I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
adrianfromthecastle
Car: 1992 Nissan 240sx
shmex wrote:
Any suggestions on reliable arma and tie rods???
basically anything not made in China, LOL.
If you're on a budget, I'd go with Tein inner and outer tie rods, and Power by Max rear upper control arms... both of which I found to be decently priced. You can get the tie rods from FRsport (i think theyre in Irvine) for like $130, and PBM rear upper control arms are like $180 (located in San Diego).
shmex
Car: 1990 CA18DET Hatch, 1992 Stock Coupe
Hey thanx dude...by the way do you go to any of the meets out here like the 818 or 626 one??? You should try comin to duce40sx's weekly house gathering.
adrianfromthecastle
shmex wrote:Hey thanx dude...by the way do you go to any of the meets out here like the 818 or 626 one??? You should try comin to duce40sx's weekly house gathering.
pff... dude, I used to be big into meets back in the day, ask anyone...
hell, I even started a thread that listed all the weekly socal meets (stickied in the california forum)zerothread/233523
but frankly, it got boring pretty after awhile. I dont even go to the ones I was supposed to be hosting, lol.
PapaSmurf2k3
Site Admin
ChickenWyng wrote:My brother just gave me his '91 240 and I am having idling and starting problems. At first it would start up and run fine but the tachometer would dip down when I was slowing and sometimes cut the car off. I changed the fuel filter and that didn't change anything but now the car won't start at all unless it has sat for a couple of days. I believe I might have to change the fuel pump, but I'm not for sure. If it does sound like the fuel pump, can anybody direct me to a tutorial or video on how to do it? I'm not a grease monkey but I learn fast so I have a feeling I might be able to do this with the proper guidance. Any help would greatly appreciated and thanks.
Well buddy if I were you I would start out by Seafoaming the car once you get it running. If you don't know what that is, you can search for it. Basically its a can of cleaner stuff you buy at NAPA and run through your brake booster line, and it cleans everything out. After that, your plugs (and O2 sensor) are going to be covered in all the crap you just blew out. You WILL need to replace them.
IIRC, if you buy a Walbro fuel pump (which you probably don't need), it comes with directions on how to put it in. To see if your fuel pump is working, make sure your radio and everything is turned down. You should be able to briefly hear a "hummmm" when you turn your key to the ON position (without cranking).
If you do that stuff, and stuff still doesn't work right, come back and explain whats going on, we will help you further.
onemad240
Car: 95 240sx base
I noticed that oil was leaking through the valve cover gasket, so i replaced the broken valve cover gasket and it stopped leaking so much, but it still leaks a little bit from the same spot. When i replace the gasket i didn't use any sealent because the valve cover already had a groove for it. Should i have put some gasket sealent in certain spots?...And I know that there is a sequence to tightenting the bolts on the valve cover, but i didn't find out about that until afterwards, could that have anything to do with it? Is there a red or bright color liquid that u can pour into ur oil filler to see more precisely where the leak is?
d0pe240
does anyone know the specs to the springs on the cusco zero 2e coilovers? like how tall the spring is, the diameter on the inside, and how wide it is on the outside? this is for the front and rears. i tried looking around, but couldnt find anything.
PapaSmurf2k3
Site Admin
onemad240 wrote:I noticed that oil was leaking through the valve cover gasket, so i replaced the broken valve cover gasket and it stopped leaking so much, but it still leaks a little bit from the same spot. When i replace the gasket i didn't use any sealent because the valve cover already had a groove for it. Should i have put some gasket sealent in certain spots?...And I know that there is a sequence to tightenting the bolts on the valve cover, but i didn't find out about that until afterwards, could that have anything to do with it? Is there a red or bright color liquid that u can pour into ur oil filler to see more precisely where the leak is?
You are supposed to put sealant at the cam shaft crescents. It helps the gasket to stay in place better. If it is still leaking, you can just take the cover back off, clean everything really well, and goupe it up a little bit in the problem spot. Silicone valve cover gaskets are relatively re-useable, as long as you do it within a short ammount of time (before they get hard and unflexable). I am unaware of any die that you can put in that would make it more visable. Make sure you torque the bolts down to correct torque ratings. Don't go more, its VERY easy to strip out those tiny alluminum threads (trust me, I know, I've done it).
d0pe240 wrote:does anyone know the specs to the springs on the cusco zero 2e coilovers? like how tall the spring is, the diameter on the inside, and how wide it is on the outside? this is for the front and rears. i tried looking around, but couldnt find anything.
Try asking in the wheels and suspension forum. Either that, or ask the vendor from which you would be buying the stuff from.
d0pe240
^ alright i'll do that. thanks.
