I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
troskinatior
Car: A Two Tone Piggy Coupe
okays. I was driving down 195 at around 75mph today around 8am to go to drift camp and all of a sudden it sounded like a huge tractor trailer tuck was passing, the steering wheel saw shaking, then it started to veer to the right so i pulled over and saw the right front brake was smoking. When we got home i pulled of the cailiper and every thing looked ok except the metal bracket peace between the pision and the pad was missing. Now Im trying to put the caliper back on and I can't compress the pistion enough to get the pads over the rotor. So how do you compress it? I know it isnt seized because I hit the brakes when the cailiper was off and it was moving. I tryed to compress it with a pipe wrench with the brake booster cap off but I barely did anything. Are you suspose to compress it with the bleeder valve off? If you do, do you need to bleed the hole system? And does any one know how it can just stick out of nowhere?
And can someone please help me, the last couple of times I posted on this thread I got ignored.
truckmtr240
Car: 91 240sx hatch
Is there any way to adjust the height of the hatch. like lower it.
troskinatior
^ do you have the rubber bushings on the hatch? if you take them off it will probably lower it
Dire91
Car: 1997 Nissan 240sx SE
I know this is a really fanboi question but since I'm sort of against the whole "learn on public streets" does anyone know of any drift schools/tracks around the NYC area.
troskinatior
YEP! Well its not a school but there teach you how to drift and everyone helps you out. Its clubloose in englishtown nj. The next event is in 32 days. heres the link-http://www.clubloose.com/clubloose/phpbb/index.php
http://www.youtube.com/watch?v=OSiPNXTgK0U
http://www.youtube.com/watch?v=ZhdKZCLM_t8
There was also a event on friday in ny. It on the clubloose event subfourm
Dire91
troskinatior wrote:YEP! Well its not a school but there teach you how to drift and everyone helps you out. Its clubloose in englishtown nj. The next event is in 32 days. heres the link-http://www.clubloose.com/clubloose/phpbb/index.php
Thank you! I'm like beyond beginner, is that a problem? I can't seem to find the event thread for the one you are talking about. Those guys all seem really experienced.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
troskinatior wrote:okays. I was driving down 195 at around 75mph today around 8am to go to drift camp and all of a sudden it sounded like a huge tractor trailer tuck was passing, the steering wheel saw shaking, then it started to veer to the right so i pulled over and saw the right front brake was smoking. When we got home i pulled of the cailiper and every thing looked ok except the metal bracket peace between the pision and the pad was missing. Now Im trying to put the caliper back on and I can't compress the pistion enough to get the pads over the rotor. So how do you compress it? I know it isnt seized because I hit the brakes when the cailiper was off and it was moving. I tryed to compress it with a pipe wrench with the brake booster cap off but I barely did anything. Are you suspose to compress it with the bleeder valve off? If you do, do you need to bleed the hole system? And does any one know how it can just stick out of nowhere?
Dude happened at 75, and wont compress, scary. Did you try another caliper, if not try depressing the piston and see what happens, it it depressed then just replace the failed caliper.
troskinatior
Tried A hammer... didn't work. I used A pipe wrench... Didn't work. I bought A C-clamp... I bent the s*** out of it.
When the car was in the air I pumped the brakes and my brother said the pistion was moving back and forth, so I don't think its seized. When you try to compress it do you just push it in? Or do you need to open the bleeder valve?
http://www.clubloose.com/clubloose/phpb ... php?t=3711 Heres the event that was on friday, I didn't go but looks like alot of fun. And the closest event at englishtown is on may 26, Thats for mostly beginners because its in a parking lot but when you become good enough you get bumped up into B-class and can drive on the road course. You can drive on the road course when your in C-class (the lowest you can go) but you can only drive in the back course. The best drifting event on the east coast and POSSIBLY the usa is on may 29 and 30, theres going to be pros there 100+ drivers and a bar at the track. I'm also a beginner and may 26 will be my first event!!!
Dire91
^ Alright thanks a lot man. Good luck, maybe I'll see you there if I get my car setup properly. :bigthumb:
troskinatior
Dire91 wrote:^ Alright thanks a lot man. Good luck, maybe I'll see you there if I get my car setup properly. :bigthumb:
Yea its gonna be awsume!!!
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
troskinatior wrote:Tried A hammer... didn't work. I used A pipe wrench... Didn't work. I bought A C-clamp... I bent the s*** out of it.
You are NOT supposed to open the bleeder valve. The fluid is supposed to compress enough to allow it to go back in. I think that caliper has had it and I would get another one. I have calipers I took off of my 1990 240sx HB if you want one.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Yeah sounds like you need a caliper, or maybe both. I tend to like doing work like that in pairs.
troskinatior
Thanks for the help guys. I bought a cailiper today and instaling it tommorrow. I hope I don't have any problems
ghostboy
Car: 1995 240sx
I recently removed my stock header and unfortunately had to cut the EGR tube. i live in NY so i cant leave it cut or cap it. i was looking at the stock header and it looks like the screw at the end of the tube is going to be too big to fit in the new headers. am i just paranoid or is it bigger because on my the new set the o2 sensor can fit in(what is supposed to be) the EGR tube bung and regular o2 bung?
Johnnie
Car: 1990 240sx Fastback
My dome light doesn't come on when the doors open, but I can turn it on with the button. Where is the sensor located in the door, if any, that I would need to change? I would imagine that it's separate from the door ajar sensor that makes the automatic seat belts move. any ideas?
