RobsPages wrote:
You're gas tank has an overflow valve that spills gas onto the pavement should you push too much into the tank. Trying to fill it all the way to the top is a waste of gas and money. When the fuel gauge says "empty" the Versa should take about 11 gallons (the other 1.5 are "reserve") unless you realllllllly stretched it.
What do you mean by "empty?" When the gas light goes on or when the gas gauge falls below the last line? Last time I filled up was about 3 miles AFTER the gas light went on, and the car took 11.7 gallons.... and that was just a hair above the last line on the fuel gauge.
The reason for trying to fill the tank with a max amount of gas is to fill the given volume to the max, so after you use an X amount of gas from that volume, you can fill it to that max volume again to see how many gallons of fuel you used.... I'm not sure how you can get an accurate reading of EXACTLY how many gallons of gas you used if you had unfilled volume in the gas tank. Sort of similar to that problem... you have a 3 and a 5 gallon jug, fill the 5 gallon jug with exactly 4 gallons of water; one of the jugs has to be filled to the max volume to get an accurate reading later on. So when I wait until the over spill; I'm ASSUMING that I have filled the max volume availible with gas and the deducation can start from there until my next fill up.... Not really sure how you can figure out exactly how much gas you used by counting the # of clicks the pump does before stopping since you don't know how much empty volume you have remaining.
srellim234 wrote:I agree with you, but I was responding to repind's blanket statement about everyone being wrong who claims over 40 mpg. There are one or two people who are legitimately getting that figure, but they are way out of the norm.
I guess I should of made myself a little bit more clear. 40MPG can be achieved in perfect conditions.... driving on the highway, windows closed, hyper miling tricks etc. What I meant by almost impossible is achieving 40MPG in more realistic driving conditions.... say 50/50 city/highway, windows open or AC etc. And if you actually read what I said, I didnt say it was impossible... I said it was very improbable.
