I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
Scuffed_ChukiCoupe
Car: Ka-t coupe
thanks, i got a set of 2005 maxima hid's not sure the number. I wanna put them on my s14, do you kno where i could buy those glare guards? Its better than nothing.
PapaSmurf2k3
Site Admin
Scuffed_ChukiCoupe wrote:dammit papa i feel hurt. My questions went unanswered. (second and third posts of this page) ty
haha, I'm not a JDM kinda guy. If you wanted to put a rocket on your car... I'm the guy to talk to.
shmex
Car: 1990 CA18DET Hatch, 1992 Stock Coupe
PapaSmurf2k3 wrote:chances are that if it was waterlogged, it needs to get replaced reguardless. The only other options of why your window will not work are: The switch, and the motor itself. If you want, you can try putting power directly to the motor to see if it still works.
Hey thanks papasmurf...it was the relay that failed to bring my window up. Went to the junk yard this morning. Got the relay of a z32...wich had the five lugs...got trans boot, air conditioning lever, bunch of the panel buttons to hold on the panels, and a full dohc gauge cluster...plus some 280z memrobilia..al for 30 bux!
They only had three s13..and one had both quarter glasses...and both were perfect....I just didn't know how top take them off...two piggies (1 coupe 1 fastback) 1 chuki. Yee yuhh!
Thanx for the help again.
RustyHampster
Car: 1990 240SX HB
Dude, with 7k-10k you could get a flawless 240 with low miles. Probably one with a swap already. Just wait for a good one though. and even if a 240 breaks down, the parts are sooooo cheap.
adrianfromthecastle
Car: 1992 Nissan 240sx
RustyHampster wrote:Dude, with 7k-10k you could get a flawless 240 with low miles. Probably one with a swap already. Just wait for a good one though. and even if a 240 breaks down, the parts are sooooo cheap.
ya ofcourse.
Scuffed_ChukiCoupe
Car: Ka-t coupe
well lets get that rocket going lol
hahanoonehasthisnameyet
Car: 91 hatch ♥
Hey, I was wondering What is 'HICAS' And what years of two40's have it?That and Iknow the older 240's are called pignose right. Whats the other one that well.. isn't pignose. Are there any particular models of two40's and year people strive to find? If so, Why so?
s14tan
Car: 95 ZenKi SE w/ S14 SR GT28r and bolt ons
Hi Guys! Im new here and I would like to know what this is.
Scuffed_ChukiCoupe
Car: Ka-t coupe
hahanoonehasthisnameyet wrote:Hey, I was wondering What is 'HICAS' And what years of two40's have it?That and Iknow the older 240's are called pignose right. Whats the other one that well.. isn't pignose. Are there any particular models of two40's and year people strive to find? If so, Why so?
This thread should answer those questions
zerothread/183490
PapaSmurf2k3
Site Admin
s14tan wrote:Hi Guys! Im new here and I would like to know what this is.
Is that a legit question, or are you stirring ****?
You'd probably get a better/faster response with a "I need help Identifying a turbo" type of thread in either the 240 gen or the KA-T or SR forum. You also might want to get some more shots from different angles. My guess is a Garret super 60? I'm not great at identifying turbos though.
s14tan
I was just messing with you guys.
Scuffed_ChukiCoupe
Car: Ka-t coupe
what about identifying a rocket to strap to my zenki so i can beat super fast civcs with k-series type r motors
Car: 91 hatch ♥
Nos...it straps on your ride too. All the drifer's and show cars use it... Oh and those dingling dice mirror things add 10 hp too...
But hey I got a SERIOUS question... Say I was going to buy a 240 coupe. 93 and under you know. Ne old coupe would do or is there a "oooooo SE model" supirior to others..?
That and whats HICAS?
adrianfromthecastle
hahanoonehasthisnameyet wrote:Nos...it straps on your ride too. All the drifer's and show cars use it... Oh and those dingling dice mirror things add 10 hp too...
Honestly, if I could chose, I'd get an SE. I hate manually rolling my windows.
HICAS is, in short, is 4 wheel steering. Great for auto-x, bad for drifting.
