tramp_drift240 wrote:HVP, on a scale of 1-10, whats the difficulty in getting the upholstery to form to the molds on the door panels?
Actually, when I took that picture it was the night I had just started putting on the fabric.
And its actually real silk, and at 11 bucks a yard it better be..
Its not really hard in the sense that i over lapped the whole insert then cut and trimmed the material to fit the door pan, I also did the headliner and glove box.
Just buy a GOOD upholstery glue and prep the surface with a rubbing alcohol of sorts to clean the glue and junk off the door pan.
Then spray your glue and start pressing in the material to the door then with a good razor trim the excess. let sit for a day and your home free.. JDM interior! Just take your time no rush and itll come out fine and if it doesn't pull it off and re glue!
