Fitment would be flush, and you shouldn't need a new ECU. Auto ECU's don't have a speed limiter BTW.BB1LOVIN wrote:i was thinking the same as well.Would the fitment be flush? Also would i need to change the ecu?
If the shell is clean (no rust, good interiour, no leaks, good glass, and if it has a good rear end (some form of limited slip)), you can expect to pay $1000 or maybe more, depending on your area. If the paint sucks, its got some rust, the interior is dirty, etc... you probably want to pay about $500.But it can fluctuate (think about what kind of suspension the shell has, etc).tyler240 wrote:Ok, Im very new to 240's but am in the process of buying one. A 1993 240sx coupe, its a manual and in decent condition but no motor. Will be a new project car for me, and will be doing the SR20DET swap sometime. My questions are:
What would be a resonable price for the car I mentioned with no motor?
How much would a SR20DET swap cost? Id obviously do it myself, but want to know what to expect financially.
This seems like a very good forum/club and I plan to learn alot here.
SR20's can also vary depending on if it as a redtop/black top, S15 SR20, etc.
For a red top, wiring harness, ECU, expect to pay about ~$2000-2500. Make sure you buy from a repuatable source, like a NICO sponsor.
dude... for $9k I'd build such a bad asss s13... like the badest one around...PapaSmurf2k3 wrote:The $9000 scenario is a semi-nice S14, lightly modded, etc. Just do a little research, and find out your wants and needs.
rolling chassis $500z brake + 5 lug swap $600coilovers + misc arms $2500sr front clip $2000used "ballerish" wheels $1700--------------------------------=$7300PapaSmurf2k3 wrote:You'd be surprised how fast 9k would dissapear into a 240.
James... don't you know I got the hook up LOLImma bargain shopper, the stuff I listed I overextimated for ballpark figures, not to mention I've seen pretty dope project cars sell for cheap. Like last month on Zilvia, I saw a rolling chassis forsale, came with 5 lug swap, z brakes, vlsd, gutted, coilovers, and arms for $3.5K. All it was missing was an engine. I can't wait to finish college dude, so I can actually have time to work on a real project, lolPapaSmurf2k3 wrote:don't forget building the motor, for that reliability factor (or the option of going for big power).Paint will suck up a ton of that cashdont forget a limited slip differentialnew clutch
dude, it piles up, and adds up. Don't get me wrong... 9k will get you a sweet ride
honestly, I'd ditch the sohc and boost a dohc.aformerfriend wrote:Hey there. Got an '89 240sx stock with SOHCJust a quick question, I have been wondering what I could do to my SO to boost its performance without doing anything drastic.I'm not looking for insane performance or anything.Just to have a bit of power here and there.Any ideas?
huh? I don't get what youre asking.aformerfriend wrote:What all would be possible to boost a DOHC?
as far as the engine goes, it really depends on who you know and where you go. I've seen ka24de's sell for $200 to as much as $700 (honestly, I wouldn't pay more than $500 on a ka24de).aformerfriend wrote:And how much would one run for?
well, if you do want to boost your sohc, I'd start out by testing it to see if it's boost worthy. Get a compression test and all the necessary precautions. 2nd, turbo manifolds for the sohc aren't gonna be cheap. I don't think chinese companies make any manifolds for the single cam, lol.aformerfriend wrote:I don't want to buy a KA.I was just wondering if anybody had any ideas on boosting stock motor.
hehe, he doesn't know that, that is why he is here!adrians_s13 wrote:what turbo are you planning on using? these are all things to consider
well, heres a link on how to install aftermarket inner/outer rodsJULES_S13 wrote:hey ladies and gents i need to change the inner and outer tie rod ends on my s13 i bought all 4 moog parts and all i need to do is install i also have the inner tie rod end tool and the grease gun as instructed that i would need by a friend does any1 have a step by step or a walk through for me?
thanks... jules
well you can if you want...shmex wrote:Hey what's up. So I just got a 90 fastback and I wanna upgrade the suspension to coilovers...
I was told that I can't just slap the coilovers on so what I'm wonderin is, what are the componenets needed for the coilover swap????
Thanx.
Any suggestions on reliable arma and tie rods???adrians_s13 wrote:well you can if you want...
but if I were you, I'd get rear upper control arms and depending on how low you wanna go, I'd get front inner and outer tie rods (aftermarket ones with the spacers at the outer rod ends) to change your caster and bump steer. When you lower your car, the rear camber dials in and front tow goes out, make sure you get an alignment asap after installation.
