Hxc_Nismo RB26 Build Thread- UPDATE 1/29/14
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
here is my write up on the rb quest alternator swap
rb-quest-alternator-swap-write-up-t532816.html
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
my parts from the machine shop will finally be shipped out to me monday, and i have to get the other half of my intake polished and finish the assembly of my engine. Im going to be towing my car to my work hopefully next weekend to start on the body and paint.
so stay tuned for future updates....
Beat92240
Car: R33 RB26 S13 Coupe
Damn you are a beast man! that alternator write up will be great for mine! looks like i'll be adding that on to my list of stuff to do! I'll be checking this out in the future to help me move along with my build since ur a little in front of me. Keep it up.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
thanks for the comment
well on the other note, i believe im going to put off the body and paint till winter cause it will take about 3 months or so to do, so i want to get her back on the road for the summer cause i have not driven this car since november 2009 and im way past due for a drive in a real car.
blazin240sx
Car: 1993 Nissan 240sx coupe
its a sic s14
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
thanks blazin
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
well I should have the last of my parts to finish my motor tomorrow and I will need to drop my intake off at my polisher. while I'm waiting on that I will also ship out my power fc to apexi to recalibrate it for my 4bar map sensors. I then can also finish installing the timing belt, front covers, crank pulley and drive belts. Then the polisher should only take about a week or so and then i can finish the motor and drop it in and then finish my plumbing and mount my oil and p/s coolers. Then when i get the motor back in, I will build my custom downpipe and intercooler piping, break in the motor, clutch and lsd, then its off to AMS for my 93oct with meth tune (shooting for 650rwhp) and then a race gas w/ meth tune (shooting for 800-850rwhp). So stay tuned for the future pics and updates. :naughty:
leekim
Car: 1995 240sx
hey nice clean build...which crank damper and powersteering pump are u using?
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
well i got my parts today, and they forgot my crank pulley bolt and did not finish modifying my greddy intake plenum for my power fc IAT sensor to fit, so I need to take it to the machine shop here this week to have him modify it for me. But today i came across a deal i could not pass up today and it involved a R32 RB26 long block and i just took the crank pulley bolt from there. So here are my progress pics i got done today after work.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
leekim wrote:hey nice clean build...which crank damper and powersteering pump are u using?
im using the r33 rb26 ati race dampner, and im using the r33 rb26 power steering pump
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
well i had my plenum modified for my pfc iat sensor which is smaller then the oem iat sensor. so I had the original hole tig welded shut and i drilled and tapped it for my power fc IAT sensor. I will be calling my polisher tommorow to have him come pick the greddy plenum picked up and polish it and smooth out the weld on the inside of the plenum, here are the pics of the current progress.
Jimefam
Wow almost there huh? Looks amazing and I love seeing your build as it's so similar to mine it gets me giddy. Looking at this thread from beginning to now I'm amazed at your patience and attention to detail. It's been almost 5 months since my motor blew and I started my current build and it feels like an eternity. I'm lucky there's your build and lots of others to draw knowledge and inspiration from. Keep up the good work.
bmxarmy
Car: 1961 AMC Rambler
Well said Jimefam, Its builds like this one and yours and Kevwa's that keep me motivated on the Rbambler!
Keep up the good work guys!
nolan
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
thanks for the comments guys
SlowKoop
Car: 350z s13 coupe
Hey man I just wanted to ask a question about the surge tank you have because I'm looking at the same one on ebay. Are the threads in the tank 6an also? I want to run an aeromotive 1000 but i dont want a 6an line going to it.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
you can change em to what ever you want, i think they can go up to -10an or -12an not 100% sure but im running dual feed bosche 044 in line fuel pumps and it should be good for about 1200hp.
SlowKoop
Car: 350z s13 coupe
Yea i thought about dual Bosch pumps but I'm looking at 750-800 hp at the most, so I figured an a1000 would do me justice. The only thing that scares me about the dual pumps is one going out and popping the motor.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
SlowKoop wrote:Yea i thought about dual Bosch pumps but I'm looking at 750-800 hp at the most, so I figured an a1000 would do me justice. The only thing that scares me about the dual pumps is one going out and popping the motor.
well dual Bosche 044 pumps are alot more reliable then dual walboro pumps, but thats why I have a wideband and also a in cab fuel psi gauge so if one goes out Ill see it.
SlowKoop
Car: 350z s13 coupe
I understand where your coming from. I'm loving the build and I'm considering all of the things you do because my build is pretty similar. Keep up the awesome work.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
here are the updates...
I had my greddy intake polished and I installed it tonight and here are the pics
Im going to have to take it back off because the two sets of thermo gaskets are causing issues with with my throttle body linkages, so im going to pull one set off and put my tomei metal gaskets between the TB's and Intake plenum tommorow and readjust the TB linkages so I get 100% open throttle.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
looks awesome Hans... loving the progress :yesnod
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
Coolwhip wrote:looks awesome Hans... loving the progress :yesnod
thanks Rick :naughty:
Tanman2010
Car: 1995 240sx KA-T - Sold
1995 Eclipse GS-T - Sold
2003 Evolution VIII - Sold
2004 Track Edition 350z with Nismo R-Tune Package
"HxC_Nismo" this is one hell of a nice build, nice to see someone who is putting alot of time and money into a swap and doing it right. How much is this swap running you all in all. Ive got about $30,000 saved up to throw into my 350z Rb30det project and im looking to "spare no expense" when it comes to the swap, so im just trying to get a nice round figure from you so i some idea on money, even tho our projects are a little different . Keep up the good work :dblthumb:
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
Tanman2010 wrote:"HxC_Nismo" this is one hell of a nice build, nice to see someone who is putting alot of time and money into a swap and doing it right. How much is this swap running you all in all. Ive got about $30,000 saved up to throw into my 350z Rb30det project and im looking to "spare no expense" when it comes to the swap, so im just trying to get a nice round figure from you so i some idea on money, even tho our projects are a little different . Keep up the good work :dblthumb:
I have a lot in my build, but your $30k should get you where you want no problem, but let just say if i sold my car i wont get my money back.
Beanstalk
Car: 89 240sx & 95 240sx
Bump for the Real Street Rb26deT... Hans lets try and hit the exact same numbers ...lol
el-biejon
Car: 240sx
HxC_Nismo what map sensors are u gonna use with the power fc?
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
el-biejon wrote:HxC_Nismo what map sensors are u gonna use with the power fc?
GM 4 bar Map Sensors x2 good for about 40.5 psi of boost
gawdzilla
Car: none
most people get the vacuum signal from the same source anyway (off the PCV area), so you can just use one map sensor and splice the signal to the PFC. I've got two apex sensors on mine but should really consolidate to one and keep the other sensor as a spare.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
Well guys sorry for the late update, but I have been busy lately with losing weight, i had to do something otherwise i was going to be to big to even drive my car or even get sick from being overweight. So i have changed my lifestyle completely around. I have become vegan and i have been going to the gym 5 days a week doing cardio and weight lifting. As you can see in previous post of me with my engine I was weighing in at 340lbs, I now weigh 238lbs and can now comfortably fit in my car now lol. But now that i accomplished my personal goals, I will be starting on my car starting tonight or tommorow, and working on it through out the winter, and trying to get it done by spring of 2012, and have chris black at AMS tune it for me. So Stay Tuned cause there is a beast coming in 2012 and your going to see Godzilla on steroids lol.
Madhatter969
Car: 95' SE s14 - build project
05' Evo VIII - DD
Congrats man, cant wait to see this thing!
