good at it , by the way what is a G50??maxnix wrote:Well, the bad news is that the Accord transmission will cost just as much to replace.
Whatever you do, do not rely on any "mechanic" who is not well versed in G50 model to work on your car. Things could get a lot worse fast.
I wish we could do more to help.
You have a G50 Q45. A Pathfinder is nowhere close in any form except for 4 wheels.Jcesar_lopes wrote:The accord is long gone, my prob. is the Q45 he has experience in pathfinder trans and is very good at it , by the way what is a G50??maxnix wrote:Well, the bad news is that the Accord transmission will cost just as much to replace.
Did i detect irony or is really a stronger version of A Pathfinder?maxnix wrote:No, the transmission should be the stronger version of the Pathfinder. I hope he can get all the new parts he needs.
Jcesar_lopes wrote:Did i detect irony or is really a stronger version of A Pathfinder?maxnix wrote:No, the transmission should be the stronger version of the Pathfinder. I hope he can get all the new parts he needs.
maxnix wrote:No, if he has enough new parts and the experience, you should get by. Don't forget the external filter and he should check all ATF line and the heat exchangers.
