Not expecting that. Just building anti-squat.spank044 wrote:Good luck getting your 240sx to lift on launch.
okWDRacing wrote:Like I said, I cut 1.6's and I HAVE SOFT SUSPENSION. That's fact...no need to argue anything on my end. We're talking about eeking every last bit of performance out here. Which is a conversation that I don't even fit in
I'm new to the humility thing.. lolWDRacing wrote:I'm not really debating anything brosef. I know that a properly tuned suspension is better then something that's just soft enough to assist with loading the tires enough to help me go fwd instead of spinning.
I usually cut between a 1.6 and a 1.9 with drag radials. So long as I'm under 2.0 I think I'm doing well.
My main thing is I can't afford to do the suspension correctly at this point in time. Hell I'd love to do a solid rear conversion with traction bars. That would open the door for gear combos and actual aftermarket support...lol.
An open mind is the key to enlightenment. Humility isn't really my thing
The only reason I said anything about anti-squat was because it was said that my stiff coilover springs wouldn't be good for drag. That's the ONLY reason I said anything.visser003 wrote:Squat is not bad, it has been used in drag for MANY years. Anti-squat is a relatively new idea and has been found to slightly outperform the previous squat setups.
That being said, you are making it seem like a world of difference and the fact is it only will slightly outperform a properly setup squat.
Anti-squat, though, is extremely hard to setup correctly to gain more benefit compared to squatting.Your not a professional with a team of engineers, if you want the max performance you should go with a softer rear.
I'm sorry for saying unecessary things, I'll edit it.spank044 wrote:Calm down pal. We were having a discussion about what we feel and think. You are the only one getting angry and upset by any of the comments posted. We are all in titled to our opinions without you needing to call names or make gay remarks. You need to learn how to accept a little opposition with some integrity, if you need to take a couple minute breather before you reply. I learned a long time ago it isn't worth getting mad over what someone types on a forum.
I got an email from Goran at GZM in australia. They are a jatco specialist and he responded to me asking about either the 01 or 03 for my 600whp goal by say that the 01 might live at that level for a while but the 03 would be a better choice. They have the valve body for high powered versions of either trans as well as rebuild spec sheets for max duty setups. My 3n71 is strong enough but I want overdrive for highway drivingWDRacing wrote:So...
I SERIOUSLY just want to go automatic. If I had the money to bolt up a TH400 I'd be ALL over it. Sadly, I do not have the funds for that.
I wonder how much power the KA slushbox would hold if I had Precision Industries rebuild the converter? Any guesses? Assuming that the only time it would see nitrous or more boost then 10 psi would be on the track. Also, KA auto's are literally lying around everywhere. I could probably get 4-5 donated to the cause from just Nico members alone I have one just sitting in my yard under a tarp
Really Stephen? I'm sorry man but there is always room for discussion about every topic. Time and again the guys reading this thread have stated that no-squat set ups have the potential to be SLIGHTLY better then a properly set up softer rear end. But the gain is minimal. Unless you're comparing stock suspension to the aftermarket one you'll be using, in which case that's a awful comparison.GODCHSR wrote:
So show me proof of your claim _____ or say nothing at all
I don't see anywhere in your initial post about the current subject where you state openly and clearly that you're aiming for a properly tuned no-squat set up. THAT would have been the time to explain your goals and why you're going with a harder set up compared to the usual softer suspension that relies heavily on squat to maintain traction. Perhaps you were trying to educate us, but you did so poorly and with an arrogant tone. The internet doesn't express emotion well.GODCHSR wrote:Coilovers are in.
Why didn't anyone tell me it would make such a HUGE difference! Holy CRAP! Seriously the thing barely has any give at all. It is TIGHT!!!!
I was showing some friends in my garage yesterday. I stood on the trunk and bounced my weight and it BARELY moved at all.
I am in awe.... going to the store was awesome too... IE:Normally I would have to get a slight swing from to right to 'throw' the car one way in order to compensate for the sway/energy being absorbed... NO more.. NO MORE! I can turn and hit the gas and the thing just slides! I mean seriously, it just freaking goes sideways!
Anyway, having a welded diff helps a ton I am sure, but for the record... coil-overs are THEE way to go.
Yes, room for discussion to find out the right answer. Squat is inferior on every level to an anti-squat (or better yet, rear lift) setup in every way on EVERY type of suspension.WDRacing wrote:
I agree... that my tone became arrogant but only after arguing an issue where the answer is tangible. If we were discussing pizza and tacos I would not be arrogant is saying Pizza is better, because I "think' it is.We are discussing simple and proven science... not scientific 'theories'. I don't care about opinions, I care about evidence. Show me the evidence.It's "me" that is arrogant, I myself did not create the law of physics... but the law of physics remains. So I will defend the truth and that is what I have stated.WDRacing wrote: Perhaps you were trying to educate us, but you did so poorly and with an arrogant tone. The internet doesn't express emotion well.
My intentions are to go from 0-fast as quick as possible. A stiff suspensionw ill make that happen more quickly.WDRacing wrote:We posted with limited info to go on. After you made your goal clear you'll notice that we did acknowledge that no-squat has the potential to be better. Potential being the key word there.
Squat does work just like a crappy suspension "can" work when drifting but it doesn't mean you should.WDRacing wrote:Here's a tip, if you want 2 way communication you can't tell people they are simply wrong and don't know what they are talking about. Especially when squat DOES work.
I agree but for the record people... I don't care about ideas and opinions unless we're in the exterior/interior styling thread. Then you can debate what wheels or sideskirts look better.WDRacing wrote:Lets all calm down and remember that this is a discussion forum. People have different idea's and goals and they are all welcome here.
Dude, this is really stupid... I never once acted like it was going to take full seconds off... but this is a drag race right??? I mean 10ths do make a major difference, right? People spends thousands of dollars to shave tenths... I AM TRYING TO BREAK A RECORD HERE!!!!!!!WDRacing wrote:Just for the record, since we're talking about facts here, you're only going to gain a couple tenths on the launch IF you set it up correctly. Going stiff isn't then end all to fast times homie. One of the reasons you're getting a rebuttal is because you're acting as if you're going to shave off entire seconds when you simply aren't going to.
Best of luck to ya.
What record?GODCHSR wrote:I AM TRYING TO BREAK A RECORD HERE!!!!!!!
GODCHSR wrote:Sweet!
The tuning all takin care of. I already bought the AEM EMS, just need injectors and new turbo.
I'm shooting for 450rwhp and high tens... 10.99 at least. yikes... lol
I've already got the turbo. HX351991ls13 wrote:just get this turbo and call it a day
100shot of nitrous is going to blow your stock motor. Please take a video of the pass if you to spray...I am entertained by exploding motors.WDRacing wrote:Just install nitrous and only use it if you can't bust into the 10's. Have it activate in 3rd for a 100shot. THAT's 10's or bust
100 should net half a second
Well stock with 25psi of boost perhaps! hehehe100shot on a stock motor (low boost) and tuned properly won't hurt anythingvisser003 wrote:
