How do I change low beam bulbs?
garland8402
Car: 2012 Nissan Rogue
I've already researched and have seen videos on how to change the bulbs for the high and low beam. However when I untwist and remove the piece where the low bulb is, there is no bulb at the end (just a plastic knob?). Is there something I'm not doing? Can someone please post a video or picture on replacing just the low beam bulbs on a 2012 Nissan Rogue?
Thank you in advance,
Garland
D1dad
Car: 2021 Nissan Altima SR
2018 Nissan Rogue Midnight
2009 Nissan Altima SL
I’m confused. There’s no bulb to change? I assume your car has halogen bulbs? I’m not familiar with a 2012 but I switched my wife’s 18 to led’s and I was able to access everything from the top. My 09 Altima requires going through the wheel well. If the bulb is burnt out and worked at 1 time then there has to be a bulb there unless it fell out and is in the housing.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
D1dad wrote:
Mon Jul 26, 2021 4:00 am
I’m confused.
Me too. Even if you have xenons there's still a bulb, it just attaches differently. Maybe you can post a pic of what you're looking at?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
garland8402 wrote:
Mon Jul 26, 2021 3:15 am
Garland
Yeah, there's something amiss here. Until you post a video or picture(s) we're working blind. Is yours equipped with HID or Xenon?
Here's a discussion with a video on replacing a bad HID ballast on a 2010. If that's possibly what's wrong with yours then the replacement procedure will be EXACTLY the same for your 2012.
2010 Rogue replace HID ballast
And here's another discussion on replacing the low beam on a first gen (which is what you own).
HID low beam bulb replace 2010 Rogue
Also for fist gen Rogue - DIY: HID / Xenon Lights Install
garland8402
Sorry for the confusion and no pics but the video posted by Rogue One was what I needed (the video about the 2010 Nissan Rogue low beam bulb replacement). Thank you everyone!
Return to “Rogue Forum”
