speedeast wrote:As far as the fuse box, I just disassembled it and took each relay out but left them all wired up.
With the MAF questions:
This link is a good resource for wiring. Make sure you read the posts, there is good information in there.
http://www.ka-t.org/forums/viewtopic.php?t=10282
This link is good for the same thing, but not Barney speed, from Jom Wolf:
http://jimwolftechnology.com/w...S.PDF
SAFC would be an option without a tune I think. Has something to do with settings. Do a search on z32 maf and ka and see what you come up with.
Wish I could help you more; my goal is to eliminate my MAF when my engine gets some upgrades.
thanks that was helpful, i did search and read a few topics, i was just looking for a basic understanding of the setup. im going to wait til i get the sr in b4 i get into that. i'll stick to the basics for now.
i have pretty much everything ready for the swap, still un-clear on alot of stuff tho. im trying to decide on a wastegate, will a 38mm do?
*EDIT*forgot to add this chart i found* * big turbo/low boost = bigger wastegate * big turbo/high boost = smaller wastegate * small turbo/low boost = bigger wastegate * small turbo/high boost = smaller wastegate
would the stock sr t25 be under "small turbo/low boost" and would a 44mm be better?
how do i increase boost? is it the wastegate or the actuator that increases boost? stock is 7psi, the HKS Actuator Kit increases to 12psi, is the hks act nessasary to increase boost or is there another way?what is a safe psi to run?i will be getting a cheap manual boost controller for now, i read that in order to close the internal wg valve, it must be welded shut, or a bracket installed, which of these methods is perfered? i can weld it myself but is there any way it could damage it? is this the bracket?
i know this stuff is common sense to most of you, my first turbo motor and its tucked away in the corner, until i have everything i need. once i take it apart i'll understand everything. if someone could explain the basics to me that would be helpful. any details at all will be goodThanks
Modified by KYZAAC at 3:43 PM 3/27/2010
