I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
rootS13
Car: 1990 Nissan 240sx Hatch
I have a 98 engine in a 90 chassis. Which model exhaust do I need... right now im using a custom made one that sounds horrible and I cant take it anymore.
dahveed
yeah. and if you roll it down normal-strength,(or attempt to =P ) it goes down like a millimeter. if you use hulk-strength, it rolls down. likewise for making it go up.
odmoht
question !!!yeah um...I'm doing my auto> 5spd swap.Flex plate is out and now I'm stuck on the A/T adapter bearing.Any tools or techniques on how to remove this easily??
Any help is appreciated.
PapaSmurf2k3
Site Admin
rootS13 wrote:I have a 98 engine in a 90 chassis. Which model exhaust do I need... right now im using a custom made one that sounds horrible and I cant take it anymore.
Any 91-94 should work... might need a little minor persuasion, but nothing major.
odmoht wrote:question !!!yeah um...I'm doing my auto> 5spd swap.Flex plate is out and now I'm stuck on the A/T adapter bearing.Any tools or techniques on how to remove this easily??
I THINK you are talking about the pilot bushing. You could try using a puller, but I think I ended up dremeling mine off.
rootS13
Aftermarket wise... still the same?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I would say so.
JoseBronx
Im running into more trouble with my car
I know this is a noob question to most but I dont know much about cars, please help. I have a 90 s13 hatch and its been getting worst lately.
Every time I turn the car on it dies. It idles real low I have to give it gas so that it doesnt turn off. There is also some sort of oil leak that spills all over. Could it be a blown head gasket?
I took the car to a mechanic and he couldnt work on it because supposedly it took too much of his time. He did say that the engine was fine but that vacumm system has messed up. Wires, sensors were disconnected Im guessing for the aftermarket intake.
Will post a video in a couple of minutes.
Thanks
odmoht
yeee...another question.is it bad to tighten the flywheel bolts with an impact gun?my brother and a friend said it was bad because it was too tight.
PapaSmurf2k3
Site Admin
JoseBronx wrote:Im running into more trouble with my car
Thanks
Yeah sounds like a vacuum leak. Look for disconnected hoses, but if you can't find any, pick up some starting fluid and spray it around any suspect areas. The car should idle up. You can then concentrate your search in that specific area.
PapaSmurf2k3
Site Admin
odmoht wrote:yeee...another question.is it bad to tighten the flywheel bolts with an impact gun?my brother and a friend said it was bad because it was too tight.
Depends what your impact gun is set to. Just do it evenly in a star pattern and you should be fine.
odmoht
oh poo, dont really know what the impact gun was set on.but i did do it in a evenly pattern though, like in the FSM.
PapaSmurf2k3
Site Admin
yeah, you should be fine.
Dire91
Car: 1997 Nissan 240sx SE
Alright so I'm an hour north of NYC in Westchester County and I'm looking for a shop with a good reputation to rebuild my KA. Anyone know of any, the closer to me the better.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Check the regional forums, the locals will know better.
odmoht
hoooray, almost done with my 5spd swap!buuut, i have a problem. i don't have anything to put onto the bottom half of the transmission, like theres no where to screw the bolts into...if that makes sense.
i cant screw on four of the bottom bolts on the transmission because theres nothing to screw it into.
i couldnt use the gusset brackets (not sure of right word) because those came off the automatic transmission.
i think i forgot to buy something...
need some help
PapaSmurf2k3
Site Admin
Nothing to screw into on the transmission, or on the car? Are you talking about the transmission mount?
odmoht
mmm i got the transmission mount on.its the bottom half of the bellhousing. the bottom half wont screw onto the engine?
comatoseculture
Car: 1990 240SX coupe. Currently running on Megasquirt.
Its the starter plate. the AT one is missing the lower half and the MT is a full plate/shield.
You need a starter plate from a Manual trans 240sx. 89-94 will work.
However, this does mean you now take off the trans/flywheel/and clutch just to get to the plate.
My dual cam KA was an auto and I left the starter plate on it. Then did the above and put the 90's manual starter plate on.
good luck
odmoht
i dont get it, will the bottom bolt screw into that starter plate???i mean, do the 5 bottom bell housing bolts screw into anything?are they suppose to screw onto the gussets?im getting confused here. can i use the AT dust shield?
comatoseculture
I think the four lowest bolts go through the trans gussets, through the starter plate, and into the transmission.
In other words, I believe those bolts are to secure the gussets to the trans.
If I can take a picture up on a lift tommorrow, I will.
odmoht
hmm...can i still use the AT gussets on the MT transmission though?because i tried to do one side and didnt really fit or maybe i didnt try hard enough =/.
chicos240
Car: 1995 240 SX
can you get us a pic of what it looks like, from the front side and back?
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
odmoht wrote:hmm...can i still use the AT gussets on the MT transmission though?because i tried to do one side and didnt really fit or maybe i didnt try hard enough =/.
im pretty sure you can, i just did the 5 speed swap about a month ago. if not, hardware is cheap, find some metrics, dont use standard hardware, thats so irritating!
rootS13
Alright, I ran into another problem. I appreciate all the help ive recieved so far, its just that I had a shop do my swap and Im trying to figure out exactly what they did and how I can resolve my remaining issues.
First: I think its my maf, but everytime I start my car I have to accelerate in order for the car not to stall out. This happens at start up and whenever I stop. What Ive been doing is putting the car in neutral when I am stopped and that seems to keep it from stalling. Trans is an automatic btw.
Second: When replacing the tachometer after swapping in a dohc into an sohc, is it normal to also have to switch the speedometer as well? Or is there a wire thats unplugged somewhere? Neither work.
Thats it for now, thanks in advance.
PapaSmurf2k3
Site Admin
rootS13 wrote:Alright, I ran into another problem. I appreciate all the help ive recieved so far, its just that I had a shop do my swap and Im trying to figure out exactly what they did and how I can resolve my remaining issues.
Look for vacuum leaks.
odmoht
mmm...transmission on! pretty hard to put on without those swivel joints!!!ill try to put on the gussets tomorrow and pictures.thanks for all the people who helped meh.
oh and i need some help with my clutch pedal.what is that plug on the bracket used for? it has 2 wires sticking out of it. and how do i adjust it? right now i have it pretty far down, bout 5 inches from the firewall.
Modified by odmoht at 1:10 AM 8/27/2009
Dazzla
odmoht, did you have to buy a starter plate? How did oyu get that issue resolved? I'm doing a m/t swap in my s14 and have never heard of needing a starter plate to do the swap...
odmoht
i did not buy a MT starter plate loli used my AT one, but it only covers the top half of the bellhousing.but the AT kinda has two halves o.0, theres a black piece for the bottom half.going to try to put that on today.
s14derrick
Car: 1995 nissan 240sx
odmoht wrote:i did not buy a MT starter plate loli used my AT one, but it only covers the top half of the bellhousing.but the AT kinda has two halves o.0, theres a black piece for the bottom half.going to try to put that on today.
i hear that there is a flap or something that needs to be cut or bent to use the A/T plate on a manual.
Does anyone know what bolt i need to bolt my clutch pedal to my car. i have it all finished for my swap but i dont know the bolt i need. im horrible at this kinda stuff
odmoht
s14derrick wrote:i hear that there is a flap or something that needs to be cut or bent to use the A/T plate on a manual.
that cut or bend could be the bottom half of the AT plate?cant help you with the bolts , because i too am horrible at that stuff ahah
