What tire are you running with? I have 225's up front (Hankook Ventus RSR z212) and have no issue with them unless i'm at the end of a session...but the obvious solution would be to go to an R compound tire....Automato wrote:
i don't know what kind of brake setup you are planning on running, but i find that 225's, stock brakes with brembo blanks and hawk pads, are lacking in keeping up with my brake setup. as long as you are not slammed, you could probably work in some 245's for the front and 275's on the rear. of course offset and rim width plays a big role too, but after looking around, thats the biggest setup i've seen someone run on an s13 with stock fenders and slight mods to the fenders. zilvia.net has an awesome thread on maximum rubber under s-chassis.
right now i have the federal 595's, the crappy versions lol. i know it's not the ideal grip setup, but that was what i bought the car with. R compound would be nice, but i don't think my pocket is deep enough to dd R compounds. plus, i do a lot of traveling from northwestern NY to southeastern PA so that wouldn't help with tire wear as well. i am going z32 26mm front setup soon and want a tire setup that would give me decent grip but also last a little longer too.codyace wrote:What tire are you running with? I have 225's up front (Hankook Ventus RSR z212) and have no issue with them unless i'm at the end of a session...but the obvious solution would be to go to an R compound tire....
awesome. sounds like my kind of tire. since i will probably be going though them like under wearduffman1278 wrote:Federal tires in general are pretty crappy, but they do the job for events.
the 595ss suck, but the 595rs are actually supposed to be decent. haha, again, i point you towards zilvia.net on a thread about the 595rs vs azenis 615's.http://www.zilvia.net/f/showth...zenisthere are also a few links in this thread comparing the 595rs's to other tires as well. the price for the 595rs is comparable other tires that have been proven so its up to you if you want to be a guinea pig or not. me personally, it would be between the kumho mx's or if i wanted to spend a little more money, i'd get the azenis rt615's.idahotuner wrote:so 595 are crappy?
I would disagree. I currently have Federal 595 (whatever the street variant is) on my rearmost two tires, and have NO complaints about them...in fact I like they way they worked on track better than the Potenza's!duffman1278 wrote:Federal tires in general are pretty crappy, but they do the job for events.
I love my Phatnom II gauges. Match the stock SE ones perfectly!idahotuner wrote:after next week i will be ordering my coilovers and rucas. from pbm. so that is exciting. today my phantom water temp gauge is coming in.
haha, I def hear ya there...I wanted to swap my gauges out for the black bsae model ones so badly, but just figured F it....idahotuner wrote:hey thanks cody. i thought about getting those gauges but they were to busy to suit my liking i like simplicity when it come to gauges.
I think I like that..but knowing my luck I would crack the bezel trying to get that gauge in there.redtop91 wrote:Fail. Right under Phantom II on the gauge face it says Autometer.
https://www.bigwheels.net/inde...20LipJRPS13 wrote:id be very interested in seeing these on your car, i was looking at sporting the same rims on my 180sx. and where did you get the pricing on those wheels n tires?
FTWWhite Comet wrote:sounds good. just wanted to comment on the wheel selection. i think the 006's look good but i dont think i'll like them on an s13. they look good on an s14, but i cant even recall seeing them on an s13. if u do get them i'll be anxious to see how they look and flow with everything
