9 inches wide. yes 17s. no over fenderstramp_drift240 wrote:youve got 275 40s on the back? are they only 17s?
and do you have overfenders by any chance.
next weekend.autox615 wrote:updates soon!?
I take it the knock sensor tested bad?idahotuner wrote:YAY new injector O rings came in today. but i am 3 hours away at college. and wont be able to get home for 2 weeks. need to pick up a new nock sensor. and a fuel rail to manifold o ring.
When you go to install the KS, make sure to check the sub harness as well. Often times its the harness that has failed, not the sensor. I just ended up making a new harness for mine, because I didnt feel like dropping the money at Nissan.idahotuner wrote:yeah dude i tested it and the tps. the tps i got 11.8 and the KS i got 00.0 lol i think this is the parts number for the knock sensor. 22060-30P00 its off a 95 240sx
if you have it keep it.DriftBoy07 wrote:quick question-you dropped the power steering right?im considering if i want it or not, how do you like it w/o?
hm, im having the same problem right now.idahotuner wrote:i discovered the issue.
it is electrical. its confusing to explain but after tomorrow i am going to start trying to track it down.
Had to jump your car anytime recently?idahotuner wrote:its a wiring issue man. some were there are two wires crossed or something cause the car idles fine when the head lights are on and hwne i turn them off it doesnt lol