Scuffed_ChukiCoupe
Car: Ka-t coupe
came in hatches only btw
ka-t4u
hi guys do you think it is possible to eliminate my iacv system and control my idle with my throttle body only? i already posted an the KA forums but maybe here i'll get a quicker response, any input will help, it is a ka24de...
vda240
Car: 97 Nissan 240sx
Quick question, I'm looking around for some wheels & tires for my 240 (1997) and was wondering what tire sizes that will fit a stock 240 without rubbing? (I was thinking 245's on the back, 225 on front) my car is not lowered right now, but im planning on lowering it with eibach sportlines or tein's s's.
Car: 91 hatch ♥
Adrian, Thanks for the hicas answer
PapaSmurf2k3
Site Admin
ka-t4u wrote:hi guys do you think it is possible to eliminate my iacv system and control my idle with my throttle body only? i already posted an the KA forums but maybe here i'll get a quicker response, any input will help, it is a ka24de...
I beleive it is possible, but it doesn't work as well. KA-T guys used to do it fairly often. I would think it would also work if you drilled a specific sized hole in your throttle valve to let in air. How big? That I do not know. Start small and work your way up? The other way to do it would be to adjust your throttle cable so that it keeps the valve cracked a little bit.
PapaSmurf2k3
Site Admin
Scuffed_ChukiCoupe wrote:what about identifying a rocket to strap to my zenki so i can beat super fast civcs with k-series type r motors
First, select your rocket. I reccommend anything bigger than 800 lbs of thrust. After that, we have to design the rocket holding system to be tailored to that specific rocket.
Scuffed_ChukiCoupe
Car: Ka-t coupe
I messed up one of my headlights, and i need to bring it back to life. I used meguiars platx polish and it worked, but i still saw traces of yellow in the plastic. So i took it upon myself to sand it with the polish. My uncle gave me 400 grit. So after that i wet sanded it, dont think any of that made a diff. SO now i have a clear headlight and an ashy headlight. How do i bring the ashy one back to life.
RCG_Savage
Car: '92 240sx fastback
Could some one explain how exactly what a 8:1 or 12:1 FMU means. I'm slowly buying all the parts I need in order to turbo the KA and I'm currently confused when it comes to the fuel system and pressure.
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
so i was talking to this guy the other day. he had a celica and he had just got it and he was dying to show it off to someone. so we are talking and he revs it up to like mach holy sh*t and the he tells me its supercharged. i laughed and i told him to open the hood and show me. he goes on about how fast this completely stock celica is and then tells you can get up to 10 hp by tightening up the battery terminals.
well im new here, i drive a completely stock 1993 240sx fastback.just got it a little while ago and im saving up some money to buy some coilovers or just springs.
PapaSmurf2k3
Site Admin
RCG_Savage wrote:Could some one explain how exactly what a 8:1 or 12:1 FMU means. I'm slowly buying all the parts I need in order to turbo the KA and I'm currently confused when it comes to the fuel system and pressure.
FMU stands for fuel management unit... I think. 8:1 means that for ever 1 psi of boost, the FMU adds 8psi of fuel. 12:1 adds 12psi for every 1 psi of boost. You should be just fine with 8:1, but don't run more than about 7 lbs of boost with it. Make sure you get a better fuel pump than stock.
Scuffed_ChukiCoupe
Car: Ka-t coupe
hey pa pa whats your thoughts about that ellis hobbs character.... and his "stellar" performance.
PapaSmurf2k3
Site Admin
If you really want to know... I think the giants are a bunch of cheaters and faked those 2 injuries in the pat's last scoring drive. That enabled them to have enough time on their final drive to get down the field and score. That being said, Brady was off all night, and was throwing like crap. That and he got sacked a whopping 5 fuggin times. Matt Light was sucking out loud, and the reffs were making far too many calls in favor of the giants. There also should have been a fumble recovery or 2 to go towards the pats... but whose counting?
roy23pim
Car: 1995 Nissan 240sx
will the 5 lug conversion from a 300zx n/a fit on my s14 240sx?
Scuffed_ChukiCoupe
Car: Ka-t coupe
The front yes, the rear will need more parts to fit i belive.
roy23pim
sorry to bug so much with this easy stuff .. but do u know wat parts i will need?
Nali
Car: Datsun Nissan 280ZX
Real noob question here. Is it wise or even pratical to get a stock 240sx and do a CA18DET engine swap for it. Just really curious as the CA18DET isnt too expensive and is quite a potent engine.
