I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
deBekker
Car: 1992 240sx, 1990 Honda Accord EX-R
It's the rubber tube, not a metal one. A friend of mine said I could just buy any rubber hose to replace it but I'm not so sure. I'll try to get in there and get a picture of it.
PapaSmurf2k3
Site Admin
Probably talking about the PAIR valve... just rip that crap out and plug the hole.
deBekker
It's the hose that connects the headers to the exhaust line, if that helps.
Also if anyone could offer some advice on fixing my power steering, that would be great. I'm pretty sure just a hose needs to be replaced. I'm not really an expert, more of a "bring it to the shop" kinda guy.
PapaSmurf2k3
Site Admin
So I take it you have no power steering? Red fluid could be automatic transmission fluid as well (do you have an auto?).
I've contacted NICO's S13 power steering guru to come in here and sell you the busted hose.
deBekker
I'm quite sure it's power steering fluid. I had a beamer where the same thing happened, and my 240 is a 5 speed
Thanks a lot man!
DJButton
Car: 2010 Nissan 240sx
deBekker wrote:I'm quite sure it's power steering fluid. I had a beamer where the same thing happened, and my 240 is a 5 speed
Thanks a lot man!
Alright, first off we have to determine which hose is that is leaking, if it is the soft line that goes from the reservoir on the fender-well to the pump then it is a very easy fix. You can take the hose off and go to any auto parts store and have them cut you a new one, that is what's called a "soft-line"
Unfortunatly it's more likely that the high pressure line has spring a leak since that is the notorious weak point of the system. The high pressure line has a banjo fitting on top of the pump and then takes a 90* plunge down the backside of the pump where it meets up with a steel "hard-line" and goes over to the steering rack. However, you are in luck since my company, Fujii SPL, makes replacement high pressure lines! They come right off the back of the banjo style fitting on the pump and delete the high pressure to hard-line mess and simply go straight to the rack with new fittings and washers included.
Examine these lines and see if you can find the leaking area and we can go from there to get your power steering in tip-top shape again. This also provides a perfect opportunity to replace the power steering fluid as well. There is a drain on the back of your steering rack to let it out, and you can take off the soft-line from the reservoir to drain that portion. On my own car I refilled it using synthetic power steering fluid, don't know if it made any difference but it does not cost much more and is clear in color unlike the nasty red stuff. Which helps on an automatic in finding leaks, so that an liquid under the car will be a different color.
Hope that helps out, I'm going to save that so I can just copy and paste next time someone brings this up... wheeew!
DJ
deBekker
thanks a lot man, I'll go out and take a look at it tomorrow and take some photos of what I think the problem area is. It's about minus fourty today with wind chill and I have the flu, so I don't think it would be smart to go tinkering around outside haha. Hopefully tomorrow it'll be nicer and I'll have a good look. It'll probably be hard to find because in the past I've just brought cars with the same issue to the shop. And all the fluid has probably drained out by now because there was tons of red oil on the floor and it's been sitting for a few months. Nonetheless I'm sure I can find the problem area and then can start trying to get my hands on the right part. It sounds like this might be do-able once I can get it into my garage.
davids1st240
Car: 1989 240sx 12valve ECCS 2400
hey my signal lights work when my headlights are off but when my headlights are on my signal lights just stay on they dont flash or anything iv checked a lot already i think its some of the wireing... any advise would be great
thesporty240
Car: 90' s-13 hatch
Im new too, I have a 1990 hatchback if you get an s-13 becareful because really the interior is fit but the break pedal and gas pedal are really close together that almost made me hit a guy on a dirtbike
you know the light button to make the lights go up and down. if you keep hitting it really fast it will make only one headlight wink its kind of fun to do when you stop at a crosswalk and a group of girls go by lol
maybe a relay? or you need new turn signals. idk thats weird
SpecD_240sx
Car: Nissan 240sx
So i got another question, been digging for answers but can find any. What is the hose thats attached to the valve cover on the right side between the turbo, and what woud it lead to?
thanks
PapaSmurf2k3
Site Admin
SpecD_240sx wrote:So i got another question, been digging for answers but can find any. What is the hose thats attached to the valve cover on the right side between the turbo, and what woud it lead to?
thanks
Is it your car? Just go look if it is... but to me it looks like its some sort of cooler (transmission cooler maybe?)
SpecD_240sx
Car: Nissan 240sx
No it's not my car. I've noticed it seems to be changed in a lot of cars, so i just was tryin to figure out what it was. Thanks for the help
Dire91
Car: 1997 Nissan 240sx SE
So my rear bumper cover on my S14 is dented in and I want to fix it. I know how to take it off but most of the stupid plastic screws are stripped, I'd clip them off but where do I get replacement ones?
PapaSmurf2k3
Site Admin
Maybe a "bumper fastener kit" from a dealership? Things like that are often "dealer only" items.
dontneedalicense2haveacar
Car: 1992 Nissan 240sx (s13)
Im about to buy a 1992 240sx hatchback and my dad will only let me drive a car with driver air bags!! So do they have a air bag in the steering wheel?
AZ89two4Tsx
Nope. Only the s14 and newer does. But the s13 did get a good crash test rating iirc. That might be something to mention if you were looking to persuade.
And no, you can't install aftermarket ones if you were going to ask.
Oh well I'm still going to buy the car and hopefully when my dad sees how much i love it he will let me drive it and if not i'll sell it make some money and buy a silvia
PapaSmurf2k3
Site Admin
I guarantee you 100% that you will not buy a silvia if you sell that car... its the same damn thing as you had just bought, so your dad still isn't going to want to let you have it, only its way more expensive, from another country, and right hand drive.
Tell your dad there is more to safety than airbags... look at race cars. How many of those do you see with airbags?
HA! Good point don't worry i think i can pursway him his first car was a 68 camaro and that didn't have any air bags. HE'S still here and he doesn't wear his seat belt . I've seen a pic of his car and it was 20 different colors. I'll post a pic of the 240sx when I get home.
Respond back by saying "please Max let Jake drive his 240sx" every one who reads this post this^^^^^^^^^^^^^^^^ so I can drive my car.
AZ89two4Tsx
^ You're only 13? Wow, that's even younger than when I started. My advice is pick one up soon (whatever you get), the next F&F is coming out and will most likely raise the "drift tax." 240s are already way overpriced as it is.
And btw, I doubt my advice will really sway your dad, I'm not even 16 yet. Try getting someone older to try to get him on your side. Good luck dude.
Ya thanks i knew i had to start young if i wanted one so i have just been trying to save as much money as i could im looking at three cars right now but i don't know witch one im going to end up with. I always start young. I learned how 2 drive at 6 learned how 2 drive a clutch at 8 and bought my first car at 13 and i started playing GTA at 5 lol
dickie
Car: Killer Turtle
who is this "2" and why is it important that you learned how he drives?
Drifting10
Car: 91 240 SR Hatch
Hey guys i was reading this thing that was like top ten things girls say when they get in a 240 and i thought i read it in this thread but i looked back alllll the way to page 30 and couldnt find it soo if anyone knows this can you please post it up i wanna show my girl friend and my buddy
Thanks in advance guys!
AZ89two4Tsx
d!ck wrote:who is this "2" and why is it important that you learned how he drives?
lol
About that thread, don't buy a 240 if you expect chicks to like it. Because they most likely won't. And if you want to find the thread, use the search button.
If you want to buy a car that chicks dig buy an M3 duh
Drifting10
nvm found it!
Mangid wrote:
"Where are your mirrors? I need to put makeup on"
"It smells like gas in here"
"What do you mean you don't have air conditioning?"
"Why don't you have an antenna? I want to listen to the radio"
"Why is your seat better than mine?"
"Do you drive like this all the time?"
etc etc etc
hoopD240
alright i have searched everywhere for this info and not much luck, i have no cat and want to get rid of the aiv or whatever since thats what its for, and i also want to remove the coal canister, can anyone give me a good link for these?
GranTurismoDriver
Car: Nissan S14
Is it possible to use a HKS Hi-Power exhaust on my KA24DET motor (now), and later use it on a SR20DET motor (later) by converting the upper components to bolt up to the turbo?
PapaSmurf2k3
Site Admin
You can definitely use the cat back, and yes as long as everything is still in the same place, there isn't any reason you can't use the whole thing. That being said, the odds of everything being in the same place after a swap (turbo mounting point to turbo mounting point) are very slim, so you might end up having to make something custom, or replacing your downpipe, or both.
PapaSmurf2k3
Site Admin
hoopD240 wrote:alright i have searched everywhere for this info and not much luck, i have no cat and want to get rid of the aiv or whatever since thats what its for, and i also want to remove the coal canister, can anyone give me a good link for these?
All I can say is do a search. Removing the AIV is pretty easy, just onbolt it, unplug it, and plug the hole in the exhaust.
