I have a feeling it's something to do with the programing code of the ECM.srellim234 wrote:I think this one........
** snip **
.....or cause the engine startup problems.
I think there may be something to that. Are most of the folks with significant mpg issues on the CVT? Some factory may be setting the ECU to the wrong mappings for that transmission.DejaWiz wrote:
Maybe the vendor mislabeled some ECU's or the factory installed the incorrect units. There's eight different modules, after all:srellim234 wrote:It could very well be. But why would that programming error, hard coded, be only throwing off a few cars and not others? I'm not an expert by any means, or even knowledgable about the intricacies of that type of programming, but unless there are variations in the program why would there be variations in the output? Don't they download the same software package into each car?
By auto, do you mean the traditional 4 speed automatic or the CVT? If it's the latter, I'd expect your readings due to the type of driving you do.repind39 wrote:I might add that this first trial was with using the AC 100% of the time, not much highway driving but not "city" either... just regular roads that average around 35 mph with stop lights every 1/4 mile of so.... I also drive normal, consistant acceleration, do the speed limit etc. I'm hoping this MPG reading will go up when the AC won't be used.
I have the same problem. I have a real hard time getting past 300 miles on a tank.. unless I'm on the freeway.repind39 wrote:Just got back from my 1st fill up (car has 17k miles BTW and auto trans).... got 289 miles out of 11.7 gallons = 24.7 MPG. I am greatly dissapointed as this car was mainly to save money on gas.... I have 95 Nissan Pickup, 4X4, stick shift, 150k miles with the classic KA24 that gets a solid 20 MPG so getting a little under 25 MPG on a relativly new Versa is a complete joke.
Unfortunatly, the "auto" that I meant deals with the above quote.Ever Victorious wrote:if it's an auto... damn, that sucks.
I can understand your frustrations, as I'd be feeling the same way if I were in a similar situation.repind39 wrote:I just have a crappy feeling that getting rid of the 04 Civic might of been a bad decision but time will tell, sorry for the rant, still a little pissed off at how things are unfolding.
Don't keep your fingers crossed. I sent a couple of emails to Nissan customer service and a few other Nissan contacts with links to both this forum and certain threads that would hold a lot of value to them as to what their customers are saying about Nissan and its Versa. References to problem threads, too. They absolutely ignored me, not even acknowledging that they got my emails. Even though they're not #1, I guess they're still too big to care about the customer.dauphine wrote:I hope that some of the 10,000 plus views of this thread include a few Nissan execs, perhaps it will inspire a bit of investigation into the Versa's inconsistent fuel economy issues. Hope springs eternal.
Miles per tank is pointless in a discussion of gas mileage numbers. You could be filling up after 9 gallons or 11 gallons. Big difference on mileage depending on which it is. It's necessary to do the math to see what you are burning per mile.Shad0wXCalibur wrote:My mileage isn't the best but it's not bad. The most miles to a tank I've managed to get is around 320 miles. Maybe that will improve as it gets driven more. I am just a little bit disappointed that an 08 car is not any better designed for gas mileage than my piece of crap high mileage Neon from 12 years ago. That thing managed 370 miles to a tank twice before and it has a big slow 3 speed automatic.
I agree, the people who posted getting 40+ MPG had to do something wrong... I would go as far as to say that its not impossible, but very improbable.longo wrote:I do think there is some really Bad Math on this forum.
This was probably mentioned in this forum a dozen times but the easiest way to calculate gas mileage is to top off your car to a point where gas almost spills out (or squirts out a tiny bit), drive a X amount of miles (100+ miles to get a decent reading) and then top it off again at the same gas station and see how many gallons went in which is shown on the pump.... then divide X by # of gallons that went in.
Hypermileing scares the crap out of me - the car should never be turned off in transit or you're gonna have a bad time.srellim234 wrote:Two ways to be getting over 40 mpg out of the Versa:
1. Serious hypermiling, of which we have one or two people on this forum.
2. If 99% of your miles are running at about 45-55 mph with no or very few signals and the ground is flat. I personally experienced 40 mpg up and down Highway 98 on the Florida panhandle on my trip there. The CVT cruising down a highway at the 1800-1900 rpm level will be right at about 40 mpg. Anything outside of that rpm range is going to kill the gas mileage a good 20-30%. This car's efficient operating range is really narrow.
As for fill-ups I let the pump run until it clicks off. I give it a few seconds to settle, then slowly fill until the pump clicks off again. That's usually another 1-1.5 gallons. I get consistent fill-ups that way without any spillage. Since I track every tank, any difference averages out over time anyway.
