I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
PapaSmurf2k3
Site Admin
TheGuru wrote:Hey guys does 200$ sound like a good price for everything needed for a 5 speed swap except a transmission and transmission mount?
all used of course
As long as its in good working order... its not a BAD price. Not really good either.
phobs
Alright, so why do some Silvia corners have different shades of amber? Examples:
http://i20.photobucket.com/alb...2.jpg
http://i20.photobucket.com/alb...0.jpg
I have a pair of immaculate corners with light amber shade like the first picture and I have a pair of worn out corners with a darker shade of amber like the second picture. Is it because of sun fading? Different manufacturing years? Anyone know the answer to this, it just makes me wonder.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Look how some clear headlights get a yellow tint overtime... I'm sure that's the same thing...
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
it probably has to do with the years manufactured. Maybe a different vendor,.
odmoht
quick question...i plan on getting the nrg quick tilt system w/ nrg short hub.i don't see anyone with this setup and was wondering if its a bad setup or too expensive?searched and nothing came up.is it better than the hub/QR/Lock setup?
any help is appreciated.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Not sure about that, I thought the tilt was achieved in the column and not at the hub. I would also like to know.
odmoht
well i was told from a sponsor that a nrg short hub is needed/required for it.does anyone have this setup ??
Brownskills
Car: 240SX
PapaSmurf2k3 wrote:
b) "out of tolerance"?? What kind of plugs did you use?
used ngk iridium plugs, when installing the last plug it felt like the threads did not settle like the rest (the plug tightened all to soon)...taking a shot at myself but i believe the engine would not perform if such was the case!??
PapaSmurf2k3
Site Admin
Yeah that's bad news man... sounds like it cross threaded or something.
LigerDrift
Car: 96 S14 SE Zenki
Yo hey guys new here, finally got an account but been on here just searching for the past year lol. Ive used the search button to find my answer but apperantly i havent searched enough.
Question: Will a 5 spd ecu from cali cause high idle or any abnormal idle since i do not have the egr temp sensor that the cali s13 came with? Thanks
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I dont think so. I have a few friends with all the emissions stuff removed and they run okay. Some never even threw a CEL
krunkel
Car: 92 240sx hatch
75 280z
can a 350 engine fit in a '92 240?and not the engine from a 350z but from a chevy or some american car. if so how much power could i get out of it and what all could i do with it (drift,drag,autocross, ect.)? i got a buddy at work that will sell it to me for $100!
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
They fit, find the hybrid section for info. These guys make the mounts needed for a gen1 / 2 engine
http://mckinneymotorsports.com/products
LigerDrift
Yeah cause my s13 used to have an auto ecu, so i poped in a 5spd one and it idles a lot better still stays stuck at 1.8k rpm then dropes to about 1k to 1.3k. Really weird, i adjusted tps and iavc, cleaned it new plugs, wires etc. I did check the egr valve. reved the car to 2k rpm and checked if there was spring action and it should have lifted yet it didnt. Is my egr valve gone bad? Thanks OutToWinPAHC
PyR0NiAk
krunkel wrote:can a 350 engine fit in a '92 240?and not the engine from a 350z but from a chevy or some american car. if so how much power could i get out of it and what all could i do with it (drift,drag,autocross, ect.)? i got a buddy at work that will sell it to me for $100!
350s are a dime a dozen. The problem is the weight of them. Of course, you can make a s***load of power with them though.
krunkel
Car: 92 240sx hatch
75 280z
thanks guys. i saw a 240 at the beach with a LS6 in it. it sounded bad a**. but i might buy the 350 and wait till later down the road before i put it in.
PapaSmurf2k3
Site Admin
If you get an all aluminum 350 such as an LS series engine, they actually weigh a little LESS than a stock KA.
Dire91
Car: 1997 Nissan 240sx SE
Can't seem to find a writeup or video on how to fiberglass then bondo holes in the body. Such as on the rusted hatch of 240sx.
PapaSmurf2k3
Site Admin
If you pick up the Bondo fiberglass repair kit (made by 3M), there are instructions right on the box. I actually just used it, and it surprisingly laid down REALLY nicely. Then again, 3M makes awesome stuff... and Bondo just slapped their name on it. Let me know if you have any questions.
berserkbishop
New to 240's. I
I am looking at buying an s13 with the RB20DET already swapped. The current owner claims to be the one who did the swap. Everything seems solid on the car but it has a bad grind when going into 2nd. He says that the transmission in it was from the KA.
Can a KA transmission be used with the RB20 and if so how long before the transmission cant handle the extra HP?
He is asking $4000 with the car which includes some nice gauges and coilovers installed. Is this a good price?
Thanks in advance!
justinedible4
Car: 1990 Honda Accord, 1991 S13 HB
Hey guys Im about to dye my carpet black tomorrow and i was wondering, after each coat do I have to scrub the dye in with a brush or can I just spray it on and not worry bout it? Btw Im using the duplicolor vinyl and fabric dye.
PapaSmurf2k3
Site Admin
berserkbishop wrote:New to 240's. I
Thanks in advance!
AFAIK, the KA transmission will NOT bolt up to the RB in any way. I'm pretty sure it doesn't stock, but I'm not sure if its possible to make an adapter plate.
You might want to check in the RB sub forums though. Get some pics of the car and post it up there.
LigerDrift
dahveed
tanabe sustec pro sevens. i wanted to go low with them, but there is a little plug that says "do not remove" on the bottom, doesnt let me go past that. is there any way around this?
krunkel
Car: 92 240sx hatch
75 280z
ok so i went to a shop and its gonna cost me 200 to pull the head to see whats wrong and then a trip to a machine shop to get something cut then plus parts and s***. the guy told me that im looking at around 800 to 1000 for all this but if its something simple he said 600 cause it wont have to go to a machine shop. Now after after all that, i got a friend that knows a guy that will sell me a motor (that he says runs) and he will install it for 500(500=price of motor and installation). hes selling the motor cause hes doing a sr swap. the motor is stock and is from a auto. plus the guy said if the motor doesnt run or some s*** he'll give me my money back. what would be better to do?
Modified by krunkel at 11:57 AM 11/16/2009
PapaSmurf2k3
Site Admin
krunkel wrote:ok so i went to a shop and its gonna cost me 200 to pull the head to see whats wrong and then a trip to a machine shop to get something cut then plus parts and s***. the guy told me that im looking at around 800 to 1000 for all this but if its something simple he said 600 cause it wont have to go to a machine shop. Now after after all that, i got a friend that knows a guy that will sell me a motor (that he says runs) and he will install it for 500(500=price of motor and installation). hes selling the motor cause hes doing a sr swap. the motor is stock and is from a auto. plus the guy said if the motor doesnt run or some s*** he'll give me my money back. what would be better to do?
I'd probably go with the other motor. How many miles are on the one you have?
krunkel
Car: 92 240sx hatch
75 280z
144,xxx
Patarach
Car: 240sx convertible KA-T
justinedible4 wrote:Hey guys Im about to dye my carpet black tomorrow and i was wondering, after each coat do I have to scrub the dye in with a brush or can I just spray it on and not worry bout it? Btw Im using the duplicolor vinyl and fabric dye.
That duplicoler vinyl/ fabric dye is terrible in my expieriance it wears out really quick, If anything get new carpet its not to expensive,
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Or use rit dye and dye it..... I did mine, looks awesome.
STEEZxIT
Car: 98 honda prelude (sold!), 95 240sx se
http://www.cars.com/go/search/...ional
idk if it looks sketchy to you guys but theres somethin about it makin me question it lol.your opinions? cos if it checks out i'm down for a trade in on the spot!
