FattyMcBaggins »
https://forums.nicoclub.com/fattymcbaggins-u24900.html
Mon Nov 06, 2006 7:51 pm
Could you post a pic of it next to a wall or something? Outside, with the camera behind the back of the car, looking down the side? My only reccomendation would have been to use a block for all of your sanding, beacuse a hand will wave a surface. Also, I'd only ever use soft glaze putty as a finishing filler, after primer. Tends to not hold up as a base filler very well. Metal 2 Metal is the best filler on the planet. Has a lot of aluminum in it so it will not crack because of temperature changes and such. And a layer of filler primer all blocked down before paint would've really smooth everything out. And set down that buffer! Wet sand the clear coat with 1500, 2000, and 2500. Then use heavy, medium, and light buffing compounds
