This is the diagram i used. The switch was like 4 bucks and i had some extra wire laying around. Basically what the switch does, it interupts the power to the headlights when you push the big light button on or off. So you push the button flip the lights up, then you flip the little switch to off, then you push the big button again and you will see the lights wont flip back down. Heres the tricky part, you have to flip the little switch fast enough (on then back to off) to get the headlights down to the height you want them at. You get used to it and can do it on the first flip like me
Ive been thinking of revising that. Instead of a flip switch, i would used a rotary knob to control power flow to the headlights so the go down slowly enough to your desired height. So off to radio shack i go to test out my little theory....
http://www.imagestation.com/pi...2.jpg
