I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Your in pa.... go to Elite JDM in Philly. Its a stand up shop, and the only place I'd get a JDM engione from personally.
That Guy1
Car: 240
TroubleBound wrote:Okay so im in the process of doing my sr swap but this is a super noob question so i didnt want to make a thread for it and i tried searcjing but i don't know what any of this crap is even called. So i took off the exhaust manifold cause i got a new one to go onto it. No biggie, but i had to take two things off of the top of the engine that now have no room to be reinstalled and im wondering what they are and if i need them/how+where to relocate them.Is this my Air intake valve? If so, does that mean i don't need it? Cause i bought a AIV plug from enjuku cause the swap guide i have said i needed one )=.And i have no clue what this one is, something relating to the oil cause its the black box that has a hose coming right off of the valve cover. It doesn't look like it should be deleted either way. Where does it go now do i need more parts/brackets?And as you can see in this last pic, the most recent, my new manifold doesn't leave room for number one or number two to be reinstalled, just wondering what everyone did cause im dumb. Thanks..
Number 1 get rid of all together. It will only create vacuum leaks. the only thing you'l have to do is plug the egr off on the downpipe.
Number 2 bypass that box with hose from an autoparts store, that is for oil overflow.
3rd thing is the most important. Heat wrap your headers very well, you will regret it if not. It will catch couplers on fire.
Just an FYI. the stock cast manifold gives you better torque and dissipates heat a lot better. The only reason for a tubular manifold is a turbo bigger than one to fit the stock manifold.
PapaSmurf2k3
Site Admin
billabong093 wrote:Ok, im new to 240's, and i dont actually have one yet. I had a z32 na but i wrecked it due to some assf***s wreckless driving, so now im saving (work $ + z32 part out $) for a 240. I was just wondering how much a basic kat setup will run you, the setup and supporting mods so the car will be ready to go. This is assuming your starting with an engine in near perfect stock condition, i've already read about checking compression or rebuilding if you had too. Thanks a lot guys, i should be buying a 240 around the new year.
You're looking at about 3 grand to get a turbo setup. This of course depends on what your goals are. You can do it cheaper than that... but you'll have to cut corners. Visit the KA-T forums on NICO and read all about it.
PapaSmurf2k3
Site Admin
DRIFTKNIGHT_240 wrote:can u tell me wat kind of gear oil can i use to change it?
also my car when am in 2nd gear and i go at 6K rpm it won't go in 3rd gear can low oil cause that?
You could do Redline Shockproof gear oil, or 80w90. Low oil can definitely cause that... its also caused by worn synchros.
TroubleBound
Car: 1992 240SX Hatch
Thanks ThatGuy i appreciate all the advice! I obviously have no clue what the hell i'm doing haha i'll learn.
fightinchunk
fightinchunk wrote:will any of the coupe overfenders fit on a convertible... especially the rear ones?
bump
PapaSmurf2k3
Site Admin
I wanna say yes, but you should ask in the vert forum.
DRIFTKNIGHT_240
Car: 240sx Zenki s14 [going sideways]
3rd gear is the only gear it does that all the others are fine at 6K isit possible that only the synchrons of 3rd are bad?
PapaSmurf2k3
Site Admin
Yes... try the gear oil swap first... you can also try double clutching when going into 3rd.
DRIFTKNIGHT_240
thanks
tom1012
Car: 1990 Nissan 240sx
will a ka24de manual trans fit a ka24e?
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
tom1012 wrote:will a ka24de manual trans fit a ka24e?
YES
honeybear
Car: 2007 Mustang
I Was Just Going To Say The Same.
Dire91
Car: 1997 Nissan 240sx SE
What's it called when the back of the hood (closest to the windshield) is lifted a little? I believe it's for better airflow but how do you do it? Just curious.
PapaSmurf2k3
Site Admin
People do it to lower underhood temperatures. I don't think it has specific name, but its just raising the cowl of your hood. Most do it by placing washers (as spacers) between the hood hinge and the hood.
s14derrick
Car: 1995 nissan 240sx
this may be a stupid question but.. im in the middle of my 5 speed swap. i have the trans ready to go in its all lined up but wont go in the motor the extra inch i need. i believe the input shaft is just really tight in the pilot bearing because it was even a little tight getting the alighnment tool in.what would be a safe and easy way to get it in without damaging anything?
PapaSmurf2k3
Site Admin
Getting that last extra inch is always a pain in the a**... you could try putting a socket on the crank pully bolt and turning it/ wiggling it a bit while you push the trans in from the back.
s14derrick
we tried that actually :/ i was wondering if maybe a block of wood on the tailshaft and a mallett would be a good idea to tap it in ?
PyR0NiAk
Just wrestle with it... I know it sucks, but it'll eventually go in... It took my grandpa and myself a while to get my SR transmission back on after changing the clutch...
s14derrick
thank you guys. guess im just going to have to manhandle it
Dire91
PapaSmurf2k3 wrote:People do it to lower underhood temperatures. I don't think it has specific name, but its just raising the cowl of your hood. Most do it by placing washers (as spacers) between the hood hinge and the hood.
Does it mess with fitment at all, like the latching at the front of the hod?
PapaSmurf2k3
Site Admin
no, it still latches fine, but obviously your body lines will be uneven at the back.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
D-Max hoods really help flow
justinedible4
Car: 1990 Honda Accord, 1991 S13 HB
Alright Im looking at wheels and Im thinking about either buying some diamond racing 16x8 +0 offset wheels or xxr 502 in 16x8 +0 offset. I have a question, in the first picture is the diamond racing wheel in 15x8 +0 and the second pic is a 16x8 +0 and I was wondering why the poke (distance from the outside of the fender to the outside of the wheel) is soooooo much greater on the 15x8 than on the 16x8?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I don't think they are sticking out more. I think the stretched tire and negative camber are making the one with the tire appear to be more flush.
naVan
Car: 1996 S14 Silvia Zenki K's Aero edition
the pipe that goes into intercooler from the turbo has a hole in it rite next to camshaft position sensor facing camshaft position sensor and is covered by the nut.what nut is that.is that an air leak covered or something else ? does the pipe has it already ?
and below is the pipe that goes to boost pressure sensor.i cant find the pipe and also not the boost pressure sensure.WTF but the there is hole in it that is uncovered and air leaks from it.
its JDM 1996 S14,same in the photo provided but its not mine.
naVan
93white240sx
Car: white 1993 240sx
Hey whats up? My name is Dustan and I am buying a 93 240sx in about a week, and it have the digital gauges in it but the speedo doesnt work. What I am wondering is what I need to do to get it to work again or do I need to replace it? I am fairly new to the 240sx scene but am not new to tuners/imports. I had a 99 Mitsu Eclipse GS that I totalled not that long ago. Anyways I will be driving it back from the Dallas/Ft Worth area back to Lubbock which is around a 7 1/2-8 hour drive. It has a rebuilt ka42de in it if that will mean anything.
PapaSmurf2k3
Site Admin
Those digital speedos/heads up display units go out fairly often. Usually what people do is swap in an analog cluster. I'm pretty sure there is a writeup on NICO on how to do it.
93white240sx
PapaSmurf2k3 wrote:Those digital speedos/heads up display units go out fairly often. Usually what people do is swap in an analog cluster. I'm pretty sure there is a writeup on NICO on how to do it.
Sweet thanks bro. This is gonna be a good forum to be on. I am also on a couple Mitsu forums from when I had my Eclipse but those guys are super d!ck and absolutely hate noobs period no matter what. You couldnt get away with trying to start a thread on there like this.