Snott Rocket
Car: 1991 240sx, 1986.5 Toyota Supra, 1974 Corvette, 1962 Rambler Classic 400
I just bought all the parts needed for a 5 speed swap in a 91 HB. I even have the ECU and trans harness. I haven't started removing/installing any parts yet, but I'm wondering if it's possible to make the clutch interlock work without using the 5 speed dash harness. I have an FSM but wiring diagrams aren't my strong point. I tried searching but didn't see anything about making the interlock work.
onemad240
Car: 95 240sx base
alright thanks papasmurf
mr.lonelyS12
Car: S12
does the Unorthodox crank pulley for the ka24de need larger/longer belts?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
No.
mr.lonelyS12
Car: S12
hopefully someone can answer before the auction is over
mr.lonelyS12
Car: S12
thank you!
el OCHO
Car: 1990 rps13
1990 s13 DASH LIGHTS...when i got it, the tac lights were not workin. is it a fuse or is it the bulb?? i was thinkin if it is a bulb, could you tell me where i could find some new ones i was thinkin about some red or blue...thanks
redtop91
mr.lonelyS12 wrote:thank you!
No problem
el OCHO wrote:is it a fuse or is it the bulb??
Are your tail lights out? If so it's a fuse. The Blue 15 3 fuses from the bottom on the right.
el OCHO
Car: 1990 rps13
redtop91 wrote:
No problem
nope tails are good so it must be the bulb then ...any idea where i can find some coloured leds for them?
jay2pointoh
Car: 1995 nisan 240sx zenki
Just purchased my s14 for $2000 great price.its auto, has a cold air intake, cat back exhaust, and non SE.Looking for advice on getting drift ready for cheap and safe.I live 20min from XAT Racing and have talked to them already but still looking for tips from the community.Any and all advice is welcome.Thanks.
adrianfromthecastle
jay2pointoh wrote:Just purchased my s14 for $2000 great price.its auto, has a cold air intake, cat back exhaust, and non SE.Looking for advice on getting drift ready for cheap and safe.I live 20min from XAT Racing and have talked to them already but still looking for tips from the community.Any and all advice is welcome.Thanks.
cheap and safe: aftermarket lowering suspension (of even cut springs), a welded diff, and cheapo used tires. You got yourself an easy drift car.
When you plan on upping your game, thats when it gets a bit more technical and expensive.
redtop91
LOL. Are the words cheap and ghetto interchangeable?
adrianfromthecastle
redtop91 wrote:LOL. Are the words cheap and ghetto interchangeable?
haha depends on where you live
hud_240coupe
Car: 89' 240sx Coupe
Hi, I just bought a 89' or 90' automatic 240sx coupe. I'm not sure what year it is because I dont get it till next thursday cause I didnt have the whole 750 for the car so its still in the tow yard. So anyways its in decent shape as far as the outside and motor goes. It has tan interior and the dash is pretty cracked but otherwise its nice, just needs an alternator.
My question is this:If I have the HUD and digital speedometor as well as power locks and windows does that mean I got the higher end SE model or could it still possibly be a base model with added features?? Also what are the differences between the base and SE? THANKS.
adrianfromthecastle
hud_240coupe wrote:Hi, I just bought a 89' or 90' automatic 240sx coupe. I'm not sure what year it is because I dont get it till next thursday cause I didnt have the whole 750 for the car so its still in the tow yard. So anyways its in decent shape as far as the outside and motor goes. It has tan interior and the dash is pretty cracked but otherwise its nice, just needs an alternator.
sounds like you have an SE.
jose_s13_ka24de
Car: 240sx s13 ka24de
does any1 noe where i can find a ka24de 5spd transmission ???? it keeps telling me i dont have the permission 2 be in that forum . . . wat i have 2 do 2 change that ???? i have more exhttp://forums.nicoclub.com/zeropost?cmd=reply&id=3276682#zer...ience than most the forumm kids do . . . (smh)
jose_s13_ka24de
does any1 noe where i can find a ka24de 5spd transmission ???? it keeps telling me i dont have the permission 2 be in that forum . . . wat i have 2 do 2 change that ???? i have more experience than most the forumm kids do . . . (smh)
Snott Rocket
jose_s13_ka24de wrote:does any1 noe where i can find a ka24de 5spd transmission ???? it keeps telling me i dont have the permission 2 be in that forum . . . wat i have 2 do 2 change that ???? i have more experience than most the forumm kids do . . . (smh)
You need 10 posts to be in the for sale forums
hud_240coupe
thanks....so does an SE model have any changes to the suspension?
adrianfromthecastle
hud_240coupe wrote:thanks....so does an SE model have any changes to the suspension?
not unless you have the HICAS version, they came with a larger sway bar. SE's may have ABS, but that's about the only difference in regards to upgrade. Engine and suspension is the same.
Otherwise, the main difference between SE and base models are just the luxury power options.
jose_s13_ka24de
can any1 tell me wat i need for auto 2 manual ka24de swap . . . 1992 se besides the transmission
jose_s13_ka24de
and how a sr swap would be with all the componets static/icons.html#http://forums.nicoclu ... icons.html#
