Here are the bolts you need for a s14 auto > manual swap: (I have this printed, I just have to goto Nissan and order it all!)s14derrick wrote:i hear that there is a flap or something that needs to be cut or bent to use the A/T plate on a manual.
Does anyone know what bolt i need to bolt my clutch pedal to my car. i have it all finished for my swap but i dont know the bolt i need. im horrible at this kinda stuff
Do you have MSN? There's alot of little things I'd love to get clear since you are the person who has been able to make the most sense to me!diggles240 wrote:Dazzla- you can use the a/t trans harness. The s14 speed sensor does not have a tail/plug like the s13 sensor. Read this:
speed sensor identification
Wire the neutral and reverse to the ECM and read the link that Salem posted for ka24development.com. It covers the wiring issues. Again, do not wire the 5th position switch to an a/t ECM.
Look at the a/t lower harness and find/reuse a plug for future removal of the transmission rather than hard wiring those sensors. This should not be difficult to accomplish.
Sorry, I do not have MSN or whatever. I will try to answer your questions, but I seriously believe the best thing to do is purchase the 5 Speed Swap DVD from JDS Performance.Dazzla wrote:Do you have MSN? There's alot of little things I'd love to get clear since you are the person who has been able to make the most sense to me!
#1 But now I'm confused about the speed sensor wiring. What does the speed sensor plug into, and how? I'm assuming that the wire running to my auto speed sensor will directly plug into my new s14 speed sensor, correct?
#2 I seem to have a sensor on the top of the transmission. I think this is the CAS? Is it the same thing as the speed sensor? Same plug that connects to my auto CAS, now connects to the m/t CAS?
#3 Will their be any unused plugs from the auto transmission that I will need to cut off or close off once I put in the m/t transmission?
EDIT:
Does anyone have a Nissan part # for the "boot": Do I even need it?
Pretty sure you can go AT LEAST 275 in the back and 245 in the front.canadiantogueking wrote:so I am confused, with aftermarket suspension and wheel's the widest I can go is 205?! 2nd. Do you need to have different rated tires to get up to high speed such as 150-170mph?
holy crap man you wrote a book... you might want to make that into its own thread. I've had a catalytic converter go bad on me once... and it is pretty alarming how quickly things go south, and how bad they can get.1991SE240SX wrote:hello all. so yea...im a newbie and have a problem. first-a little into on me and my car.....im 25 and have owned many sweet cars but have wanted a 240 for the past 6 years. I spent the last 4 years searching for my dream ride with no luck. Until Feb of this year-i went to a police auction and found my baby. And i got the winning bid of $600.
She is a 1991 SE coupe with a KA-DE, Auto, 90k miles, working HUD, only rust is on passenger rocker panel, previously a non-smoker car, brand new Yokohamas, and surprsingly clean paint job(Gun metal metallic with NICE clear coat)
Car has always ran like a champ. and has never let me down....until as of the past 2-3 weeks.
so i have done mass researching and what not and know that 240's are known for the infamous idle issues. But my prob is a lil more hectic than that. I have a crazy idle prob(after the car warms up). it will be at the normal 600 RPM mark and then go up to almost 2k then down as for as 100 RPM. Followed by shaking pretty hard.....and black smoke coming out of my exhaust. Seems like i have to double foot it at lights jus to keep it from stalling out. the smoke isnt super thick.....but its enough to leave a black tint on my bumper above the muffler.
thought it was a vacuum leak, but after a good look over and some starting fluid, it checked out ok. i pulled my plugs to check their condition-and they have a black sooty deal all over them(except the little platinum diode). then.....after all that, was told i had a leaky injector(dont know why it would only do it when it was warmed up....i thought an injector would be bad right off the bat) so i ripped out the entire s13 unit(fuel rail, injectors,lines,and FPR) and switched in a slightly used s14 unit. everything was working fine...until 3-4 days later when the symptoms slowly crept back into view.
I had it in my driveway idling(and it was idling like dog shyt) and hit the cat with my breaker bar and it stalled the car instantly. I hit it hard as hell too. WTF?? ive always suspected a cat prob because since ive owned the car......after driving around for a while-id get whiffs of a sulfery stinky smell(some strong & some light). but not to the extint it is now. After i hit the cat-it seems to feel like a better car. But once it warms up...the sluggish feeling starts. would a cat cause that many problems tho??
I run codes reguraly and 99% of the time ive gotten a 5-5 readout. The 1 other time i got 3-3 or 3-5(not sure) readout and it had something to do with the exhaust oxygen sensor according to the FSM i have. So....i went and got a new bosch o2 sensor. seemed to be fine yet again and couple days later......de ja vu'. i rulled out the MAF just because that would not let me rev up past 2500,right? i was thinking maybe a faulty IACV??? maybe ignition coil???
heres a list of parts i have-might be a cause or lead to the prob......
-S14 Injen Intake(didnt know there was a diff when i bought it from a friend. Finding out only diff is the s14 lacking the breather tube connection for tube off the valve cover. Worked fine for me, got a Spectre mini-filter and put it on the valve cove. Ran perfectly fine and problem free for 6-7months)
-NGK Platinum 2 spark plugs
-NGK S14 blue spark plug wires. 8mm i think??....(only have 4-plug wires......still have o.e. ignition coil wire on coil and Dist.)
-AVI removed
-Megan Front Upper Strut Bar (3-hole mounting plates, not 2-hole. whats the diff???)
-Reg maintained oil changes w/ Lucas 4cyl formula every 3k, Lucas fuel system cleaner, fresh Trans fluid w/ Lucas ATF conditioner and stabilizer.
-Premium Gas only(usually 91 oct....sometimes 94)
-knockoff 5Zigen Fireball muffler(ghetto as fuhk 2.5" piping. From almost cat-back.....)
thats about all i can think of worth mentioning. any info and/or feedback would and will be greatly apprciated. thanx to all that can help.
Ghast wrote:So what happens when Nice guy "A" decides to help out Dumb guy "b". When dumb guy "B" needs a jump start.
Dumb Guy "B" Places cables to his vehicle without nice guy "A" knowing.
Well nice guy "A" knows that you should never f*** up when placing clamps to terminals.
Dumb guy "B" admits to just guessing.
Nice guy "A" looks over at dumb guy "b"'s mistake and now realizes his car is acting f***ing wierd.
Ok guys my accessories are all working fine it seems like but the battery does not really want to hold a charge. But when i give power from another vehicle the battery still does not want to hold a charge.
Like i said it seems as though all of my accessories are working perfectly though.
I do not want to make a thread. I just want some help. ThanksGhast wrote:Let me explain more in depth. With a running donor car hooked up properly to jump my car. My car acts as if it is not getting enough power. When i unhook the ground for awhile to reset the ECU and then reconnect everything on my car. The car started but then died about 5 minutes after. Car ran fine but accessories slowly started to dim along with my lights and everything, As if the battery was not holding charge.
Is it safe to assume that only my battery may have gotten killed in my neighbors stupidity (and my trust of not checking his work, even though i watch this guy build engines all day long, to not even think he could f*** up on jumping a car)
Sounds like your alternator is toast to me... maybe you cooked the diodes when the cables were hooked up wrong. Your battery probably wont last long either... you might want to replace both at once.Ghast wrote:
