Mr. Bojangles89 wrote:
1) What grade fuel must be used? 2) What are the main problems people experience with them?
1. Premium. Minimum 91 octane. You can use lower octane in a pinch, but stay the hell out of boost, and you will most likely lose gas milage.
2. wiring problems due to a crappy install.
Scuffed_ChukiCoupe wrote:I got a set of rims, the fronts measure 235 45 17 the rears 255 45 17. So to make this fit, spacers? If so what size, and extended studs are a definite but should i get the longest? Fender roll?
Also another question. To tell that an s14 has a vlsd rear other than doign a burnout, the diff. cover should have fins on it right? thanks
We can't tell if the rims will fit just by what you gave us. It depends a lot on spoke design whether they will clear Z brakes or not. If not, get spacers (how big depends on how close they are to clearing the Z brakes). If you get bigass spacers (25mm), a lot of them have new studs right in them, so you won't have to get longer ones. If you go anything bigger than a 3mm spacer, you are going to want to get longer wheel studs.
Diff Covers- both have fins. The VLSD fin design is different. There should be an orange sticker on the diff. If not, and it still looks like VLSD to you, jack it up, put the car in neutral, and spin 1 wheel. The other should spin in the same direction.