Thank you
PapaSmurf2k3
Site Admin
ghostboy wrote:I recently removed my stock header and unfortunately had to cut the EGR tube. i live in NY so i cant leave it cut or cap it. i was looking at the stock header and it looks like the screw at the end of the tube is going to be too big to fit in the new headers. am i just paranoid or is it bigger because on my the new set the o2 sensor can fit in(what is supposed to be) the EGR tube bung and regular o2 bung?
Why not just remove the nut from the factory manifold and see if it fits in the header? Use some heat and some elbow grease to get it out. Or just try and see if the new EGR tube will fit in it (you are going to need to buy a new EGR tube anway, seeing as how you cut the old one). If it doesn't fit, then you should probably contact the header manufacturer and ask what is going on.
gigabit240
Car: 92 s13 hatch -sold
98 s14 kouki -current
So I had a quick noob question. I got a 1990 240sx m/t speed sensor for my 1992 m/t 240sx. I tried putting it in but three pieces around the sensor didn't let it slid in. I know that they work exactly the same and the gear ratio isn't any different. So how could I fit it in there? I don't care if i break this sensor because I only got it for 10 dollars. Is it possible I could just grind the prongs off and slide it in there? Or is there something else preventing it? Any help is appreciated! Thanks :biggrin:
speedeast
gigabit240 wrote:So I had a quick noob question. I got a 1990 240sx m/t speed sensor for my 1992 m/t 240sx. I tried putting it in but three pieces around the sensor didn't let it slid in. I know that they work exactly the same and the gear ratio isn't any different. So how could I fit it in there? I don't care if i break this sensor because I only got it for 10 dollars. Is it possible I could just grind the prongs off and slide it in there? Or is there something else preventing it? Any help is appreciated! Thanks :biggrin:
Can you take a quick pic or two of the sensor and the hole it's gotta go in?
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Mine went right in with a some force. I used a '90 KA speed sensor on a s13 blacktop SR. You may need to have the transmission in neutral. Not sure if that would affect anything.
E_Cruz1989
Car: 2001 1.8T Jetta 5-spd(DD)
1992 300ZX N/A 2+0 5-spd(Summer toy)
I've considered buying an S14, if I can find one that's not been "molested" and decent mileage under 150k, but with that aside, how much WHP can one expect to get out of a KA24DE with no FI added?
PapaSmurf2k3
Site Admin
MAYBE 180 at the wheels.
E_Cruz1989
PapaSmurf2k3 wrote:MAYBE 180 at the wheels.
I've never driven a 240sx, is that a noticeable amount of whp when behind the wheel?
kevin26k
im sorry to do this but i need help finding a write up. i cant seem to find it with the search and its not in the stickies, i need the full 5 lug swap and 300zx brake upgrade for a s13 or possible the parts list needed so i can start rounding up the stuff. i know im missing it somewhere, thanks.
PapaSmurf2k3
Site Admin
Its noticeable, but you'll get your doors blown off by even the most basic turbo setup.
kevin26k wrote:im sorry to do this but i need help finding a write up. i cant seem to find it with the search and its not in the stickies, i need the full 5 lug swap and 300zx brake upgrade for a s13 or possible the parts list needed so i can start rounding up the stuff. i know im missing it somewhere, thanks.
Should be under www.240sxtech.com
kevin26k
didnt even check there, thanks.
240skitzo
Car: 1995 Nissan 240sx
d!ck wrote:If you want to get out of the whole ordeal for cheap, what you need to do is drive a ways and find the body parts at a yard or through craigslist cheap.
if you don't want crappy looking headlights that yellow and haze up quickly there are aftermarket options out there for you like final konexxion or JDM glass housing lights. i guarantee this will still be cheaper than piecing a complete kouki front end as you have to deal with:
parts availability is next to none, you think finding zenki stuff is bad...
high demand - everyone wants it, and they are willing to pay. front end swap is expensive, might as well sell the zenki and find a whole kouki rather than just trying to get the front off of one.
if kouki is your thing go for it. be prepared to spend more and wait longer. if its worth it, you will make it happen.
I find your information to be incorrect regarding the availability of kouki parts. I can go to just about any web site and find tons of kouki parts even stock parts. now zenki is a whole different story i cant find zenki parts to save my life.
speedeast
240skitzo wrote:I find your information to be incorrect regarding the availability of kouki parts. I can go to just about any web site and find tons of kouki parts even stock parts. now zenki is a whole different story i cant find zenki parts to save my life.
Everybody's clear on which is which, right? As far as original parts, I can find Zenki all day long. To the aftermarket effect, I can find Kouki all day long. Y'all need to pick a new search engine or something.
gigabit240
That was a good idea. I just took a hammer to it and it went right in! thanks
speedeast
gigabit240 wrote:I just took a hammer to it and it went right in! thanks
This statement worries me, lol. :gapteeth:
DeAvo
Car: 1996 180SX type X
SR20DET Blacktop
Hi guys I have an sr20det black top 180sx. Owned about a year now. Basic mods Include fmic, bov, pod filter.
Experiencing a loud sucking noise under boost.
Have since replaced and clamped my vacuum lines and tightened all silicone coupling on intake system but still unsure what's causing it.
I have a cheap no name bov, could it be stuffed, and opening to early, and leaking pressure?
Does anybody know a way I can test where the leak is or any other suggestions how/where the noise could be coming from?
Thanks
