ken240sx »
https://forums.nicoclub.com/ken240sx-u27409.html
Sun Sep 03, 2006 7:22 am
welcome to the world of home painting lol, luckily when i'm ready to paint my school will let me use their garage, paint, and any tools...so it's all free lol! but anyways, it's important that you find a day with really no wind at all. you wouldn't want that great paintjob i know you're going to do get ruined by a few leaves or specks of stuff flying into it, that would suck. just for a little advice about bondo, i saw when you shaved your rear marker you used a nice chunk of bondo, it's good that you used the metal screen for support, but if you end up shaving something else i would suggest brushing a little fiberglass resin on the screen and surrounding area and put a piece of fiberglass matting that's saturated with resin over top of it, and then brush more fiberglass on it. let it dry, then bondo it. i only suggest this because you really want to use as little bondo as possible as it will crack with very little effort, it's also very flammable. the fiberglass would just be an extra piece of mind knowing that your bondo isn't going to crack. but so far the car looks great...before you paint it also spray each panel with a mild degreasing solvent so its shiny, and that simulates what the car would look like painted and clear coated...this will allow you to see any uneven spots or flaws. if it's all ok then just wipe it off and go at primering it up, if not then fix it, spray it again, wipe, then primer. good luck man, i hope everything goes well.
