Hxc_Nismo RB26 Build Thread- UPDATE 1/29/14
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
I'm loving it. More pics!
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
sorry but my machine shop took longer then expected, i should be able to go pick up my motor this coming tuesday and then the car will be going to the body shop once i put my rear subframe back in on my next day off. then ill be putting the motor back together and have it prepped and ready to go in once the car comes back from body and paint.
ill have new picks up soon.
proto45
Car: S14 soon to be swapped... for an RB26!
subscribed :mike :
Any updates?
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
Sorry about the delay of keeping this thread up to date. I have been real busy with other important matters. Well i picked up my rear knuckles from Torres Machine Shop in Temecula, Ca and he just installed my SPL Solid Monoball Bushings wich replace the factory pressed in rubber bushings. So now since i had my knuckles back i went ahead and finished assembling my rear sub frame and suspension.
Here are the pics...
So Im going to install my R33 e-brake cables, and I need to run my fuel lines before i can install my sub frame. I need to order new z32 rear e-brake shoes and then i can finish the rear brakes. Then Im then going to go ahead and get the car ready for body and paint. When the car is gone for paint, when i get the engine back from the Torres Machine shop i will be able to finally assemble my engine and get it ready to drop into the car. so stay tuned for future updates.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
well i finally got the rear subframe installed
installed the r33 ebrake cables and the z32 ebrakes
installed the z32 brakes and powerslot rotors
installed my rear tanabe underbrace
tomorow I will be installing my tein rear coil overs and my rear sway bar.
so stay tuned
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
I was meaning to post these last night but forgot to so here are the pics of my tien flex coilovers installed and my whiteline rear sway bar installed.
Today I am planning on replacing my speakers in the car and do an eyeball alignment on the car and get it on the ground to see how she sits.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
well i got my new alpine speakers installed and adjusted my rear suspension and sat it on the ground. im going to wait till I get the motor back in before I do my final height adjustment. here are the pics I took of my recent progress.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Looking Good man!
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
That looks solid as hell Hans! Keep up the good work :mike
74260zt
Car: rb26powered early 74 260z car
Darius wrote:That looks solid as hell Hans! Keep up the good work :mike
I agree ^^
Very impressive!
Madhatter969
Car: 95' SE s14 - build project
05' Evo VIII - DD
Just wanted to say incredible job on the build. Keep it up!
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
well guys I'm moving back to missouri, so the car is going to have to be put on hold again but i will have pics up of the motor here very soon so stay tuned :chuckle:
Madhatter969
05' Evo VIII - DD
Where at in missouri are you moving back to?
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
Why where are you from
Madhatter969
05' Evo VIII - DD
Just curious man, I'm here in gay a** arkansas. Northwest, about 30 minutes south of joplin.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
yea im alot further north then joplin, im by Jefferson City
Madhatter969
05' Evo VIII - DD
yeah, a bit aways. Have you heard of any meets in the MO/AR/OK areas? Great work on the project too, i'm definitely using some of your ideas on my build up!
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
yea we have 2 meets every year in missouri, there is a meet coming up in june 2011. check out http://www.midwestce.net its our local forum for the midwest states so check it out.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
well the Beast is coming back home to Missouri, I will be towing her back starting tomorrow morning from Murrieta, Ca. I will be checking on my motor today and it should be done but I have heard that before many times before, but this guy is a perfectionist and takes pride in his work so it doesn't really bother me as long as i can get my motor before i finish moving. so my build is on hold until i finish moving back.
bllabong89
Car: 1995 s14
oh damn...I hope I get to see this thing cruisin thru Missouri. Where are you moving to?
ralphsdiorama
Car: 1991 240sx, 1998 240sx (RB project)
I fear my kouki will find this thread and then disown me. Great work! Keep those updates coming.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
here are the most recent pics my friend took for me last week.
the long block is done, the 3 angle valve job, port and polish head work, and valve lash. now im just getting intake manifold modifications and my head oil return mod finished and ill finish the motor assembly when i am finished moving.
RocketOgre
Car: 1989 240sx
Love the car and love the wheels, can't wait to see it all put together!
l0nestar
2004 Toyota Altezza
I like.
What is the red material on the block? Gasganich *SP? or some other slick coating to enhance flow?
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
l0nestar wrote:I like.
the machine shop painted it for me so im assuming its for flow, and or corrosion resistance
blazin240sx
Car: 1993 Nissan 240sx coupe
dam its gonna be one powerful rb26 and will be worth it
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
there will be alot of new updates when i finish moving back to the midwest so stay tuned.
meet07
Car: 89 180sx rb25det
Did you have to upgrade the sprngs/retainers and all with the 260 degree cam install??
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
no i didnt have to cause they were the poncams which only came with 9.15 of lift but i upgraded everything except for the lifters anyways.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
Well I picked up the engine up last night and now I just have to do final assy.
Here are some cell pics
