My head has been ported and polished, gasket matched on the exhaust ports, tomei poncams type b 260 cams, tomei cam gears, 3 angle valve job with ferra valves, supertech dual valve springs w/ titanium retainers, super tech valve seals and seats, stock solid lifters, tomei cam cap studs, mines valve cover baffles, greddy intake plenum with sikky performance thermolator intake gaskets, full race response turbo manifold w/ arp exhaust manifold studs, tomei oil orfice, and head oil drain mod. Also im using a turbonetics 1.0 divided hot side on my precision dual ball bearing air cooled 6765 running 3.5" turbo back exhaust.RRRRB wrote:Yeah 800whp shouldnt be an issue, I made 760 on 30psi pump e85 on 6766.. it easily would have made 800 if I had the injector. 6765 is a little less efficent but shouldn't have issue hitting 800.. most people making 900whp+ on 67mm turbos are on super efficent setups..big time ported heads, huge cams etc. And using the bigger H cover compressors and big turbine hosuings..
I didn't catch what you has done in terms of cams and head work.
sorry for the bad link... here she is running and finally alive...HxC_Nismo wrote:She is finally alive, had a couple of bugs to work out but got em fixed. Now I just need to adjust the fuel maps so i can break in the engine so I can go get her tuned.
Here is the video that was taken today...
https://m.youtube.com/?rdm=1l0oglmx&cli ... SbGEYDWtv4
Oh I know but RawBrokerage hooked me up at a lower price so thats the only reason why i just picked it up from them.RRRRB wrote:Looks great, i just converted to crank trigger myself.. That Ross kit is SOOO over priced its rediculous.. I made my own for 300 bucks total
thanks man I appreciate itDarius wrote:Hans,
The car looks amazing! I'm impressed with how far you've come since we met in Iowa several years ago. Looking forward to the dyno results!
+1 there hasn't been enough cool posts on this forum in a long time. Break up the boredom.RRRRB wrote:common man!! i wanna see what she lays down!
Well i am still trying to source a trailer and I still need to set an appointment with my tuner but he is about 6 hours away from my home.RRRRB wrote:common man!! i wanna see what she lays down!
